Hex Socket Stainless Steel Bolt Kits 28 quid delivered!!!!
Ok fellas.
Over 100 pieces, A2 grade stainless steel hex socket bolt kits.........or steel 'stealth style' black bolts.
This is a group buy and I need a minimum of 5 people.
Price for SN users is 28 pounds including delivery to the UK (this is a discount to my usual eBay prices)
Bolts and washers will be sent from my home in Thailand and take around 5-10 days to arrive.
These look the absolute business compared with the standard ones!, I've had them on my car for over six months now......
I'm sure this is the cheapest bolt set ever on Scoobynet.
In the kit you get bolts, nuts and washers for:
radiator support brackets
top mount intercooler support brackets
header tank attachment to inlet manifold
intake pipe attachment to inlet manifold
plastic air feed pipe attachment
metal breather pipe attachment
boost solenoid assembly
throttle cable bracket
fuel cut off switch
wings
earth connection on left and right of suspension
ht lead brackets
dipstick bracket
power steering fluid tank
power steering, alternator and a/c belt covers
header tank
washer bottle
fuse box
coil pack
vents on underside of bonnet
power steering coolant bracket
suspension and strut brace
screws for sidelights
Not included are the bolts to attach the bonnet and the bolts, timing belt cover bolts and the intake manifold to cylinder block/fuel rail bolts, these can be include for extra cost (the timing belt cover bolts are quite expensive as they're an unusual size)
Paypal payments are made to sutthasri@hotmail.com
Please note I tested this kit on my V3 STI, however it should fit all EJ20 engines.
Any questions, feel free to PM me!!
fuel cut off switch
wings
ht lead brackets
dipstick bracket
header tank
washer bottle
fuse box
coil pack
Just to add:
I will email a fitting guide with photos for every purchase.
The bolts come in bags according to size.
Bolts are the same size as originals, I measured all of the bolts on my engine.
I will mark the parcel as 'xmas or birthday gift' so u can avoid any import taxes.
