Mahle "Drop-In" Pistons for EJ25 engine
I have a brand new and unused set of Mahle "PowerPak" drop-in forged pistons for an EJ257 (2.5Ltr) engine
They were purchased for a project build, but a change in plans means they're now up for sale.
The set is boxed and comes complete with the following items...
4 X Forged Pistons
4 X Complete Ring Sets
4 X Piston Pins
8 X Piston Pin Clips
Specs as follows..
Subaru 2.5L Turbo WRX STI, EJ25/257
Bore - 99.5
Stroke - 79.0
C/R - 8.5
Pin Diameter - 23mm
Compression Height - 30.7mm
Suitable for use with Standard Length rods.
They are a direct replacement for the standard weak, cast pistons, and will enable your 2.5 motor to be tuned safely over 400hp (with the correct supporting mods)
Cost me £400 + delivery
Looking for £325 including RM Special Delivery
Please PM me if you're interested
4 X Forged Pistons
4 X Piston Pins
Specs as follows..
Bore - 99.5
Stroke - 79.0
C/R - 8.5
Pin Diameter - 23mm
Sam Witwicky
17
13 November 2015 10:49 AM
Brzoza
02 October 2015 05:26 PM
