Performance Classic parts from hillclimb car
Please see car for sale thread on attached link
https://www.scoobynet.com/private-fo...print-car.html
Breaking car. Please message me if interested in any parts.
Simtec. Mapped for anti lag, launch and jacked open throttle. 6mths old. £650 SOLD
Turbo. Owen Developments Garret ball bearing. 450-500 bhp. Fitting kit inc. SOLD
GT Spec 3 bolt manifold and up pipe.Pics on my profile under subaru SOLD
3 Inch exhaust and decat down pipe. open neck.Pics on my profile under subaru £150sold
Front mount inc all pipes, hoses, mikalor clips and dump valve. £150sold
Injectors 740 with fitting kit. £200 SOLD
Walbro 255 motorsport fuel pump.SOLD
FSE fuel reg. black motorsport. £35
Carbon sti strut brace Pic on my profile under suabru. SOLD
Rota alloys as pictured on car. These were brand new 6 weeks ago and have only run at 2 events.
ET 48 PCD 5x100 and 5X114.Drilled for both. 17inch 8j. You will need to roll arches to get on. £400 collection only
sold
and if interested i've got 12 cut slicks (gone a bit hard but ideal for track days)£50 collection only.
I also have unused arch kit. Classic flare kit made by ABW for 4 dr. £140SOLD
Gearbox Quaife 5spd. All 5 gears and shafts are made by Quaife and includes Modena torque bias diff built in 754 casing. Comes with rear STI diff to keep matched ratios. £1500SOLD
Shell. Never driven in winter since import and in vgc. All sound deadening removed and resprayed inside in base coat and lacquer to match exterior.To include all panels (alloy bonnet) Doors, boot, bumpers, spoilers ,dash,lights, wishbones,hubs, etc etc. Will look like pics. FIA spec full weld in cage which extends throu to front strut tops.Rear spoiler etc. SOLD
Other parts available.
Suspension and brakes SOLD.
Seats and harnesses prov SOLD
Devon for pick up and poss post some items(not shell )
Please note If paying by paypal please use GIFT or add 4% if using goods to cover fees. Prices are cheap already can't afford to lose any more money. Thanks.
sold
Yes mate
Drivers:Sparco circuit
Passenger Sparco corsa
Both with harness and side mounts.
Were going on ebay........make me an offer!!!
Yes mate £65 Delivered.
Ecu is able to run 2 maps but only has jacked open throttle map on at present.
Anti lag is turned on via switch.
Anti lag is mapped properly and not just for bangs. You will find inlet would be under positive pressure at all times. Thats why i ran electric brake vacuum for servo.
Idealy you would need remap.
[QUOTE=Patsy450;9499991]pm'd you this morning. Just wondering if you got it?
Sorry about delay. PM sent.
Exhaust is complete system from Turbo back. Parts are cheap as i've pick up new car today. I'm racing at St Eval this weekend in new car if that helps.
Turbo is now sold.
Turbo is now sold.
great i take it that it comes with air flow sensor also i m not sure if it makes any difference but mines a 97 uk turbo v4 with the three socket conector and i might sound dumb but what is jacked open throttle ?? thanks john
Jacked throttle. My throttle butterfly is wound open 25% at tickover and then the ecu cuts ignition to hold tickover at 2000 rpm. Reduces lag and means i could run proper antilag. Makes the BAH BAH BAH noise you hear wrc cars make at startline. Down side is car is always on boost hence electric brake vacuum set up.
I wouldn't suggest running jacked throttle on a road car thou but brilliant for the track/hills.
