FMIC & Standard recirc valve?
Old 28 September 2011, 10:26 AM
ac1867
ac1867's Avatar
Default FMIC & Standard recirc valve?
Hi All
I was just wondering if you can fit the OE recirc valve on to FMIC pipework? I have a forge VTA fitted at the mo, but want to swap it back before my map tweak. And was just wondering about fitment?
Also where would it recirc the air back to with no air box?
Andy
Old 28 September 2011, 11:30 AM
MarkC
MarkC's Avatar
Yes you can fit the recirc valve on fmic pipe work. I had to get this silicone hose to fit mine back to intake.
http://www.ebay.co.uk/itm/Silicon-Ho...#ht_1426wt_808
Old 28 September 2011, 11:52 AM
ac1867
ac1867's Avatar
Thanks for the response & the link.
Do you have a pic? I can't get my head around the fitment just because the OE version is held on by 2 bolts into the TMIC, and I can't figure out how to fix it on.
Andy
Old 28 September 2011, 12:11 PM
Blue by You
Blue by You's Avatar
Spaek to HArvey on here about these https://www.scoobynet.com/trader-ann...cessories.html
Old 28 September 2011, 12:36 PM
joz8968
joz8968's Avatar
ac1867, I have a surplus-to-requirements and unused correct pattern (diamond shaped) harvey DV adaptor for a MY99/00 OEM DV...
Old 28 September 2011, 02:45 PM
MarkC
MarkC's Avatar
I didn't realise your recirc is the bolt on type, as said above contact harvey
Old 28 September 2011, 02:59 PM
alcazar
alcazar's Avatar
Or joz8968 as above.
Old 30 September 2011, 01:07 PM
harvey
harvey's Avatar
If you don't get a sale out of this I will take your old one back Joz at a price fair to both of us.
Old 30 September 2011, 01:41 PM
joz8968
joz8968's Avatar
Question
Sure.
From memory was the brand new price something like £12.37 (with or without P&P) - can't recall....?
Just let me know what you're after for it back again lol...
Old 01 October 2011, 06:09 PM
barnshaw
barnshaw's Avatar
sorry to bump this thread, i currently have an APS DR725 FMIC with an APS recirculation valve, i am looking to going back to OEM , will i need to blank off the the hose from the FMIC to fit the standard OEM valve?
Old 01 October 2011, 07:02 PM
joz8968
joz8968's Avatar
You will need to remove your APS item, and reuse the FMIC pipe's port (+ a reducing silicone) to mount the OEM item onto said port - assuming, that is, the FMIC's hardpipe has a generic circular port (rather than something bespoke for its matching APS DV). But to do this you will need one of harvey's flange adaptors. You then need to use your exisitng pipe for the recirc. side of the OEM DV i.e. the pipe (probably quite long) that goes from the DV's recirc port to the turbo intake.
Old 01 October 2011, 08:11 PM
barnshaw
barnshaw's Avatar
thanks joz, that makes sense and confirms what i thought, cheers for the reply
Old 01 October 2011, 08:32 PM
joz8968
joz8968's Avatar
Or go DV-less?!...
The VF35 (UK STi) or VF37 (JDM STi T.S.) are fine to run DVless (you'd get a great impeller stall noise lol on throttle lifts/gearchanges).
...In which case a blanking bung will need to replace the APS DV (plus you'd need to bung the turbo intake recirc port and blank the vac line to the I.M.).
If you go this route, then I have couple of unused, great quality ally bungs which I don't need - 34mm O.D. GGR one and a 'ribbed' 38mm O.D. ASH one.
Old 01 October 2011, 08:57 PM
barnshaw
barnshaw's Avatar
hi joz i am currently running an APS SR40 turbo so i could go this route, would it require remap after or could it go without.
Old 02 October 2011, 10:12 AM
joz8968
joz8968's Avatar
I would think it wouldn't do harm as such... But if it were me, then I'd get the mapper to take a look at the map to make sure it's all okay
At the very most, a tweak of a few of the map's cels would be required, I expect. Just depends on how much your mapper would charge for said tweak? (Usually c.£150+)....
Old 02 October 2011, 05:52 PM
harvey
harvey's Avatar
Stalling any turbo is bad news and on any roller bearing turbo I expect it will reduce service life noticably. This is why Subaru and most other automotive manufacturers fit a pressure release sytem or dump valve as standard.
Old 02 October 2011, 09:08 PM
joz8968
joz8968's Avatar
Harvey, can you PM me your delivery address please (for me to be able to send you that adaptor back)...?
Old 03 October 2011, 11:58 AM
alex_00s
alex_00s's Avatar
I'm running a TD05 18G without DV and love the sound it makes!
Old 03 October 2011, 05:33 PM
harvey
harvey's Avatar
Yes Alex it will sound very nice going through tunnels especially but it won't improve performance and it can only shorten turbo life although yours is a sleeve bearing turbo and very robust so not as bad as the effect on a ballbearing turbo.
If you want to talk about a set of tubular headers give me a ring.
Old 04 October 2011, 10:06 AM
allsop83
allsop83's Avatar
I thought the same- I wouldn't delete the BOV on any VF series Turbo....
Can someone confirm this??
Old 06 October 2011, 01:09 AM
Pramas
Pramas's Avatar
personally if harvey says u better off with a dv, then go with a dv, hes a font of knowledge and wont give u bad advice
shorty87
19
22 December 2015 11:59 AM
buckerz69
29 September 2015 04:16 PM
shorty87
Wheels And Tyres For Sale
29 September 2015 02:18 PM
speedrick
28 September 2015 01:06 PM
Quick Reply: FMIC & Standard recirc valve?
