3x 52 mm Prosport Gauges - Brand New Senders
****SOLD****
For sale: I have three 52mm Prosport gauges for sale in the standard white/amber combination. They are boost pressure (BAR), oil pressure (BAR) and oil temperature (deg. C).
All boxes supplied and brand new senders, holders, stickers, etc also. The only reason for sale is that I sourced some green ones. I already had the amber ones installed so the green ones are using the senders I already put in. You will get the senders and other gubbins from the green ones, which are identical (quite literally only the bulb that is different inside the gauge).
The amber ones are only a few months old and have only been used a handful of times. They've spent most of their time just sitting around in the garage. I finally got them into this pod below in January and then the green ones turned up a few days later .
£95 posted please but will listen to fair offers to those that state a reasonable case. Remember these are in the UK already
oh right,
Well... can you just take a pic of the oil pressure sender for me... thats the one i'm concerned about. most of the senders are huge you see, i want to see if the prosport ones are slimmer.
David
David
oil pressure sender-Prosport VDO type
Prosport Oil Pressure Gauge Sensor / Sender Unit on eBay (end time 26-Feb-10 10:49:41 GMT)
e30tech.com Forums - View Single Post - ProSport Gauge Sale! Inventory InStock! Gauges starting at $35.00
https://www.scoobynet.com/interior-1...ure-boost.html
I'd already wrapped and sent the gauges before seeing this.
