MY99 UK parts from broken car
Old 06 April 2010, 08:52 PM
bob r
bob r's Avatar
Default MY99 UK parts from broken car
Only the parts listed below and some small interior parts are left along with some misc items.
ImageShack® - bobred's Profile Page
Front Black mudflaps/brackets x 2 with Silver Subaru swoosh - £15 delivered
Petrol flap in RB5 Grey 86F - £10 delivered
Parcel shelf and o/e Subaru speaker covers - £18 delivered
Front and rear speakers - £10 a pair delivered
Interior mirror - £6 delivered
Prop - £20 delivered
Wiper motor - £12 delivered
Wiper arms with wipers - £15 pair delivered
Air con pump Fully working - £30 delivered
Space saver tyre [unused] - £20 delivered
Brake servo - £22 delivered
Brake fluid resevoir - £12 delivered
Airbag control unit/ECU - £30 delivered
Alternator - £17 delivered
Ignition/Plug leads ex cond x 4 - £12 delivered
Front and rear ARB's - standard - £10 ea + £7 del
Plastic wiper/widscreen vent trim -£15 delivered
Front window mechanisms n/s only - £14 delivered
Central locking motor n/s only - £14 delivered
Front/rear seat belts - £7 ea delivered
Front/top inner arches - £15 pair
Windscreen washer bottle/pump and hoses and spray nozzles - £15 delivered
Front door seals [bottom] - £7 ea delivered
Wheel nuts x 20 although 4 lockable nuts are slightly damaged due to hammering a socket on them. - £14 delivered
A selection of dash switches - Headlight adjuster/rear demist/headlamp washer/- £5 ea delivered
Plastic trims around doors/belts /air vents etc £? [main dash is sold]
Jack - £12 delivered
Subaru wheel/tool kit - £10 delivered.
Radiator bottom hose -£5 delivered
Airbox to inlet pipe - £10 delivered
No part too small. lol
Pick up will reduce the price.
Thanks Bob
bob r is offline
Old 06 April 2010, 08:59 PM
R5_GTT_Steve
R5_GTT_Steve's Avatar
Have you got the rear wheel arch rubber things (sry for discription) and what kind of condition are they in?
They run the lengh of the wheel arch and push onto the lip.
R5_GTT_Steve is offline
Old 06 April 2010, 09:11 PM
Turbo_T
Turbo_T's Avatar
TMIC if u still got ?
Turbo_T is offline
Old 07 April 2010, 06:08 PM
bob r
bob r's Avatar
Sold
Sold
Btt
bob r is offline
Old 08 April 2010, 09:57 PM
bob r
bob r's Avatar
btt
bob r is offline
Old 09 April 2010, 09:57 AM
nerocircus
nerocircus's Avatar
Bob - I'l have the Jack please...
Also, do you have the original hose/pipe which is needed to put my OE recirc valve back on? THe one which gets blanked off when fitting a VTA...mine was cut right back when the VTA was fitted and I want to stick the recirc back on.
nerocircus is offline
Old 09 April 2010, 04:25 PM
bob r
bob r's Avatar
pm sent
bob r is offline
Old 11 April 2010, 05:44 AM
stevecsti
stevecsti's Avatar
alright m8 my frunt speakers r broken where r u ? any where near notts
stevecsti is offline
Old 11 April 2010, 09:09 AM
porky_wrx
porky_wrx's Avatar
Do u have headlight adjuster switch and don't suppose u got wiring for it
porky_wrx is offline
Old 11 April 2010, 09:46 AM
mark_sargeant1985
mark_sargeant1985's Avatar
Have you got the switch that turns the interior light on when door opens and loom? Both sides.
