Newage Hyperflow Wing Intake and K&N Filter
Location: STI V8 with 558bhp 580ft/lbs on V-Power (2.5 cdb)
SOLD
Newage Hyperflow monster cold air intake (sits in inner wing). Comes with Lateral Perfromance 'large' K&N filter (approx 6" dia, 7" long, not to be confused with smaller filters supplied with other kits).
Filter is mint and will be serviced (cleaned and re-oiled) using K&N gen products before posting. Intake kit is mint apart from a few scratchs around the inner wing area which can't be seen when fitted (they are in the wing). Intake pipe originaly supplied by TSL (cost over £220 new). Filter from Lateral.
SOLD
SOLD
So the filter sits just behind the fog area? Do they do fog cover things to direct air to the filter? Rather than having a big hole in the bumper, plus what's the kind of sound from this kit?
My fog cover is only off for the sake of the photo mate (so you can see the filter), I don't run with the cover off.
It sounds just the same as any other induction kit but not as loud inside the car as the filter is further away. It sounds just the same to people on the outside though (i.e. same K&N induction roar)
£160 posted.
£160 posted.
£160 posted with K&N
£140 posted with Hyperflow filter
the car gets wet,,, the filter will be fine as only spray will hit the filter and so little that it would to anything to the engine,,,,,,,, JUST DONT DRIVE THOUGH A RIVER THOUGH
The filter is quite well protected in the inner wing. I have K&N 'gortex' material sock that fits over the filter but never fitted it. Never had any problems in the rain.
As above watch what your doing going through fords but who drives through a ford flat out anyway .
