Non genuine newage MAF any good?
Old 07 March 2010, 03:43 PM
noisymini
noisymini's Avatar
Default Non genuine newage MAF any good?
As title really. I'm after a MAF for my 02 Bugeye STI. Best price i've found for a genuine Denso 22680-AA310 is £140 but there are non genuine ones on Ebay that also have a 12month warranty for £59.
Anyone out there actually tried any non genuine ones?
Air flow mass meter sensor Subaru impreza 22680-AA310 on eBay (end time 22-Mar-10 12:14:05 GMT)
Old 07 March 2010, 03:54 PM
wayner845
wayner845's Avatar
i bought one of these and it worked fine until i could afford the genuine article
Old 08 March 2010, 02:49 AM
billyray911
billyray911's Avatar
You have a pm
Old 08 March 2010, 08:20 PM
FB Tuning
FB Tuning's Avatar
I've had a couple of blueprint newage MAF's that have worked fine, and one that didn't work at all.
You pays your money and takes your chance
Old 09 March 2010, 06:38 PM
noisymini
noisymini's Avatar
Cool. Cheers for the info. Was thinking the cheap ones can't be that bad if they are willing to offer a years warranty so thought i might give one ago but have bought a denso one from billyray911 which arrived today so i should get to fit it tomorrow and fingers crossed it will fix the problem.
i assume i can just swap it over and i don't need to do anything to reset the ecu???
Old 09 March 2010, 07:32 PM
Splitpin
Splitpin's Avatar
That's not really saying much. There isn't much value in a warranty on an airflow sensor unless you can be reasonably confident that the seller's going to be around in 12 months' time. Possibly also worth pointing out that the warranty is unlikely to cover any engine damage that might result from a sensor failing or misreading.
In an ideal world you'd reset the ECU but you need a Select Monitor to do that on a newage car. It should re-learn pretty quick anyway although it might be worth disconnecting the battery for an hour or two.
Old 09 March 2010, 09:23 PM
discodancer
discodancer's Avatar
Anyone else got a genuine MAF sensor for sale for a bugeye 01 plate?
Old 12 March 2010, 07:48 PM
noisymini
noisymini's Avatar
Well I fitted the new MAF and it still suffered a loss of power after warming up properly and after a few full throttle blasts. So I disconnected the battery for a couple of hours. I figured it was worth a try because disconnecting the battery cleared an engine light I caused the other day buy unplugging the MAF with the engine running. I have since used an ECU reader and there are no faults still logged.
So far I think it has been OK though I need to give it a decent run to check. If I still have problems then be ready for a new thread asking for any ideas ;-)
Thanks for the help and big thanks to Harvey (Billyray911) for getting he new MAF to me so quick.
Old 13 March 2010, 09:14 PM
billyray911
No problems-hope it sorts the problem out
61
11 January 2021 03:08 PM
33
29 August 2017 07:18 PM
7
14 December 2015 08:16 AM
Scooby-Doo 2
8
26 September 2015 02:09 PM
Quick Reply: Non genuine newage MAF any good?
