Throwing in the towel,sti8 huge spec.
Really hard decission to make but i cant justify spending another 6k+ on the car to get it on the road again ,see my garage for spec,i will get a full detailed list up later tonight.
Some pics and contact number
07899025855
Please ask if there are any bits you see in the pics or in my garage full spec,as the full car is going.
07899025855
Ok some details,
The engine melted a piston last week,so hence the descission to break,the 2.3 will just need at worse case 1 new liner other 3 are ok as are the pistons,this has the 14mm head stud conversion and a billet 78mm crank,i will know more details on the condition of the engine soon as i get it home.
List
Front 330mm AP cp5555 calipers with pagid rs 29 pads little use on pads,complete with like new performance friction disks and braided lines,this kit would cost 3k ish new
£995 delivered
Rear brembo brakes 1 caliper has been drilled and tapped to next metric size due to snapped bolt,still perfectly useable,the calipers have just had a full re-furb in black with yellow brembo decals to match front AP's,these will come complete with pagid rs42 pads and genuine brembo disks £200
AST fully adj suspension,this is the remote canister kit which is over 3k new,in perfect working order,springs have the usual paint flaking on them but the kit is awesome,no knocks or bangs,complete with top mounts £995 delivered.
Wheels are rota gra's 7.5 x 18" ,5x100 ,in white,these are in as new condition,they have a used set of toyo r888 tyres on 225x50x18",all legal,£650 collected,can send on pallet at extra cost.
Oil cooler is a setrab one with pipes/fittings and sandwich plate £140 (dibs to banny) ?
Turbo is a garrett b/b GT35R 0.63 only done 300 running in miles £675 delivered.
Tial v-band 44mm wastegate,new diahpram and has 1 bar spring,also have a .7 bar spring £220 delivered
Prosport gauges x 2 oil pressure and oil temp these are new,complete with newage drivers side pillar pod all sensors etc £90 delivered.
Rear lights 125 delivered
Carbon S202 style wing £250 collection only this is an adj one.
Will keep adding to the list all night.
List
£995 delivered
Fuel set-up,walbro lift pump with braided -6 fittings on sender unit,swirl pot,bosch 044 all lines/fittings and covers/brackets as in pic,lines go to the metal pipes under the back seats £400 complete set up
Battery relocation kit,comes with chunky cable to bay,propper alloy battery box,earth lead,gold terminals and a fuse/trip switch (works fine but plastic is cracked) £75 delivered.
