mega classic parts threads (2dr and 4dr version)
Old 31 March 2010, 07:00 PM
Default mega classic parts threads (2dr and 4dr version)
ok its getting hard keeping track ov my threads so all parts are now list in 1 ad any info or extra pictures needed please ask cheers
all parts are plus delievery if needed or collection more than welcome from walsall west midlands
call/tx/pm or if preffered email me
email address
matthewbaker791@btinternet.com
call or tx for a quicker reply cheers
07785942237
ENGINE BAY AND DRIVE TRAIN PARTS
very rare pink sti adjustable suspention only model i know to have these fitted is the s201 there pink but have also had a new lick ov pink paint so look mint sti stamped in rears are are adjustable via dial at bottom ov shock fronts are top adjstable sadly the passanger side has had slight heat damage from a small fire underthe bonnet adjustment still works and shocks work very well no knocks or bangs tho see bottom pics for damage£offers
genuin sti rear lateral link arms paint not the best but apart from that good con £offers
2x sets ov the steel cam wheels found on very early sti cars ideal for the version 1/4 bake light plastic wheels great up grade due to strengh £50set
version 3/4 engine wiring loom very good con all plugs are intact nonoe broke or any repairs £30
phase 2 cross over pipe ideal for the 2.5 conversions complete with sensors£25
good working green label maf £45
pics to follow
k&n cone filter to suit green label maf good con and with fittings £35
pics to follow
tdo5 turbo 90degree inlet all seems good con no play in shaft and no oil in exhaust housing £70
lightweight billet fly 5 speed flywheel very good con £100
3 port boost solinoid good working order £30
pics to follow
abs hubs good con £25quid each
drive shafts all good con £25each
alloy bottom arms good con with ball joints £70pair
hybrid front mount intercooler core only in good working order but is slightly bent was removed from ex time attack car that had light front impact causing this warp like from no damage to fins or anyting and carnt be seen when fitted to the car at all just worth noting half sprayed black and other side left in raw ali so can be flipped to what ever side suits you £60 NO PIPE WORK INCLUDED OR AVAILBLE SORRY
rare os giken exhaust from japan very rare to find over here and are very expensive new also the quality is second to none
2.5"flange fitting going to full 3" system in very good some minor scraps and underside but doesnt affect it in anyway also jasma approved from japan sounds awesome without being to loud for a 3" system also its a 1 piece system so no joins from cat back £150
uprated 5 paddle clutch good for well in to the 400's low milage and plenty life still £140
exedy ultra light weight billet fly wheel in very good con requirs a new spigot bearing only couple quid tho £110
lightweight underdrive bottom pully good con with nealy new belt to match £30
CAT BACK STAINLESS STEEL SYSTEM LOOKS A QULITY SYSTEM AND SOUNDS AWESOME 5" TAIL PIPE £sold
DECAT DOWN PIPE £SOLD
APEXI BOOST GAUGE IN VERY GOOD CON WITH ITS OWN HOLDER AS NEW £45
4X COIL PACKS £SOLD
GREEN LABEL MAF IN VERY GOOD WORKING ORDER £SOLD
performance panel filter orignally fitted to my sti version 4 believe its simota or simlier very good con re useable filter makes a good sound also £20
fuel filler neck pipe £SOLD
3port solinoid both in good working order £SOLD
good con rad single fan £40
pics to follow
std tmic good con £15
4x single coil packs all seem in excellent con £80
pics to follow
std catted down pipe good con no blowing or corrion £60
(pics tro follow)
std middle section in good con no blowing ect £20
(pics to follow)
bottle type pas pump good working order no leaks or noise's £30
(pics to follow)
version 2 uk wagon ecu good working order £30
pics and code to follow
2x power steering lines with built in cooler £25
automatic starter motor believe to be same as 6speed items very good con £40
mint metal header tank no rust or corrsion £30
standard version 3/4 top mount good con with all pipe work £20
version 1/4 cam covers in very good con complete set £30set
2x early plastic header tank mint con no leaks £25
ver 5 sti ecu possably been ecotekked already but carnt comfirm runs perfect on car and pulled very strong £60
3x starter motors both good working order no sticking or noises £25 each
3x alternators all good working order when removed £25each
std flywheels x2 good working order no juddering £15 each
washer bottles uk with washer pumps and smaller jap spec 1 £10 each
water bottle bracket for intercooler spray kit (bracket only) £10
INTERIOR PARTS
sti 555 v ltd front seats in very good con front and rears no rips tears or sagging £230 set
rare sti pedal set all good con full set £90
sti spec door cars all in very good contion no wear or tear complete with switch gear £60
sti facelift dash with rare passanger top glove box complete with all jap spec double din trim parts minus clocks £100
2x wagon load cover in excellent conditon and perfect working order £30
UK SPEC DOOR CARDS GOOD CON WILL BE GIVEN GOOD CLEAN BEFORE SALE £40 FULL SET
wagon boot trim all complete and excellent conditon £20 complete
pics to follow
standard automatic clocks good working order £30
version 1/2 sti rear sued rear bench good con will be cleaned before sale no rips or burns £20
uk spec ver 5 clocks good working order £30
early prefacelift steering wheel squib for air back equipped cars £25
uk facelift dash good con complete with air bag
clocks and centre consol not included £50
x2 facelift centre consol good con complete £40 each
