Removing Air Con (Guide Needed)
Old 10 May 2010, 02:25 PM
M4RKG
M4RKG's Avatar
Default Removing Air Con (Guide Needed)
I'm in need of some sort of "How To..." guide or instructions on removing the Air Con from my '97 WRX - Any assistance mucho appreciated! Mark
Old 10 May 2010, 03:59 PM
trogg
trogg's Avatar
What parts do you want to remove? All of it?
The condensor in front of the rad should be the easiest bit.
Is there still gas in the system? You will need to get a specialist to remove it before working on it.
Old 10 May 2010, 04:12 PM
rossmc
rossmc's Avatar
You can unofficially de-gass this yourself pretty easily even though it's technically illegal, but how would anyone know?
Just take the belt off the compressor, then remove the compressor, then remove the small rad in front of the big rad, then the rest of the pipes in the engine bay, i just left the unit on mine behind the dash in place
Old 10 May 2010, 04:45 PM
M4RKG
M4RKG's Avatar
Yea, there'll still be gas in the system as i've not touched it at all... I'll probs have to research it abit more before starting
Old 10 May 2010, 05:34 PM
trogg
trogg's Avatar
By posting about it on a public forum.
Old 10 May 2010, 08:06 PM
Chris8055
Chris8055's Avatar
Hi Mark..
I used to work at a Subaru Dealership and used to install the Aircon kits. Amazingly i have kept the fitting instructions. I am going to post them out to another chap on here so if you want pm me your address and ill post them to you to!!
You should be ok taking it off yourself.....just work backwards though the instructions!!
Chris
Old 10 May 2010, 09:12 PM
M4RKG
M4RKG's Avatar
That would be great mate, thanks very much!
I'll PM you now
Old 11 May 2010, 01:53 PM
allsop83
allsop83's Avatar
Does anybody want to scan this in and post it up for reading? I would be looking into removing mine also
Old 11 May 2010, 02:23 PM
rossmc
rossmc's Avatar
It's that easy you don't need instructions! Just pull it apart
33
29 August 2017 07:18 PM
Bazil_SW
24
21 September 2015 11:55 PM
taylor85
Wanted
13 September 2015 04:57 PM
Mellow Yellow !
3
10 September 2015 08:30 PM
Quick Reply: Removing Air Con (Guide Needed)
