MY99 UK parts list - cheap
Only the parts listed below and some small interior parts are left along with some misc items.
ImageShack® - bobred's Profile Page
Front Black mudflaps/brackets x 2 with Silver Subaru swoosh - £15 delivered
Petrol flap in RB5 Grey 86F - £10
Parcel shelf and o/e Subaru speaker covers - £15
Front and rear speakers - £10 a pair
Interior mirror - £5
Prop - £20
Wiper motor - £10
Wiper arms with wipers - £10 pair
Drive shafts rears only- £10 ea
Air con pump Fully working - £30
Space saver tyre [unused] - £15
Brake servo - £20
Brake fluid resevoir - £10
Airbag control unit/ECU - £30
Alternator - £15
Ignition/Plug leads ex cond x 4 - £10
Front and rear ARB's - standard - £10 ea
Plastic wiper/widscreen vent trim -£10
Front window mechanisms n/s only - £12
Central locking motor n/s only - £10
Front/rear seat belts - £10 ea
Front/top inner arches - £15 pair
Windscreen washer bottle/pump and hoses and spray nozzles - £10
Front door seals [bottom] - £5 ea
Wheel nuts x 20 although 4 lockable nuts are slightly damaged due to hammering a socket on them. - £10
A selection of dash switches - Headlight adjuster/rear demist/headlamp washer/- £3-5
Plastic trims around doors/belts /air vents etc £? [main dash is sold]
Subaru wheel/tool kit - £10 delivered.
Radiator bottom hose -£5
Airbox to inlet pipe - £8
No part too small. lol Postage can be arranged.
Thanks Bob
Prop - £20
Wiper motor - £10
Brake servo - £20
Alternator - £15
Thanks Bob
Bob
I'll take that hub, passenger-side sun-visor, and the bright-switch off your hands if you've still got'em. I don't think I'm close enough to collect, so if you could PM me once you've worked out postage, or box everything up and let me know size and weight.
cheers
Mark
cheers
Mark
