Carbon look PSI3 Data monitor SECS unit
Early version with lcd screen.
Unit and leads only. Currently in my MY00 top mount. But this style can be DIN mounted.
I put the carbon look sticker on there, so there is no labels for the controls. They are easy to remember, bit like changing gears. I can do some labels on white tape with black writing if needed. I can also include a copy of the dimensions of the newer style faceplate, which you can have made in 2mm acrylic for less than a fiver (eBay) and a paper copy of the instructions.
It does work fine, except it doesn't like to be too cold or too hot. If it is, it only makes the screen either show nothing, or jibberish. It's always fixed by unplugging the obd lead once or twice.
As you know, you can't get these anymore, its old, but it does the trick.
I want 60 quid delivered for it. Boxed and ready to post.
Sam Witwicky
17
13 November 2015 10:49 AM