3x black carpets good con £20 each
version 5/6 uk blue flex front seats in decent con no rips or tears will be all cleaned up before sale £60pair
uk spec wagon rear seats in good con with head rests£25
uk spec pre facelift door cards all in decent con all will be cleaned before sale complete with all plastic trims and switch gear £30set
smoked boost gauge in a a piller pod good working con £45inc pod
std version 2 uk spec speedo clusters £20
pics to follow
ALL INTERIOR PLASTICS AVAILBLE facelift and pre facelift including dashes and most plastic trims PLEASE ASK FOR DETAILS
EXTERIOR PARTS
facelift alloy light weight bonnet very good gon no dents or corrison just the usal stone chips at front in sonic blue 74f complete with all vents and under trays £250
carbon look after burner rear lights good con £80
smoothed boot in good con has had small line deleted looks good job £30
pre facelift front bumper with genuin 3 piece splitter in good con fog light covers NOT included £150
aftermarket fog covers in good con £20
aftermarket version 5/6 front grill for pre facelift head lights with mesh grill in good con paint in crinkle black paint £30
2 front wings in decent con no visable rust few minor dinks nothing major £40pair
all four doors all seem in good con no visable rust complete with all internal grubbings ect few minor dings nothing major £80full set
wagon pre facelift rear bumper 230 white rear bumper in good con with unpainted hockey sticks £30
pics to follow
standard rear wagon lights in good con £30pair
pics to follow
rear bumper good con but will requir work when removed due to wide arch blended in il remove best i can £20
version 3/4 front grill good con £30(prov sold flectcher)
facelift headlights £30pair
4 doors all look in good con no rust or dents as i can see but rears will have marks where rear wide arches removed £80set
better pics to follow
good con boot lid in 74f no marks or dinks £60
salon facelift rear bumper in very good con complete with hockey sticks £40
std 2door side skirts good con £50 set
FACELIFT FRONT BUMPER IN GOOD CON NO CRACKS OR SPLITS AND UNCUT middle but has had some splitter fitted in the past so has slight cuts in air ducts see bottom pics WEDGES/INDERCATORS/FOGS ARE NOT INCLUDED £70
FACELIFT GENUIN CRYSTAL HEAD LIGHTS ELECTRIC ADJUSTMENT IN VERY GOOD CON LIKE NEW £100PAIR
GENUIN CRYSTAL FOG LIGHTS IN EXCELLENT CONDTION NO CRACKS OR CHIPS £60PAIR
CRSTAL FACLIFT FRONT BUMPER INDERCATORS IN VERY GOOD CON £25
CRYSTAL SIDE LIGHTS IN VERY GOOD CON £sold
black crystal side light practically brand new £25 pair
smoked side repeaters practically brand new £20pair
CRYSTAL SIDE REPEATERS IN EXCELLENT CON £20 PAIR
VERSION 5/6 FRONT GRILL IN EXCELLENT CONDITON £60
facelift wagon rear bumper in very good con no cracks or bumps complete with colour coded hockey sticks in 406 silver £40
FRONT WINGS drivers side in decent con very min rust with good paint passanger side has got fair bit ov rust on bottom edge mont point virtually gone £30 pair
REAR BOOT WITH MID LEVEL SPOILER WAS ONCE GREEN BUT REPAINTED VERY GOOD JOB DONE THO £80QUID PAIR
FACELIFT REAR BUMPER WITH MATCHING HOCKEY STICKS IN GOOD CON BUT PAINT NEEDS ATTENSION £40
4 DOORS 3 LOOK IN VERY GOOD CON BUT DRIVERS HAS SOME SLIGHT RUST ON BOTTOM EDGE ALL COMPLETE WITH TINTED WINDOWS AND ALL DOORS INTERNALS £80 FULL SET
fuel filler cap cover very good con in 406 silver £10
colour coded 406 silver side skirts good con £30set
electric folding colour coded wing 406 mirrors excellent working order £40pair
standard un painted side skirts excellent condition £25pair
standard fog lights excellent conditon no chips or anything £35 pair
cassic pre facelift front bumper royal silver paint needs re doing £20 pics to follow
facelift unpainted uk spec electric wing mirrors good con £25pair
2x uk spec saloon rear lights all good con £25 pair
std side lights 2x sets all good con £10 set
WHEELS
17"speedline prodrive wheels in very good con no curbing with mint goodridge tyres all in 215/45/17 all with at least 6mm tread on £280
tei 17" wheels in decent con some curbing and polished lips need attention but clear std 4pot cailpers no probs tyres dont look in best con £250
16" UNKNOWN WHEELS IN VERY GOOD CON NO KURBING AT ALL SADLY NO CENTRE CAPS TYRES LOOK LEGAL BUT EDGES ARE CRACKING SO AM UNSURE £100 SET
standard 15" 5spoke subaru wheels fitted to early ra with polished lip and dark centre all good con tyres arent up to much tho £30set
pics to follow
SUSPENTION & BRAKES
steel bottom arms good con £30 set
standard springs and shocks all seem in good con no rattles/knocks or visible leaks £60 full set
(pics to follow)
steel bottom arm good con £30pair
pics to follow
front subaru 4pot cailpers with good con disks and pads in excellent working order no sticking pistons ect ideally need painting £200all in
std rear 1pot rear brakes solid disks good working con decent disks and pads £30 all in
pics to follow
2pot front cailpers all good con complete with disks and pads £30 complete
pics to follow
standard 1pot rear cailpers and disks and pads £30 set
ra none abs wheel hubs all good con also i have normal abs hubs full sets and drive shafts £25 each
PRIVATE PLATES
H8 EVD (Hate Evo) £850 OVVNO
i have loads more bits that would take me forever to list so if you dont see the item you need please ask i may have it cheers
Mattybr5@MB Developments is offline
Old 31 March 2010, 07:35 PM
Bealescooby
Bealescooby's Avatar
matt i ll have wheel
Bealescooby is offline
ste123
ste123's Avatar
mate any joy with them rear brakes? and have you got a dump valve for my94?
