few classic bits to go
all parts are from a 1997 wrx
engine cam covers £25
Cam Pulleys x 4 £20 (SOLD)
Crank pulley mint £25
2x air con units £20 each have got rad and all pipework too.
Starter motor £25
powersteering pump £20
alternator £25
uncracked header tank with cap £15
exhaust manifold £20
knock sensor £10
Cam sensor £10
LAmbda sensor £25
and the other stuff below
Starter motor £25
alternator £25
knock sensor £10
Cam sensor £10
LAmbda sensor £25
is the manifold the bit on top with the throttle body?
Can you post it? Have you got a pic?
Would the cam sensor fit a UK turbo?
