Swirl pot / fueling set ups
post your swirl pot / fuel set up
got an sm engineering jobby to put in somewhere so need inspiration inc hosing, pumps etc.
mines got 3 x -6 'inlets' i presume and a -8 outlet, sound normal? does one have to be a breather?
I have mounted mine under the bonnet, passenger side at the rear just in front of the removed air con pipes. No pics at the moment but I will try and get some.
In answer to the breather question, no the 4 pipes are return to tank, return to swirl pot from regulator, and feed in and feed out.
really? some pics of yours would be appreciated martyn, can you let me know which pipes on yours are which then? iv got one on the top, 3 on the side, the bottom -8 must be the fuel out im guessing. not sure which way round to arrange the other 3 x -6 ones!
Isnt it a bit dodgy putting the swirl pot cool etc in the front of a car engine bay where its most likely to suffer damage in an off/accident?
The fuel cooler has done a perfect job at sorting that small issue out. Just fitted it in the return to the swirl pot from the fuel regulator.
A sytec bullit fuel filter is now mounted on the otherside of plate and all fittings have been ordered from Alex Austin at Torques UK with sard FPR mounted on bulkhead with mocom racing adapted fuel rails .
20
22 October 2015 06:12 AM
johnnybon
Wheels And Tyres For Sale
7
25 September 2015 07:49 AM
