APS High Volume Twin Port dump valve
Old 01 May 2011, 07:55 PM
TimH
Orange Club
TimH's Avatar
Default APS High Volume Twin Port dump valve
£60 delivered within the UK, including paypal fees
This is intended for those upgrading to an FMIC - especially an APS item - and looking to get an uprated recirculating DV to go with it. It does not have the necessary flange to replace the stock DV fitted to a TMIC, and you will need to reuse the flange from the stock DV to bolt to the APS, so the rubber tube that goes back to the intake system can be connected up.
You can read the info on the APS website here
This is the image from the APS site that portrays the item I have for sale
and here's the actual DV I have for sale - the slight marking on flange face is of no consequence as it's outside the rubber seal. The mounting bracket could do with a good rub down and repaint.
Old 01 May 2011, 08:58 PM
b3mwe
b3mwe's Avatar
sorry to sound thick where would i get the flange so i could fit it to my fmic for example
Old 01 May 2011, 09:07 PM
TimH
Orange Club
TimH's Avatar
On my setup, the DV bolted to the inlet manifold on the passenger side. The recirculating that used to go to the oem DV then mates directly to the APS, and there was a pipe supplied with my APS FMIC that then ran from the other connection to the TMIC pipe that runs to the throttle body...like this:
I've still got the pipe that runs to the takeoff on the FMIC pipework if it's any use to you (it's the one that runs back towards the bulkhead)
Old 01 May 2011, 09:55 PM
stevie turbo
stevie turbo's Avatar
cheeky bid would youtake £40
Old 01 May 2011, 10:01 PM
TimH
Orange Club
TimH's Avatar
Originally Posted by stevie turbo
cheeky bid would you take £40
YHPM
Old 01 May 2011, 10:20 PM
stevie turbo
will this be ok for newage bugeye
Old 01 May 2011, 10:28 PM
TimH
Orange Club
TimH's Avatar
Yes, assuming you have an FMIC, or are planning your own custom pipework for the TMIC
Old 02 May 2011, 11:14 PM
TimH
Orange Club
TimH's Avatar
SOLD
shorty87
19
22 December 2015 11:59 AM
buckerz69
29 September 2015 04:16 PM
speedrick
28 September 2015 01:06 PM
Quick Reply: APS High Volume Twin Port dump valve