Also after the rubber grommets and tube that carry the wires for the doors (3door models)
mark_sargeant1985 is offline
Old 12 April 2010, 10:43 PM
bob r
bob r's Avatar
Pm sent
Sold
Sold
Not got them
bob r is offline
Old 12 April 2010, 11:58 PM
zakscooby1
zakscooby1's Avatar
phase 2 440 injectors?
zakscooby1 is offline
Old 13 April 2010, 02:57 PM
bob r
bob r's Avatar
Sorry, they have gone.
bob r is offline
Old 16 April 2010, 10:56 PM
bob r
bob r's Avatar
btt
bob r is offline
Old 16 April 2010, 11:15 PM
richgreenscooby1
richgreenscooby1's Avatar
hi mate , have you got the carbon canister that goes by the abs pump , and a fuel cap >
richgreenscooby1 is offline
Old 16 April 2010, 11:17 PM
bob r
bob r's Avatar
Both gone matey.
bob r is offline
Old 18 April 2010, 12:35 AM
bob r
bob r's Avatar
btt
bob r is offline
Old 18 April 2010, 09:37 AM
SiofChester
SiofChester's Avatar
Cost for a front lambda sensor (if it's the one with the wiring that's about 10cm long!) please
SiofChester is offline
Old 19 April 2010, 10:29 AM
bob r
bob r's Avatar
Haven't got one
btt
bob r is offline
Old 19 April 2010, 06:36 PM
Turbo_T
Turbo_T's Avatar
will the Alternator fit a early classic as my mate needs one
cheers
Turbo_T is offline
Old 19 April 2010, 07:10 PM
scooby1doo1
scooby1doo1's Avatar
Will the rear drive shaft fit my00 uk also rear diff if you still have and if it fits
cheers
scooby1doo1 is offline
Old 19 April 2010, 07:38 PM
sharpy10
sharpy10's Avatar
hi, have u got the master cylinder for the clutch, and the bit that goes through the car that attaches to the pedal. thanks steve
sharpy10 is offline
Old 19 April 2010, 09:03 PM
LongJonnyGspot
LongJonnyGspot's Avatar
Hi,
Can you help me out with a few parts
I'm after -
1. Fuel sender, no pump required for a P1. Blue label
2. Plastic air / brake ducts that sits directly behind the 2 lower slots of front classic facelift bumper. These attach to part of the underneath plastic panels, the ones between inner arch panel and bumper. It also has a fixing point on the bumper itself I think? I don't mean the wedges but the ducts , I think they direct air towards the brakes. I only need the passenger side.
3. The actual underside plastic panel, the one that runs under engine bay next to the removeable undertray. The one that the air duct fixes to as I tried to explain above, passenger side.
4. The grommits/ fixings for these bits.
If you have any of the parts could you PM a price
Many Thanks
LongJonnyGspot is offline
Old 20 April 2010, 01:12 AM
Captain Carbon
Captain Carbon's Avatar
Also, would you be interested in parting with the interior carpet? If so what colour is it and how much...
SS
Captain Carbon is offline
Old 20 April 2010, 10:49 PM
bob r
bob r's Avatar
cheers
Not sure matey.
cheers
Driveshafts will fit. Diff sold.
£12 delivered.
bob r is offline
Old 20 April 2010, 10:52 PM
bob r
bob r's Avatar
Originally Posted by LongJonnyGspot
Hi,
I'm after -
Many Thanks
Pm sent
SS
Carpet sold matey.
bob r is offline
Old 20 April 2010, 11:39 PM
scooby1doo1
I will have both drive shafts please
Old 21 April 2010, 07:26 PM
stedee
stedee's Avatar
theplastic inner arch covers, i iwll have them mate ,by any chance have you got the switch blank - the bigger one that is on the centre console by the handbrake and ill have the switches aswell please
steve
pm me your paypal address and i`ll pay up
stedee is offline
Old 21 April 2010, 09:34 PM
bob r
bob r's Avatar
pm sent
steve
pm sent
bob r is offline
Old 22 April 2010, 09:29 AM
Classic-Scott
Classic-Scott's Avatar
Hi have you got the radiator?
Classic-Scott is offline
Quick Reply: MY99 UK parts from broken car
