**Classic Parts from MY00 - LOW PRICES **
All these parts need to go, they are taking up space in my garage !!
GOING ON EBAY NOW
Lowered some of the prices to clear the stuff !!
Pictures are below the list
Window mechanisms - £15 each includes motor
Door switches - £20 for the lot
ABS pump - £20
Pedal set - £15
Brake fluid resevoir - £10
Coil Pack - £20
Battery - £15
Header Tank - £30
Plastic wiper/widscreen vent trim -£10
Rear Diff-3.54UK - £60.
Propshaft - £10
ECU Kick plate - £8
Complete set of plastic interior trims, including all trims around seatbelts, door trims, speedo cowling etc - £choose what you want
Unbranded Mid Level Spoiler in white, needs some work on it- £60
Under dash cowling - £10
Entire dash - no airbag - £35
Speedo clocks - £35
Glovebox - £15
Pictures
GOING ON EBAY NOW
ABS pump - £20
Pedal set - £15
Coil Pack - £20
Battery - £15
Header Tank - £30
Propshaft - £10
ECU Kick plate - £8
Speedo clocks - £35
Glovebox - £15
Pictures
Front drive shafts please is this £40 with post, would like the diff also but no good with prop.
There was no clunk sounds from the shafts or diff befor removal?
Location please as I may want to pick up if not to far
Based in High Wycombe, Bucks if that is any good to you.
I would have loved to take the prop off but fooked if I can. Maybe a friend of mine will come and help me
Diff and front drive shafts are fine. Front drive shafts were only replaced about 10 months ago I think
To post them would be about £8 or there abouts.
Obviously diff would be a lot more due to the weight, its a heavy bugger
