RC Nitro rally SUBARU IMPREZA RACE CAR 4WD
Hi Guys
Well i brought this a couple of weeks ago and must admit its great fun, but i need the money for my deposit on my house so needs must.
This thing does 30/35 mph due to its 2 gears and is more than happy on tarmac, grass, mud, basically anything you can through at it!
The suspension can be altered and is currently set up high as I generally use on grass and tyres last an age.
Its a CEN racing Subaru impreza with the following spec:
Race proven 2.6cc engine with true ABC construction
Light weight 2 speed transmission with adjustable shifting
Reliable shaft drive (4wd)
Super hardened ring and pinions gears
Large stronger swing shafts
Sealed radio and battery box
Pivot ball suspension
Heaby duty anodized purple aluminum 2 piece chassis
Front and rear aluminum purple shock tower
Ball bearing included
Dual chamber tuned pipe with with high flow manifold
Super heavy duty adjustable rear toe-in rods
4 wheel braking
75cc fuel tanks with fuel filter
High performance teflon clutch shoes
Oil filled coil over shocks
Fully painted and decaled bodies
Fully assembled and ready to run
Many upgrades available
Fully adjustable
Impact CII radio
Additional
Supplied with all required radio equipment
Optional foam front bumper
Storage/transportation bag
Rechargeable glow plug warmer and mains charger
Glow plug spanner
2 or 3 glow plugs
Upgraged air filter
Upgraded tyres
Obviously it has a few scrapes as you'd imagine with a car that does 30/35 mph, these are mainly on the underside of the anodised base plate and the shell, there is also half of the top fin missing from the engine but this does not affect the running or cooling at all hence why I have never bothered to change it.
Its Worth well over £350
Im looking for £150 collected (Essex) , on collection I will show you how to start/run the car
postage can be arranged but I'll not be able to demonstrate the car
Any questions please ask or pm me.
If i have good interest i will Stick some photos up. If not its going on Ebay
thanks again
Darcy
4 wheel braking
Fully adjustable
Impact CII radio
Additional
Glow plug spanner
2 or 3 glow plugs
Upgraged air filter
Upgraded tyres
thanks again
Darcy
Danny0608
6
27 September 2015 02:16 PM
Danny0608
12 September 2015 02:59 PM
