Bugeye Front Seats - Air Bag Light
Old 11 August 2011, 07:58 PM
Modifications
Modifications's Avatar
Default Bugeye Front Seats - Air Bag Light
Hi all
i have just changed the front seats but my old seats had the air bags in. I have fitted the resistor 3.3 on both sides but air bag light is on.
should have i disconnected the battery first becuase i didnt.
Whats the solution without taking the buld out. is it a simple ecu reset
regards
Colin
Old 11 August 2011, 08:02 PM
NINJA ED
NINJA ED's Avatar
Originally Posted by Modifications
Hi all
regards
Colin
Yeah m8 you need to disconnect battery for at least 20 mins you should be able to reset though
Old 11 August 2011, 08:10 PM
Modifications
ok i will try that :-) or get it reset if it doesnt work :-)
cheers buddy
Old 11 August 2011, 09:19 PM
95turbowagon
95turbowagon's Avatar
Hi all
regards
Colin
Can you point me in the direction of where you got your resistor, i've changed the seats in my bug for ones form a P1 and have the airbag light up.
Old 11 August 2011, 09:21 PM
madmerlin
madmerlin's Avatar
Maplins m8, couple of quid each..
Old 11 August 2011, 09:25 PM
madmerlin
madmerlin's Avatar
Hi all
regards
Colin
ecu reset never solved mine m8, the airbag light was on a diff. system, i managed to get a chap on here to sort it out for me, his name was sy, he has the black box to reset the thing.. dont know if he is still on here though.
Old 11 August 2011, 09:28 PM
JonMc
JonMc's Avatar
I took mine out and fitted the resistors, didn't disconnect the battery and the light went out fine. Same with my steering wheel and passenger airbag - if the resistors are making a good connection they should go straight out
Old 11 August 2011, 09:30 PM
madmerlin
madmerlin's Avatar
Hum, i was just unlucky then
Hope u have better luck than me m8
Old 11 August 2011, 09:32 PM
Modifications
95turbowagon
hi m8 i used 3 x 10k resistors and twisted them together to get the 3.3K. i have loads spare if you need some.
madmerlin
my cousin has the snap on jobby, so i will get it reset with that... i have used it loads of times with all the scoobs i have had
otherwise i need SY
Old 11 August 2011, 09:33 PM
Modifications
i soldered them
what resistors did you use m8, if you dont mind me asking ( 3.3k 0.6W )
Old 11 August 2011, 09:34 PM
JonMc
JonMc's Avatar
i soldered them
I would've thought that would be fine - I just pushed and taped mine in
Old 11 August 2011, 09:47 PM
Modifications
errmm strange i will get an ecu reset and see how it goes
Old 11 August 2011, 09:55 PM
daz1968
daz1968's Avatar
Just in case you have wrong resistors it is 3.3ohm not 3.3k resistors and nothing should need resetting once the airbag ecu sees 3.3 ohm it will extinguish the light, I did same in my wrx, but the resistors being thin wires needed the wires folding to increase dia before pushing in the plug to make a good connection, I would say either wrong resistors or bad connection in plug
Old 11 August 2011, 09:57 PM
JonMc
JonMc's Avatar
3.3ohm, 0.25w; I've given some to a couple of mates around here and they've not come back reporting any issues
Old 11 August 2011, 10:03 PM
Modifications
hi Daz
they have been soldered so its not bad connection
i have fitted 10k x 3 twisted together which should give 3.3K, do you have a part number? or a link?
Old 11 August 2011, 10:05 PM
Modifications
do you have any spare or a link we the buy them from
Old 11 August 2011, 10:07 PM
Modifications
http://www.ebay.co.uk/itm/10-x-3-3-O...-/120526047295
Old 11 August 2011, 10:08 PM
JonMc
JonMc's Avatar
I'll check the garage in the morning, but I should have a few left
hi Daz
Whilst that is correct it is still 1000x the resistance the ECU is expecting to see
Old 11 August 2011, 10:09 PM
Modifications
ok m8 cheers, dont mind paying
Old 11 August 2011, 10:10 PM
JonMc
JonMc's Avatar
They're the ones
Old 11 August 2011, 10:11 PM
Modifications
i will order these then m8, but thanks such much
JonMc
JonMc's Avatar
If I have some I'll get you to PM me your address and I'll post them out, not worth that much and the paypal fees would be more than the cost of a stamp
Old 11 August 2011, 10:13 PM
sc00by_d00
sc00by_d00's Avatar
Hi Mate,
I had the same problem as you in mine...i did post the issue and the "fix" in May....
Resolution to this problem is as follows:
2 x 3.3ohm 0.6w resistor from Maplin's for 21p each (one for each seat.)
Place one in each clip underneath the seat.....voila...airbag light now off...!! The resistors do need a good connection though.
Old 11 August 2011, 10:14 PM
leeturbo2000
leeturbo2000's Avatar
Can I jump on here please, my airbag light was on when I bought the car and he did say he changed the front seats....where does the resistor go? is it something to do with the yellow plug under the seats? cheers lads
Old 11 August 2011, 10:16 PM
JonMc
JonMc's Avatar
Yes, you need to bridge the terminals with 3.3ohm resistor and the light will operate as though the airbag is in-situ
Old 11 August 2011, 10:19 PM
Modifications
yes Lee it is m8,
i just ordered 10 off so got some spare if you need. i removed the plastic surrounds then soldered the wrong resistors to the base of the crimps lol. but got the correct ones coming now so if you need some let me know :-)
Thanks JonMC, ebay has some coming in the post just hope they work LOL
leeturbo2000
I love this forum! just saved me X pounds for a sparky , thank you I owe you a pint
Old 11 August 2011, 10:21 PM
leeturbo2000
yes Lee it is m8,
Thanks JonMC, ebay has som coming in the post just hope they work LOL
Cheers mate that would be great! I owe you a pint also
Old 11 August 2011, 10:22 PM
Modifications
sorry i did miss that i fitted 3.3K and not 3.3R shiiiiiiiiiiiiiiite
Old 11 August 2011, 10:24 PM
Modifications
when i get the correct ones fitted i will let you know how it went, if you still need 2 i will sort it no problem at all m8
Quick Reply: Bugeye Front Seats - Air Bag Light
