18g turbo, ph2 550's sti 3 heads
After i wrote my car off last week i've decided to sell the bits off it gonna sell a few bits at a time so easier to keep track.
its 1st come basis. All prices are plus postage, collection is fine (SR4 9DA) Any further info required contact me , Potelle@msn.com or 07957611567.
Payment by Paypal, cash or bank transfer.
Mark
Pre accident.
Post accident.
White line ALK £80 SOLD
White line Rear drop links £30 SOLD
Alcon Brakes & discs ds2500 pads no warping on discs. £500. ONO SOLD
Exeedy light weight Flywheel £100 ONO SOLD
Exeedy clutch £80 ONO SOLD
Carl Davey 20mm inlet spacers ideal for running front entry with v1 manifold. £50 ONO SOLD
PH2 550 injectors cleaned & flow tested 300miles ago by Lateral performance £230 SOLD
18g turbo supplied by Scoobyclinic £350 SOLD
Dash centre pod for pre facelift total one off. £100 ONO SOLD
Gizmo shift light settings changed by touching the shift light. £40 SOLD
Sebon carbon Reverse scoop 98-01 fitment £120 SOLD
carbon fibre side mirrors £100
Machined block to take 92.5mm pistons £300 SOLD
CP forged 92.5mm pistons £350 SOLD
X2 crankshafts centre thrust used £100
Williams racing forged con rods £150 SOLD
RCM metal 1.6mm head gaskets £90 SOLD
STI v3 heads ported,lapped, skimmed & shimmed £360 ONO SOLD
Engine Gasket kit £55 SOLD
Thats it for now more bit once most of these have gone.
Mark
Pre accident.
Post accident.
i do have the wheels x2 got curbed in the accident but nothing a re-furb wouldn't fit. The tyre had done roughly 1k prada spec 2's
Prodrive 7 18" Wheels with 215 35 Prads spec 2's done 1,000 miles. X2 curbed in accident but nothing a refurb wouldn.t sort £350. +postage SOLD
I'm holding the horns for a freind but if he decides not to have them they will be up for sale, along with the other 100 or so aftermarket bits. Just didn't put them up in one go as i'll never keep track of whats what.
Pulled the engine apart to see what damage there was as the belt got snapped, inlet cam wheel shattered & cam bent but that was it. I'm selling it all for £350, i have a buyer lined up but if it falls through i'll let you know.
Mark.
Mark.
Ing live Earth & tap into the rpm sensor wire on the ecu. You set it by touching it at the desired rpm led ilumination, all can be found here. The unit is tiny & can be mounted almost anywhere & is discrete.
http://www.gizzmoelectronics.com/Product_DSIIL.html
