massive classic parts clear out
last thread thread is getting bit long in the teeth now and dont want people have to read 4pages to check if the part there after is poss sold already so here a fresh list
collection preffered from walsall west midlands
call or tx for a quicker reply cheers
07785942237
ENGINE BAY AND DRIVE TRAIN PARTS
version 3 wrx engine in excellent running order no leaks no water or oil use and no knocks or rattles can be herd running in the car till runday7/02 complete long block with standard headers NO turbo or inlet manifold all with 72k on the clock £400 for quick sale
sti version 3 bottom end unsure ov condition as brought as a good engine for the heads but i havent personally tried the bock...as pictures its mostly been stripped down bores are perfect and no signs ov bearing wear when the sump was removed so ideal for cheap sti pistons/rods/block and possible crank also could be perfect £50
damaged 3" open neck sports cat..cat in good con but some tool has jacked the car up on ther last part ov the down pipe and crushed the pipe so it would need cutting out and piecing should be easy fix and make for a cheap sports cat £50
brand new acl race bearings main and big end for middle thrust blocks..brand new and un open wrapping surplied by rcm at cost ov £110plus delivery there standard size bearings (see pics for applications) £70quid for both sets
version 3/4 mint working coilpack £40
better pics to follow
power steering lines with built in cooler £25
automatic starter motor believe to be same as 6speed items very good con £40
standard re circ valve and pipe work £20
mint metal header tank no rust or corrsion £30
2 port solinoid good working order £20
standard top mount good con £20
version 3/4 inlet mainfold bare in very good con £30
standard middle section exhaust good con £20
5"back box unsure ov make in decent con small scrap on tip but carnt see when fitted it looks like its been modded to fit the standard centre section failrly loud £30
version 1/4 cam covers in very good con complete set £30set
2x early plastic header tank mint con no leaks £25
ver 5 sti ecu possably been ecotekked already but carnt comfirm runs perfect on car and pulled very strong £50
3x starter motors both good working order no sticking or noises £25 each
3x alternators all good working order when removed £25each
std flywheels x2 good working order no juddering £15 each
2x standard headers good con no blowing £20each
washer bottles uk with washer pumps and smaller jap spec 1 £10 each
water bolt bracket for intercooler spray kit (bracket only) £10
INTERIOR PARTS
complete type r sti v limited interior this is the wrc version with the trophy stiched into the centre ov front seats in mint con no rips or tears and all bolsters mint also complete with rear seats also mint con also complete with all doors cards again mint con and complete £350 complete
more pics to follow
drivers side bolsters still in mint con
wagon load cover in excellent conditon and perfect working order £30
wagon boot trim all complete and excellent conditon £20 complete
pics to follow
standard automatic clocks good working order £30
classic water spray button £10
classic 260mph speedo cluster iv only ever seem 1 set ov these up for sale before so very rare £35
nardni steering wheel good con £25
version 1/2 sti rear sued rear bench good con will be cleaned before sale no rips or burns £20
version 5 uk spec blue flec front and rear seats good con no rips or burns £100for quick sale
early wrx front and rear seats in very good con no rips or tears and drivers seat in very good con no sign's ov wear on fabric just a little bolster sagging not much tho £60 for quick sale
uk spec ver 5 clocks good working order £30
facelift dash good con complete minus clocks and centre consol £60
facelift centre consol good con complete £30
3x black carpets good con £20
wiper arms sets most in good con few sets left £15 front sets
ALL INTERIOR PLASTICS AVAILBLE facelift and pre facelift including dashes and most plastic trims PLEASE ASK FOR DETAILS
EXTERIOR PARTS
electric folding colour coded wing mirrors excellent working order £40pair
standard un painted side skirts excellent condition £25pair
standard fog lights excellent conditon no chips or anything £35 pair
[IMG]<img src="http://i310.photobucket.com/albums/kk415/mattybr5/P050210_16030008.jpg">[/IMG]
standard side lights good con see pics above £10pair
2x prefacelift ali bonnet 1x red 1x 262 silver both in very good con no dents or marks stickers on red 1s can be removed easy enough very light weight pictures ov silver 1 on request £60
4x 52d mica blue doors all in good con no dents or marks to speak all complete with window motors and rest ov gubbings also so all excellent con also £60 set ov 4 better pics to follow
cassic pre facelift front bumper royal silver paint nneds re doing £20 pics to follow
classic rear bumper good con apart from small part on paint work see pics colour is 230 white £20
2x sets ov unpainted side skirts full set good con £25
royal silver electric folding wing mirrors good con £30pair
facelift unpainted uk spec electric wing mirrors good con £25pair
2x uk spec rear lights all good con £30 pair
face lift ver3/4 grill in 74f blue good con £30
prefacelift head lights 1 electric adjustable set all good con £25set
std side lights 2x sets all good con £10 set
WHEELS
16" 6 spoke subaru wheels refurb in black complete with legal contact 2 tryes all round wheels are in very good con also clear std 4 pots and are amost some ov the lightist wheels subaru fitted as standard £100
unknown 15"wheels used to keep car movable ideal to keep your motor off the ground while you have yours refurbec £30 set
standard 15" 5spoke subaru wheels fitted to early ra with polised lip and dark centre all good con tyres arent up to much tho £30set
pics to follow
SUSPENTION & BRAKES
22b 4 pot cailpers £sold
standard 2pot front cailpers excellent working order with good disks and pads £40 complete set up
standard 1 pot rears again excellent working order complete with good disks and pads £30 complete set up
steel bottom arms good con £30 set
good con power steering rack £40
2pot front cailpers all good con complete with disks and pads £40 complete
pics to follow
standard 1pot rear cailpers and disks and pads £30 set
ra none abs wheel hubs all good con also i have normal abs hubs full sets and drive shafts £15 each
PRIVATE PLATES
H8 EVD (Hate Evo) £850 OVVNO
i have loads more bits that would take me forever to list so if you dont see the item you need please ask i may have it cheers
07785942237
INTERIOR PARTS
more pics to follow
pics to follow
EXTERIOR PARTS
WHEELS
pics to follow
SUSPENTION & BRAKES
pics to follow
PRIVATE PLATES
hi, i will take the standard recirulating dumpvalve and pipe work. must be the earlier standalone type that does not bolt dirct to the intercooler (the one pictured is perfect)
£20 posted?
cheers!
Ash
£20 posted?
cheers!
Ash
andy il give you a shout mate and deano sorry bud no morrette lights for sale pm's replied
just to add guys iv just started stripping a sti version 4 wagon with a few goodies on like coilovers full 3" exhaust induction kit and front and rear braces plus all the additional sti extras i will up load pics on a new thread shortly but pm if there is anything you need
sorry chris its gone now i only have my sti 4 bottom end with piston ring failure or i have another sti 4 bottom end with crank failure if any use
i dont have but my brother has 1 for grabs its sim to the version 5 sti 1 just with out a brake light built in really good quality and perfect fit its in 74f sonic blue he wants 130 for it bud
