v5 jap sti 1999 braking
[FONT=Arial Black][COLOR=black]if anyone needs parts let me know, i live in birkenhead for pick up can post at buyers expense, small parts, large parts. You can arrange courier for post code - ch426rf, I work around manchester and i can get parts to Ayelsbury near london every monday. 07917405575 steve
cooler code is 792
new sti subaru spoiler v5 v6 mat black ready for paint £80
sti front strut brace £70
sti gear *** £5
sti v3 v4 back seats £30
Standad turbo back Suspension £40
sti exhaust £30
floor mats £15
Centre Console with switches £15
starter motor £30
alternator £30
downpipe £30
front 4 pots brakes disc and pads only been on for 600 miles £200
back 1 pots new discs and pads only been on for 600 miles £100
doors £30 each with windows
v5 v6 back bumper £40
subaru wing mirror r/l £30
uk turbo v5 gearbox faulty 4th synchro £50
uk turbo v5 gearbox faulty 2nd gear has gone £50
STI V5/V6 RED TOP ENGINE cylinder HEADS complete £300
sti momo steering wheel worn a bit and air bag £30
k@n aif k&n air filter and box £20
STI Yellow 440cc Injectors £60
subaru power steering rack £40
radiator 2 fans £30
air con @ radiator £30
HEADER TANK £20
abs pump £30
side lights £10 set
SAVER SPARE £20
SIDE SKIRTS £25
WASHER BOTTLE £10
AC aircon heater control £20
Carpet£20
PETROL FLAP £15
indicator £3
Dash £40
REAR LIGHT BOTTOM STRIP £10
LIGHTWEIGHT FLYWHEEL £70
sti FLYWHEEL£30
Wishbone l\r £20 steel
back BUMPER BEAM £30
REAR DIFF SUB FRAME £20
FRONT SUBFRAME £20
clutch master cylinder£20
anti roll bar back£20
Coolant Expansion Tank£20
EXHAUST MANIFOLD £50
timing belt tensioner roller £40
oil pump £30
pistons x 4 £50
water pump £30
engine block £50
ENGINE SUMP £20
ENGINE MOUNT £30
quarter panel £100 each
Door piled £50 each
Window/Door Rubber £25 each
Boot rubber £10
cam belt covers £20
Impreza Fule Tank@pump@neck@cap £30
cooler code is 792
sti gear *** £5
sti exhaust £30
floor mats £15
starter motor £30
alternator £30
downpipe £30
radiator 2 fans £30
HEADER TANK £20
abs pump £30
side lights £10 set
SAVER SPARE £20
SIDE SKIRTS £25
WASHER BOTTLE £10
Carpet£20
PETROL FLAP £15
indicator £3
Dash £40
sti FLYWHEEL£30
FRONT SUBFRAME £20
oil pump £30
pistons x 4 £50
water pump £30
engine block £50
ENGINE SUMP £20
ENGINE MOUNT £30
Door piled £50 each
Boot rubber £10
cam belt covers £20
Hi again mate...Dont suppose you also have the stereo brackets that fit into the dash,like these in my wanted thread but for an sti 5/6
https://www.scoobynet.com/wanted-18/...-brackets.html
Can you upload or send me a pic of the headlights? Cheers spivscooby@yahoo.co.uk
