massive classic parts thread
ok its getting hard work checking all my ads so iv got them all together in 1 place so here we go
all parts are off and ready to go collection preffered on all items but can post at cost the smaller items so please ask
collection from walsall west midlands
call or tx for a quicker reply cheers
07785942237
ENGINE BAY AND DRIVE TRAIN PARTS
wrx ver 4 complete mint working engine runs sweet as a nut no knocks or rattles engine no smoke or oil or water being used approx 70k use £480
mint working condition gear box with gear linkage still fitted with prop and matching rear diff all in perfect working order covered around 76ooo removed from uk turbo2ooo
poss been refurbed as drives so sweet with very positive gear change no crunches or wines no jumping out ov gears also gear box code in first pics
£250complete
mint working gear box removed from low milage sti version 6 with matching rear 4.444 rear diff perfect working order smooth gear changes no wines or crunches and no jumping out ov gear complete with prop shaft gearbox code ty754vbaaa £sold sold sold
speedo convertor/limiter remover for early cable driven cars good working order £30
version 1 5th injector ra inlet manifold complete throttle body not pictures but is there £40
unnamed turbo timer worked well in car no instructions or anything tho £15
as new 3 port boost solinoid looks spanking new and mint working order £sold sold sold
early plastic header tank mint con no leaks £25
good condition VERSION 5/6 classic heads £sold sold sold
wrx ver 3/4 heads good con perfect working order on car no rattles or noises complete with cams and valve train and rocker covers £80 pair
used 4 paddle clutch (friction plate ony) had about 2mm before rivates so still fair bit ov life in it yet believe to be ap £sold sold sold
genuin welbro 255lph fuel pump done around 7k in good working order fitler bag could do with a clean £sold sold sold
stainless steel exhuast monngoose make sounds good not to loud 2.5" system with 3.5" tailpipe £130
near new uk 2000 twin pipe back box very good con tail pipes need a polish tho £20
2x metal header tanks both good order no leaks or damage £30 each
ver 5/6 coil pack good working order no damage £sold sold sold
ver 5 sti ecu possably been ecotekked already but carnt comfirm runs perfect on car and pulled very strong £50
ver1/2 power steering pump good order no leaks or whines £25
2x starter motors both good working order no sticking or noises £25 each
3x alternators all good working order when removed £30each
2x ver 1/4 engine covers sets all good con £sold sold sold
std flywheels x2 good working order no juddering £20 each
standard headers good con no blowing £20
phase 2 cross over pipe ideal for 2.5 convertions £20
sti ver 5 map sensor good con £sold
washer bottles x4 3 jap spec and 1 uk with washer pumps £10 each
water bolt bracket for intercooler spray kit (bracket only) £10
INTERIOR PARTS
ver 5/6 momo sterring wheel complete with air bag ood con £60
swoosh smoked 1.5bar 52mm boost gauge and oil temp gauge in twin a pilar post pod all in mint working order with sensor and adapterplate for sensor £sold sold sold
classic water spray button £15
classic 260mph speedo cluster iv only ever seem 1 set ov these up for sale before so very rare £40
nardni steering wheel near mint con from later spec cars with better middle section i believe £40
sti rear sued rear bench good con will be cleaned before sale no rips or burns £20
classic ra door cards sti spec with sued inserts 3 in good con but 1 rear has got slight damage to lower parts see pics these have holes for manual window winders also £sold sold sold
blitz boost gauge good con pod not inc needs wiring for light £15
uk spec blue flec front and rear seats good con no rips or burns £110
sti type r 2door rear bench black with gray suede middle good con no rips or tears £30
sti spec ver 5 clocks good working con £sold sold sold
uk spec ver 5 clocks good working order £30
p1/sti 2door door cards good clean order 1 has strach on leather top half easy repair £45set
early gear gaitor with leather gear **** good con £20
type r interior plastics around windows and sills £40set
facelift dash good con complete minus clocks and centre consol £60
facelift centre consol good con complete £30
2x v5 black carpet good con £30
wiper arms sets most in good con few sets left £15 front sets
ALL INTERIOR PLASTICS AVAILBLE PLEASE ASK FOR DETAILS
EXTERIOR PARTS
ra doors with wind down window mechs and glass paint work on doors not the best ideal for you track car boys who want to shed the weight ov electric windows £sold sold sold
front wings in 230 white paint work not the best close up all good con no dents or rust £sold sold
classic rear bumper good con apart from small part on paint work see pics colour is 230 white £20
prefacelift front grill good con apart from small crack near badge hardly noticable £10
prefacelift alu bonnet in good con paint work not the best close up complete with middle vent no side vents tho £45
prefacelift mini scoobs for side vents good con and fit £25 pair
lexus style rear lights ok con £20pair
boot lid from sti5 so has all holes for big spoiler good con no rust small dent in middle and wrx/sti sticker needs fully removing £20
unpainted side skirts full set good con £30
prefacelift front bumper in 74f blue decent con has mounting holes on front for standard front splitters tho£25
facelift unpainted uk spec electric wing mirrors good con £25pair
uk spec rear lights all good con £25 pair
face lift ver3/4 grill in 74f blue good con £30
prefacelift head lights electric adjustable all good con £30set
std side lights 2x sets all good con £10 set
SUSPENTION & BRAKES
alloy bottom arms good con £60pair
classic ra quick steering rack good con no leaks again ideal for you track day boys very quic turning ratio £sold sold sold
uk spec shocks and springs all good con no knocks or bangs and no leaks £sold sold sold
rear vented drilled and groved disks good con plenty life left in them will be cleaned up before they sold £sold sold sold
red stuff ceramic rear pads for single pot classic good con plenty life in them £sold sold sold
standard 1pot rear cailpers and disks x3 sets all in good working order disks and pads all have plenty life in them £30set
ra none abs wheel hubs all good con also i have normal abs hubs full sets and drive shafts £15 each
PRIVATE PLATES
H8 EVD (Hate Evo) £850 OVVNO
i have aload ov loss bits that would tak eme forever to list so if you dont see the item you need please ask i may have it cheers
07785942237
£250complete
INTERIOR PARTS
EXTERIOR PARTS
SUSPENTION & BRAKES
PRIVATE PLATES
Matty pics are not working any chance you could forward me a pic of the timing covers? to balyy@hotmail.com
I'm assuming this is all the covers? i.e. fronts and backs? Thanks
hi banny yeah i think iv excedy my daily usage on photo bucket they be back on 2mrow bud i carnt forward any pictures until it resets bud sorry
and yes bud full set front and rear covers bud
lolol sorry baly im used to banny asking me for bits il pm you pics 2mrow bud no probs and paypal and postage not a problem at all bud
cheers fud your everywhere tonight bud
hi bud iv just emailed you back and yes to offer as for the type r that is my personal car bud only thing for sale on it is the palte bud sorry
hi bud i shouldnt see a problem but postage is a bit pricey iv just got this off royal mail site who i would be sending them by
Airsure Small Packets From 4 days Up to £39 Delivery Confirmation £27.76
so your talking £35gbp if interested bud
clocks still avaible as is 3port bud to be honest iv the only set ov these clock i seen went for 90quid but there just clocks to me so £45quid if interested bud
