Gearbox TY752VB3CA
you'll have to check under your bonnet for the gearbox code to see if it matches otherwise harvey could proberley sell you the diff aswell so it could work with any impreza from 92-00 if im correct
It will fit any Classic Scooby. As it is TY 752 best to fit it to M/Y 93-98. It should be fitted to a car that already has a 4.11 rear diff or you need the 4.11 diff I also have for sale (£150) as kindly pointed out by AK.
Check your VIN plate for your TY numbers and I can tell you what you have and how this compares. This is a low ratio box. ie fast acceleration but not a high top speed if that helps you.
We will install for £155 plus lubricant if required.
