Hawkeye Rear lights on a Bugeye - assistance required
Old 24 July 2011, 11:10 AM
Rob Day
Rob Day's Avatar
Default Hawkeye Rear lights on a Bugeye - assistance required
Hi Guys,
I recently bought some Hawkeye rear lights for Bugeye, and I was aware of the fitting issues due to the change in design on the lights on the blob/Hawk, however when I installed the lights I noticed that it WAS NOT the bottom curved area of the lights preventing them gong back flush. I was going to install them as far back as I could, and then draw around the light and gently cut the bumper away, but it appears that its not the bumper preventing them from going back flush, well not yet anyway, so what is?....
What are your views please, Im also on the lookout for a blob bumper in 01G Premium Silver for the future
So from a distance they look just "ok"
Still look ok'ish
Now you can see the obvious problem
and again
Not very clear pics, but you can see that the bottom lip of the light isnt causing any issues "yet", however the are fully bolted on so why isnt it going further back
Old 24 July 2011, 11:21 AM
95turbowagon
95turbowagon's Avatar
Have you put the different lights back to back to see if there is any difference, might spot something that is causing the problem.
Old 24 July 2011, 11:42 AM
DisoDisp
DisoDisp's Avatar
take the lights out, iirc theres a whole "tab" on the hawkeye lights thats different, remove it, and they should sit flush.
take a pic and post it up if needed, inside top somewhere.
Old 24 July 2011, 11:44 AM
Rob Day
Rob Day's Avatar
Yes but its quite difficult to see whats different, i'll have another look tonight with my steel ruler
Old 25 July 2011, 07:49 AM
Rob Day
Rob Day's Avatar
I attempted to have another look at this yesterday, but one of the nuts is playing hard to get!!!! Its decided to round off and stay put although it wasnt even out on tight!!!! grrrrrr.
Will investigate tonight!
Old 25 July 2011, 10:50 AM
Rice Rocket
Rice Rocket's Avatar
Mine was the same, I just removed the foam pad underneath the round part of the light and I was happy with that, did you get the hawkeye bulb loom too? aas thats different to the bugeye loom.
Ricey
Old 25 July 2011, 11:33 AM
martin850
martin850's Avatar
That's exactly how my blobeye lights sit Rob. Doubt you will get it any better but will keep an eye on this thread just incase.
Old 25 July 2011, 11:42 AM
Rob Day
Rob Day's Avatar
Ricey
Hi Buddy,
I removed the foam pad, but the light fitting is not being restricted from a flusher fit by the bumper which is odd. Its as though if I was to put on a Hawk/Blob bumper I would still have the same problem with the unit not going back properly. Im not afraid to cut out the rounder area in the bumper, but its currently not causing an issue, something else is
Hey Pal, I'll get round it im sure. I was looking at the make up of the integral part, and thouhgts of a grinder flashed past through my head . Im sure I can get them to sit back further, if you look at the last two pics at the top of this thread, although its hard to see, there is a gap of around 5+mm behind the bottom of the light to the bumper, so this area isnt proventing the light going back .
I'll get a good look at it this evening, im sure it will go further back somehow. If you remove the Foam insulation the fitting does go back a further 3-5mm, but this isnt the solution.
Watch this space, i'll get my grinder out
Rob
Old 01 August 2011, 09:31 PM
JonMc
JonMc's Avatar
I've had a look around this issue too and I get the impression that the blob/hawk bumper is a different design to cope with the additional depth of the lights. I may investigate further when I get the car back, but TBH it doesn't bother me.
Old 01 August 2011, 09:52 PM
Rob Day
Rob Day's Avatar
I havent had much time to look at it myself, but will get to the bottom of it. Rob
Old 07 August 2011, 03:12 PM
B4D HK
B4D HK's Avatar
that is about as good as it will get mate, I fitted a pair of blob lights to a bug a few months back (without changing the rear bumper to a blob one) and they looked the same as yours do
Old 08 August 2011, 12:12 PM
Tomwrx
Tomwrx's Avatar
im sure connor done this on his and his sit flush,
it does look very nice though,
would u not trim a bit of the plastic away at the bottom to help it to sit flush.
Old 08 August 2011, 12:49 PM
Rob Day
Rob Day's Avatar
I'll get there in the end bud. It looks ok and it grown on me, but as I know its just not quite right I will eventiually sort it out when I find some time.
Rob
The plastic on the lights isnt preventing them going flush, its the way the bumper is moulded. Im going to Scoobyspares later this week, so I may see if they have a blob bonnet in 01G
I think Connor chnaged the bumper over, and if memory serves me well he eventually doing a bug > Blob/hawk conversion anyway, so if he hasnt changed the bumper it would be a little silly.
61
11 January 2021 03:08 PM
ATWRX
88
01 February 2016 07:28 PM
7
14 December 2015 08:16 AM
20
22 October 2015 06:12 AM
MH-Racing
18
18 October 2015 04:49 PM
Quick Reply: Hawkeye Rear lights on a Bugeye - assistance required
