Wheels And Tyres For Sale This forum contains only wheels and tyres offered for sale by our members.
4 Goodyear Eagle asymmetric F1 For sale 235/40/18
Old 11 May 2011, 11:45 PM
sleazoid
sleazoid's Avatar
Default 4 Goodyear Eagle asymmetric F1 For sale 235/40/18
SOLD
Old 12 May 2011, 03:40 AM
sleazoid
sleazoid's Avatar
Bump, Pics updated
Old 13 May 2011, 07:39 PM
craigoscott
craigoscott's Avatar
damn, if these were 225/40 18s i would of had them!!
Old 14 May 2011, 12:28 AM
sleazoid
sleazoid's Avatar
235 40 18 would have more grip, it should be able to fit on 8j, 8.5j ,9j and even a 9.5.j wheels.
Old 14 May 2011, 12:04 PM
craigoscott
yeah they will fit on the wheels, but not sure about the arches. i know that 245's will rub on a newage... what did you have these fitted on?
Old 14 May 2011, 02:24 PM
sleazoid
sleazoid's Avatar
rubbing is depending on the width and offset from your wheels and the height of your suspension. For 235 tyres, if your wheels are 8j or 8.5j, Im 100% sure it will not rub at all with these tyres(except you have 20mm wheel spacer on the car). Im not sure about 9j, because I fitted these tyres on my 9.5j (33mm offset)wheels, it does rub sometimes. Thats the reason why I them took off instantly. But I lowered the car a lot, there's no gaps between the arches and wheels. Even now, Im using the 225 with the 9.5J, it also rub a bit but very few time because of the height. So if your wheels are 9.5j with 30+ offset, you have to set your car higher, at least 3 fingers' gap to fit with these tyres.
This is my own experience, hope that helps.
Old 14 May 2011, 03:09 PM
craigoscott
wat car tho, classic or newage?
Old 14 May 2011, 03:17 PM
sleazoid
sleazoid's Avatar
Newage, blobeye. btw, hawkeye sti would have wider rear arch. do you know your wheels' detail?
Old 14 May 2011, 03:22 PM
craigoscott
i have a 2005 type uk sti blobeye, which has the hawkeye setup.
I dont know the offset or width of my rims, they are team dynamics pro race 1.2's, but they were on the car when i bought it, i will take one off to have a look, but i wud assume probably 7.5" wide?
Old 14 May 2011, 03:29 PM
sleazoid
sleazoid's Avatar
7.5 should be fine, Im sure it wouldnt rub, the best fitment for 7.5 is 225. but you can check it see if it is 7.5j.
Old 14 May 2011, 03:34 PM
craigoscott
yeah the tyres on it now are 225 and they fit great, i will take a wheel off and have a look
Old 14 May 2011, 04:59 PM
fawor
BANNED
fawor's Avatar
td pro race 1.2 are 8j not 7.5
Old 14 May 2011, 05:12 PM
sleazoid
sleazoid's Avatar
yeah, I just checked. for 18 inch, minimum is 8j.
http://www.teamdynamicsracing.com/pr...Pro-race12.htm
His alloy should be 8j.
Abx
22
09 January 2016 05:42 PM
gazzawrx
Non Car Related Items For sale
13
17 October 2015 06:51 PM
leg200
07 October 2015 07:31 AM
Quick Reply: 4 Goodyear Eagle asymmetric F1 For sale 235/40/18
