Intercooler spray kit
I have available my intercooler spray kit, complete with Subaru washer bottle and genuine STI intercooler spray switch.
I assembled the kit myself and it worked very well with my old top mount intercooler to combat hot air on those summers days.
The kit will consist of the following items:
- Genuine Subaru washer bottle and motor
- Several meters of fluid hose and connectors (more than enough to get from the boot to the engine bay, i mounted the bottle in the boot against the rear seat).
- 2no micro-irrigation nossels to spray a fine mist (I cut a small hole in the rubber of the main scoop undertray and they squeezed in snuggly and sat over the intercool on each side)
- 12V Relay (mounted mine in the passenger footwell near the ecu)
- Several meters of cable for relay to pump
- Couple of meters heavy duty cable with inline fuse for live feed from battery
- Meter or so earth cable
- Couple of meters cable for switch live
- Section of cable for switch earth
- Two switches so you can choose your preference, a genuine STI intercooler spray switch and a push to make red switch.
It is dead easy to install, would suggest an hour or two most fitting time even for a novice.
Not after big money at all, will take less than I paid for each component, £25 posted to your door.
Paul
Paul
