PSi3 data monitor S.E.C.S unit
Old 20 August 2011, 12:11 AM
joey_turbo
joey_turbo's Avatar
Default PSi3 data monitor S.E.C.S unit
This is an ECU Data Monitor for all Subaru's, that can communicate with the ECU, via the OBD port(96 onwards I believe), to show you the below:
BP Boost pressure BAR
IN Intake air temperature DEGREES C (this is not charge temperature)
CT Coolant temperature DEGREES C
ES Engine speed RPM
BV Battery VOLTS
TH Throttle position % (some cars have limited range E.G 5 to 85 %)
RS Road speed MPH or KMH (user selectable)
IA Ignition advance DEGREES BTDC
AF Air flow meter GRAMMES PER SECOND
LA Lambda sensor 1 LAMBDA RATIO
KC or KN Knock correction DEGREES (ignition offset)
ID Injector duration MILLISECONDS
EG Exhaust gas temperature DEGREES C (Software version 7 onwards only)
TC Time of day clock (Software version 4 onwards only)
EX Exhaust gas temperature (Software version 9 onwards only)
OT Oil temperature (Available with software version 8 onwards)
Requires external addition sensors to be fitted.
OP Oil pressure (Available with software version 8 onwards)
This is a version 14, so also does shift light and water injection. You just need to add a couple of wires into some ports on the back, will email instructions to the buyer.
It also records the peak functions of most things, Boost/Top Speed/Coolant Temp
All this data is real time and it can also be used to read Subaru fault codes, and reset the ECU.
Its DIN mounted, but easy to remove, and can be fitted into the top mount cubby hole on facelift classic's, and onwards models.
Its the newer style LCD screen, not VFD, so its just an inverted LCD. Looks good at night.
I'm after £180 delivered or swap/part ex for a version 7/8 STI top mount intercooler or a set of 17" alloys that clear brembos
Pics:
Resting on my top mounted bracket (not included):
How it can also be mounted (pod not included, this is a different PSi3):
Old 20 August 2011, 09:11 AM
Lagamorph
Lagamorph's Avatar
ill take it YHPM
Old 20 August 2011, 10:00 AM
stuart69
stuart69's Avatar
If it falls through,i will have it,either cash,or i have wheels here.
Old 20 August 2011, 02:19 PM
joey_turbo
joey_turbo's Avatar
Got a sale going through at the moment, but its worth mentioning I don't take paypal.
I got ripped of selling an iMac a while back, the barstewards took that and I lost out 400 quid also. Paypal didn't help one bit, so I refuse to put anymore money in paypals pocket.
So its cash/cheque or bank transfer. I'm good for it, my last couple of online sales have been with bank transfers, one also for another PSi3.
Old 20 August 2011, 03:34 PM
L.J.F
Instructing with fear
L.J.F's Avatar
I can vouch for this man, top fella Shame that this one was not for sale when i bought that other one Joe as this would look much better in my car
Old 20 August 2011, 03:57 PM
joey_turbo
joey_turbo's Avatar
The display and options on this one are slightly better. Its the one I've been using for a while.
Old 20 August 2011, 04:00 PM
stuart69
stuart69's Avatar
Let me know Joey if it dont go through.
Old 20 August 2011, 04:02 PM
joey_turbo
joey_turbo's Avatar
Ok, just waiting on Lagamorph to get back to me.
What wheels you got available then?
Old 20 August 2011, 05:12 PM
stuart69
stuart69's Avatar
gold 17 in sti...114.3 pcd
look in my profile,there on my spec c
They wont fit a classic Joey
Old 20 August 2011, 06:49 PM
Lagamorph
Lagamorph's Avatar
YHPM mate
Old 20 August 2011, 07:38 PM
seanscob
seanscob's Avatar
Do u have the pod?
Old 20 August 2011, 09:38 PM
joey_turbo
joey_turbo's Avatar
no
Old 21 August 2011, 09:31 AM
Lagamorph
Lagamorph's Avatar
Originally Posted by seanscob
Do u have the pod?
http://www.ebay.co.uk/itm/Subaru-Imp...d=257780102554
Old 21 August 2011, 10:38 AM
seanscob
seanscob's Avatar
Well spotted, cheers
Old 21 August 2011, 10:55 AM
joey_turbo
joey_turbo's Avatar
Now sold to Lagamorph.
seanscob, you might want to email them to ask what year thats off, it could be a newage one that wont fit a classic. If they are not sure, ask for the part numbers inside, I'll compare it with mine.
Old 21 August 2011, 10:58 AM
Lagamorph
Lagamorph's Avatar
the newage one isnt as wide so i would say it is classic but as joe said its worth checking.
Old 21 August 2011, 03:54 PM
seanscob
seanscob's Avatar
Cheers guys, have sent email
Sam Witwicky
17
13 November 2015 10:49 AM
T.K
10
02 October 2015 11:35 AM
Raptorman
01 October 2015 06:46 PM
Quick Reply: PSi3 data monitor S.E.C.S unit
