Hyperflow FMIC
Hyperflow FMIC
Bought this intercooler about a month back, but, by wierd twist of circumstance, I have ended up with a brand new kit at the same time! This has meant I have been able to put all the bits together to make a very near complete kit.
It is an Hyperflow descreet kit to suit bug, blob and hawk eye imprezas. as sold by various places online. It is extrememly good quality kit.
The core is black and has very few bent fins, in excellent condition for a used core. The pipework is anodised blue, and although it has a few scratchs it is again in great condition.
The kit comes with:
Overflow bottle in black.
Short ram induction cone and maf housing (cone has been cleaned and re-oiled with the correct cleaner, but is still quite dirty.) Maf housing is brand new and un-used.
10 x blue Smaco silicon joiners.
O.E. bov adaptor in anodised blue.
Alloy oil filler cap relocation tube. (with cap)
Lightweight bumper support bar in black.
Breather hose / fuel line / t-piece / zip ties / mounting bracket.
New sealed jubille clip set.
Full instructions.
Couple of bits worth mentioning, the pipe that u turns out of the intercooler on the nearside has been cut in the past, possibly to ease fitting, still works and fits perfectly, just adds one silicon join to the sysytem. Also the pipe that runs through the gap on the offside wing has had the mounting bracket cut, this is not essential for fitting as the pipe holds firm anyway.
All you would need to complete the kits would be a few nuts and bolts. Collection from Stoke on Trent, item can be packed and couriered at buyers expense.
£800 ono
Oh and also, unbranded indution cone (dual type) This will fit with the K+N typhoon if you want a bigger cone.
£20 Delivered.
The kit comes with:
Full instructions.
£800 ono
£20 Delivered.
Yes it is comapitble with some, I am using the hyperflow CAIK with mine. The problem with the k+n is that it uses the rear of the two holes through the inner wing, that is the same as the FMIC uses in this case. It would depend on which FMIC kit you are using.
This isn`t the best of pictures but it`ll give you the jist, if you can source a Hyperflow CAIK, it runs directly from the maf out of the front hole in the wing.
Uploaded with ImageShack.us
Ok, slight plan change, could do with getting this gone now so it`s on e-bay:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=180798293742
£500 will take this home.
