UPDATED CLASSIC PARTS LIST
Old 11 January 2010, 07:01 PM
Default UPDATED CLASSIC PARTS LIST
ok old thread is getting bit long in the tooth now and dont want people have to read 4pages to check if the part there after is poss sold already so here a fresh list
collection preffered from walsall west midlands
call or tx for a quicker reply cheers
07785942237
ENGINE BAY AND DRIVE TRAIN PARTS
wrx ver 4 complete mint working engine runs sweet as a nut no knocks or rattles engine no smoke or oil or water being used approx 70k use £450
3" stainless de cat down pipe in good con came off a 3"system but looks to able fit 2.5" systems also £sold
/mattybr5/P110110_13580001.jpg[/IMG]
brand new catch tank in mint con trail fitted but never used complete with pipe wreok that come with the kit £25 quid
HUGH ALLOY UPGRADED SLANTED INTERCOOLER FOR EARLY CLASSICS GOOD UP GRADE OVER POOR EARLY INTERCOOLERS COSMETICALLY IT NEEDS A GOOD GOING OVER WITH THE BRUSH OV POLISH BUT AS A UNIT ITS MINT WITH ALL THE BLADES PERFECT ALSO COMES WITH A UPRATED CAST HARD METAL PIPE TO GET RID OV THE FLIMSY PLACTIC 1 FITTED AS STANDARD THIS ALSO HELPS FLOW AS ITS A LARGER BORE THAN STANARD 1 ALSO
(BOLTS TO ALL ORGINAL MOUNTS ANS HAS TAKE OFF OF FOR RECIRC OR D.V)
£sold
GOOD WORKING 3 PORT SOLINOID IN PERFECT WORKING ORDER ON CAR £30
4x early coilpacks mint con done less than 2000miles no cracks and in perfect order £sold
GOOD RAD COMPLETE WITH TWIN FANS NO LEAKS £sold
GOOD VERSION 1/2 POWER STEERING PUMP NO LEAKS AND NO WHINES £30
GOOD WORKING WRX GEARBOX SEE PIC FOR CODE NO WHINES OR CRUNCHES AND GEARCHANGE STILL NICE AND TIGHT COMPLETE WITH MATCHING REAR DIFF AND PROP £sold
1x adjustable fuel regulators mint con worked excellent on the car and controlled fuel brillant at 3.5bar £25
2x speedo convertor/limiter remover for early cable driven cars good working order £30each
version 1 5th injector ra inlet manifold complete throttle body not pictures but is there £40
version 1/2 standard inlet near complete minus throttle body £25
2x early plastic header tank mint con no leaks £25
near new uk 2000 twin pipe back box very good con tail pipes need a polish tho £sold
ver 5 sti ecu possably been ecotekked already but carnt comfirm runs perfect on car and pulled very strong £50
3x starter motors both good working order no sticking or noises £25 each
3x alternators all good working order when removed £30each
std flywheels x3 good working order no juddering £20 each
2x standard headers good con no blowing £20each
washer bottles uk with washer pumps and smaller jap spec 1 £10 each
water bolt bracket for intercooler spray kit (bracket only) £10
INTERIOR PARTS
ver 5/6 momo sterring wheel complete with air bag ood con £sold
classic water spray button £15
classic 260mph speedo cluster iv only ever seem 1 set ov these up for sale before so very rare £35
classic wrx clocks reads as mph with silver suround good working order £30
nardni steering wheel near mint con from later spec cars with better middle section i believe £40
nardni steering wheel good con £30
version 1/2 sti rear sued rear bench good con will be cleaned before sale no rips or burns £20
uk spec blue flec front and rear seats good con no rips or burns £120
early wrx interior in very good con no rips or tears and drivers seat in very good con no sign's ov wear on fabric just a little bolster sagging not much tho £70 front and rear seats
early wrx door cards in very good con with all switch gear also to macth above trim £40 set ov 4
sti type r 2door rear bench black with gray suede middle good con no rips or tears £30
uk spec ver 5 clocks good working order £30
p1/sti 2door door cards good clean order 1 has strach on leather top half easy repair £45set
early gear gaitor with leather gear **** good con £sold
type r interior plastics around windows and sills £40set
facelift dash good con complete minus clocks and centre consol £60
facelift centre consol good con complete £30
pre facelift dashes x2 both good con near complete please pm for whats included
£30 each
3x black carpets good con £30
wiper arms sets most in good con few sets left £15 front sets
ALL INTERIOR PLASTICS AVAILBLE facelift and pre facelift including dashes and most plastic trims PLEASE ASK FOR DETAILS
EXTERIOR PARTS
4x royal silver doors all in good con no dents or marks to speak ov 1 has very slight bubbling just under the door handle its the rear drivers side all complete with window motors and rest ov gubbings also so tinted windows all excellent con also £80 set ov 4 better pics to follow
cassic pre facelift front bumper royal silver pisnt nneds redoing bud bummper ok £20 pics to follow
classic rear bumper good con apart from small part on paint work see pics colour is 230 white £20
prefacelift front grill good con apart from small crack near badge hardly noticable £10
prefacelift alu bonnet has some fire damage to centre bonnet still good and in shape just needs repainting idea for cheap track car or sumit vents are no good tho really £25
royal silver wings good con no dents slight corrsion on passanger side where it mounts to the bumper just started to go around the edge carnt tell when fitted £sold
lexus style rear lights ok con £20pair
boot lid from sti5 so has all holes for big spoiler good con no rust small dent in middle and wrx/sti sticker needs fully removing £20
royal silver boot lid ok con has been drilled for big spoiler £sold
2x sets ov unpainted side skirts full set good con £30
royal silver electric folding wing mirrors good con £30pair
facelift unpainted uk spec electric wing mirrors good con £25pair
2x uk spec rear lights all good con £25 pair
face lift ver3/4 grill in 74f blue good con £30
2x sets prefacelift head lights 1 electric adjustable set and other none electric all good con £30set
std side lights 2x sets all good con £10 set
WHEELS
unknown 15"wheels used to keep car movable ideal to keep your motor off the ground while you have yours refurbec £30 set
standard 15" 5spoke subaru wheels fitted to early ra with polised lip and dark centre all good con tyres arent up to much tho £30set
pics to follow
SUSPENTION & BRAKES
wrx spec springs and shocks good con no rattles or knocks £60set
2x pairs ov alloy bottom arms good con £60pair
2pot front cailpers all good con complete with disks and pads £30 complete
pics to follow
standard 1pot rear cailpers and disks and pads £30 set
ra none abs wheel hubs all good con also i have normal abs hubs full sets and drive shafts £15 each
PRIVATE PLATES
H8 EVD (Hate Evo) £850 OVVNO
i have loads more bits that would take me forever to list so if you dont see the item you need please ask i may have it cheers
Mattybr5@MB Developments is offline
Old 12 January 2010, 09:27 AM
pm's replied
Old 12 January 2010, 09:34 AM
tk09
tk09's Avatar
matty u still got the fog mesh covers?
