Subaru specific Catch Cans
Old 12 January 2010, 07:40 PM
Mad Hammer
Mad Hammer's Avatar
Default Subaru specific Catch Cans
Hi All,
I have recently had a catch can made for for track car build. I had done the same previously for my race car as the general market forgets about us Subaru boys needing 3 inlets rather than just 1 or 2. I am sure you have seen the RCM ones at £175+ !
It's certainly not cheap to get one made to the standard I wanted, however I was chatting with my supplier and he said he would be more than happy to do a batch at reduced costs if I would handle everything.
So spec is a 1 litre can with three 10mm inlets and one 25mm outlet. And a drain plug
We all know what the benefits are I am sure by getting rid of engine vapour, reducing crankcase pressure and by removing that vapour your not reducing the octane value of your fuel.
Heres a few pics of the one I have now unfitted.
Here's a pic of my other one I fitted on the passenger side suspension turret where it fits very neatly
And how much you call
Well for 5 it will be £69 each delivered. If we get 10 then just £65 delivered. Now not the cheapest out there for sure, have your £30-£40 ebay special with just 2 same size inlet/outlets if you want but these work far better I have run the whole of last season with one of these, generally with that hard drag/track use I would empty after every session to be sure. On the road these will take an age to fill.
So pop your names down and lets see if we can get enough
Old 12 January 2010, 08:04 PM
wrighty338
wrighty338's Avatar
clive il keep my eye on this. would you consider supplying the hose also?
Old 12 January 2010, 08:08 PM
Mad Hammer
Mad Hammer's Avatar
Let me look in to that mate, but yes seems like a top idea ! I just bought all the hose from my local motor factors for mine and it cost £16 !
Old 12 January 2010, 10:01 PM
rooferman
rooferman's Avatar
Mine doesnt seem to work very well and has only 2 outlets........
If its going to be a few weeks then count me in....
Old 13 January 2010, 08:23 AM
Mad Hammer
Mad Hammer's Avatar
Agreed I had a little 2 inlet/outlet can years ago and you had to T 3 pipes to 1 and then have the one outlet for the breather. Was a total waste of time on an Impreza. The 3 inlet can works perfectly as both heads and central breather all have there own pipes to the can.
I expect the GB to take 2 to 3 weeks dependent on take up.
Old 13 January 2010, 11:36 AM
Mad Hammer
Mad Hammer's Avatar
Okay pricing including pipework, so now 2 options
Can only - £69
Can with 2.5 metres of inlet pipework and 1 metre of the larger vent pipework - £79
If over 10 orders this reduces to £65 and £75 respectively
Let me know what you think or get your names down
Old 13 January 2010, 11:48 AM
TimH
Orange Club
TimH's Avatar
I'm up for this at the 5 or more price...with the pipes please
1) Tim Hardisty (with pipes)
2)
Old 13 January 2010, 12:27 PM
RA Dunk
RA Dunk's Avatar
2) RA Dunk (with pipes)
Old 13 January 2010, 12:37 PM
dazdavies
dazdavies's Avatar
Just to throw something else in the mix for the big power boys. What would be the odds of having the drain made bigger to say -10 so it could be used as a drain back to the sump?
Old 13 January 2010, 12:38 PM
banny sti
banny sti's Avatar
3) Banny sti Defo down for 1, possibly have a friend who may want 1 (no pipes)
Old 13 January 2010, 12:40 PM
TimH
Orange Club
TimH's Avatar
...and/or a fitting provided instead to allow a remote drain tap to be located somewhere convenient maybe?
Dumb question - does the can vent to atmosphere (through a filter) or does it go back to the intake?
Old 13 January 2010, 01:05 PM
Mad Hammer
Mad Hammer's Avatar
Just vents to atmosphere. I have my pipe pointing down cable tied near the bulkhead.
If there is demand then we could look at a further fitting to drain back to the sump. However this is only really required for serious track use. I have never bothered with this on mine I just empty regularly, as you then have the hassle of taking the sump off to ut a fitting on etc etc. Overkill for most imo.
Old 13 January 2010, 01:54 PM
alex_00s
alex_00s's Avatar
I'm in... since running without BOV and also solid inlet tract I've been in need of an oil catch tank and this is exactly what the doctor ordered!
100% I'm down for a tank and pipes!
3) Defo down for 1, possibly have a friend who may want 1 (no pipes)
4) alex_00s (with pipes)
ps: do you have the means or contacts to supply these anodised or powder coated (red/blue)?
Old 13 January 2010, 02:11 PM
Mad Hammer
Mad Hammer's Avatar
4) alex_00s
Sorry Alex, the firm I am using is just a 2 man band and they are exclusively aluminium boys
Old 13 January 2010, 03:04 PM
alex_00s
alex_00s's Avatar
no worries, I'm still definately in for one of these
Old 13 January 2010, 06:42 PM
millzy555
millzy555's Avatar
Just paint it mate bit of primer and 74f sonic blue would look good! only cost 20 quid for the paint!
Old 13 January 2010, 06:58 PM
RA Dunk
RA Dunk's Avatar
You could either polish it or get it powder coated i suppose
Old 13 January 2010, 10:52 PM
71/200
71/200's Avatar
4) alex_00s
5) 71/200 (with pipes)
Old 13 January 2010, 11:44 PM
slippy86
slippy86's Avatar
4) alex_00s
6) slippy86 (no pipes)
Old 14 January 2010, 10:19 AM
notfub
notfub's Avatar
4) alex_00s
7) Notfub (with pipes)
Old 14 January 2010, 12:32 PM
simon_mcc
simon_mcc's Avatar
4) alex_00s
8) simon_mcc (with pipes)
Old 14 January 2010, 12:36 PM
cav400
cav400's Avatar
4) alex_00s
8)cav400(with pipes)+further fitting to drain back to the sump) if you go for them
Old 14 January 2010, 12:49 PM
Mad Hammer
Mad Hammer's Avatar
If anyone else want a drain let me know what size you want it and I will enquire.
Clive
Old 14 January 2010, 01:32 PM
banny sti
banny sti's Avatar
Clive I am looking to drain back to the passenger side head, so would also be interested in a standard size return.
Banny
Old 14 January 2010, 01:34 PM
TimH
Orange Club
TimH's Avatar
What is the actual drain fitting as "standard" on this unit? It's difficult to work it out from the picture
Old 14 January 2010, 01:48 PM
cav400
cav400's Avatar
Clive
-10 please
Old 14 January 2010, 02:04 PM
simon_mcc
simon_mcc's Avatar
4) alex_00s
9)cav400(with pipes)+further fitting to drain back to the sump) if you go for them
Old 14 January 2010, 09:19 PM
alex_00s
alex_00s's Avatar
Old 14 January 2010, 09:55 PM
Mad Hammer
Mad Hammer's Avatar
Banny,
Do you want the second one ? If so we are there and I can start getting everything together
Clive
Old 14 January 2010, 10:22 PM
wrighty338
wrighty338's Avatar
clive, il take one matey. ideally wanted one with a drain but i can look at converting it later.
10) wrighty
Quick Reply: Subaru specific Catch Cans