ste123 is offline
Old 31 March 2010, 07:40 PM
bonescnj
bonescnj's Avatar
hi mate no luck with face lify front bumper ?
cheers
chris
bonescnj is offline
Old 31 March 2010, 08:32 PM
beal sorted over phone
ste sorry dude there coming off 2mrow mate iv been so busty sorry il drop you a tx sorry no dv tho mate
bones iv got 1 good uncut 1 mate iv just gotta sort a picture out mate drop me a pm if any use and we sort it out dude
Old 31 March 2010, 09:25 PM
ste123
ste123's Avatar
ok mate sound
ste123 is offline
Old 01 April 2010, 12:14 PM
cheers ste
all pm's replied
Old 01 April 2010, 12:31 PM
mr_D
mr_D's Avatar
u still have oil cooler?
mr_D is offline
Old 01 April 2010, 12:37 PM
hi bud i do at the momment i have another memeber also interested aswell bud
Old 01 April 2010, 12:41 PM
mr_D
mr_D's Avatar
ah ok. well if he has it then he has it. but if he doesnt then i might be interested.
mr_D is offline
Old 01 April 2010, 12:48 PM
ok bud no worries cheers
Old 01 April 2010, 05:29 PM
magicsy
magicsy's Avatar
received discs n pads cheers mate
magicsy is offline
Old 01 April 2010, 06:39 PM
cheers magic i was worried they wouldnt get there as taken so long sorry about that mate hope they serve you well dude
Old 02 April 2010, 12:07 AM
Jamz_
Jamz_'s Avatar
You selling the number plates? Could be intrested in the H8 or the FAT one
Jamz_ is offline
Old 02 April 2010, 10:37 AM
hi james yeah the h8 evo is up for sale all details are at the bottom ov the thread im unsure about the FATTA plate tho but pm me a offer if interested il see if its worth me parting with cheers
Old 02 April 2010, 01:34 PM
Tigerfill
Tigerfill's Avatar
have you still got the omp wheel?
Phil
Tigerfill is offline
Old 02 April 2010, 04:10 PM
beardy01
beardy01's Avatar
how much for tear drop mirrors bud
beardy01 is offline
Old 02 April 2010, 04:12 PM
beardy01
beardy01's Avatar
how much to post 406 silver mirrors#
beardy01 is offline
Old 02 April 2010, 06:14 PM
beardt sorry the teardrop miirors ahve now gone the 406 1s are 48quid deleivered cheers
tigerfill sorry bud its prov sold to beale bud sorry
Old 02 April 2010, 11:46 PM
Bealescooby
steering wheels mine
free bump for matt
Old 03 April 2010, 10:26 AM
lol it certaintly is mate cheers
Old 03 April 2010, 11:37 AM
Tastyturbo
Tastyturbo's Avatar
Hi there - Looking for some uprated suspension for my classic wrx if you are able to assist please?
Tastyturbo is offline
Old 03 April 2010, 07:19 PM
LongJonnyGspot
LongJonnyGspot's Avatar
Interested in boot. You have pm
LongJonnyGspot is offline
Old 04 April 2010, 09:56 AM
tasty turbo sorry mate im all out at the mo sorry
longjonny yhpm back at you mate
all pm's replied cheers
Old 05 April 2010, 06:15 PM
list up dated with few new parts added
all pm's replied
Old 05 April 2010, 08:56 PM
bonescnj
bonescnj's Avatar
hi intercooler core please .. face lift bumper too ....
pm me mate
chris
bonescnj is offline
Old 05 April 2010, 09:09 PM
leecalcars
leecalcars's Avatar
intake pipe for my00 would be nice and standered springs price please mate.
leecalcars is offline
Old 05 April 2010, 10:00 PM
bones pm replied mate cheers
leecal sorry i dont have that year induction hose in sorry and only springs i got are prov sold at the mo mate sorry
Old 07 April 2010, 10:53 AM
pm's replied
Old 09 April 2010, 12:43 AM
btt
Quick Reply: mega classic parts threads (2dr and 4dr version)