tk09 is offline
Old 12 January 2010, 07:40 PM
no sorry mate they went on ebay i said to pm if you was interested and you didnt bud so i just took it you changed your mind soz
Old 12 January 2010, 08:59 PM
tk09
tk09's Avatar
i did pm u but maybe my net messed up no worries u got a crystal fog passenger?
tk09 is offline
Old 12 January 2010, 09:56 PM
sorry dude i dint get any pm as i would have keep them for you no probs i have sumit in the pipe line tho that may interest you il pm you with details when i get 5mins bud
oh p.s no crystals at the mo ether dude
Old 12 January 2010, 10:02 PM
tk09
tk09's Avatar
dame i really want one of them as i dont want one of ebay as they aint real subaru and matt maaan u cant leave me hangin like that lol
tk09 is offline
Old 12 January 2010, 11:44 PM
SILVERSCOOB81
SILVERSCOOB81's Avatar
didnt get a reply re gaitor and gearknob mate
SILVERSCOOB81 is offline
Old 12 January 2010, 11:45 PM
tk09
tk09's Avatar
silver i got a rear silver bumper btw
tk09 is offline
Old 13 January 2010, 11:13 AM
tom iv not yet finished what i got in mind soon as i have you be first to know bud your just gonnna have to wait lol
silver sorry mate pm your way cheers
Old 13 January 2010, 05:17 PM
SILVERSCOOB81
Your inbox is showing as full mate can't reply its the early pre face lift I was interested in
Old 13 January 2010, 07:25 PM
vag.gary
vag.gary's Avatar
hi have you goy the blue p1 front splitter ?
vag.gary is offline
Old 13 January 2010, 08:02 PM
Off Your Marks
Off Your Marks's Avatar
how much for the wheels please
Off Your Marks is offline
Old 13 January 2010, 09:00 PM
nosjunkie
nosjunkie's Avatar
thanks for the parts was good to meet you tonight
will arrange to meet up again very soon
nosjunkie is offline
Old 13 January 2010, 09:29 PM
silver scoob sorry pal had few meassages come in its now cleared that gaitior is prov sold il let you know by 2mrow if it doesnt go mate
vag gary i decided to keep the splitter bud sorry
off your mark if you mean the advans there 700 mate
will really good to meet you mate and yes defo see you soon mate cheers again for braving the weather to come up
Old 13 January 2010, 09:39 PM
tk09
tk09's Avatar
matt wat ever it is best be good bro as i hate waitin lol
tk09 is offline
Old 13 January 2010, 09:55 PM
tom i can tell mate its nothing much just looks cool as *** il try get you some pics 2mrow mate if you can wait lolol
Old 14 January 2010, 12:31 PM
all pm's replied
Old 14 January 2010, 12:49 PM
dilbob
dilbob's Avatar
matt need a drivers side drive shaft complete with hub mate non abs
let us know your best price and can i fetch everything sunday?
dilbob is offline
Old 14 January 2010, 12:56 PM
i kyle iv got them err should be 30quid the pair do you them for 20quid bud your rails will be off ready for you then to mate cheers
Old 14 January 2010, 01:03 PM
dilbob
dilbob's Avatar
cheers matt whip off a rear top mount whilst your there lol extra £10
i take it your wheels have now arrived?
dilbob is offline
Old 14 January 2010, 01:08 PM
haha if i had 1 spare mate you could have had the mount but i carnt split a good set ov shocks for a tenner mate sorry
yeah my wheels have come today loving the dark moody look ov them mate
Old 15 January 2010, 10:59 AM
all pm's replied and list updated
Old 15 January 2010, 08:20 PM
pm's replied
Old 15 January 2010, 09:05 PM
SILVERSCOOB81
Hello mate did you send the gaitor and gear **** today mate :0)
Old 15 January 2010, 09:55 PM
hi bud yes its on its way to you its signed for so some1 gonna need to be in i think it maybe monday now tho bud cheers
Old 15 January 2010, 10:06 PM
hookie
hookie's Avatar
TOP MAN MATTY
hookie is offline
Old 15 January 2010, 10:18 PM
welcome matey glad to help out
Old 15 January 2010, 11:25 PM
SILVERSCOOB81
Nice one mate thanks again Your a star
Quick Reply: UPDATED CLASSIC PARTS LIST
