NGK Iridium IX Spark plugs @ JP4mance.co.uk
NGK Iridium IX spark plugs from £32.35 inc vat & FREE uk delivery.
We carry various plugs in 3 heat ranges as follows:
Heat grade 6 (stock)
Heat grade 7 (1 stage cooler for tuned engines)
Heat grade 8 (2 stages cooler for highly tuned engines)
I run these in my own TSL333 '53 STI and rate them over the stock plugs personally. I get great economy and a much smoother idle.
Subaru Impreza 2.0 Turbo (1992-00) - NGK Iridium IX spark plugs (HEAT 7)
Subaru Impreza 2.0 Turbo (1992-00) - NGK Iridium IX spark plugs (HEAT 8)
Subaru Impreza 2.0 Turbo (2001-06) - NGK Iridium IX spark plugs (HEAT 7)
Subaru Impreza 2.0 Turbo (2001-2006) - NGK Iridium IX spark plugs (HEAT 8)
Subaru Impreza 2.5 Turbo (2007) - NGK Iridium IX Spark Plugs (HEAT 7)
Subaru Impreza 2.5 Turbo (2007) - NGK Laser Iridium Spark Plugs (HEAT 6)
Subaru Impreza 2.5 Turbo (2008+) - NGK Iridium IX Spark Plugs (HEAT 7)
Subaru Impreza 2.5 Turbo (2008+) - NGK Laser Iridium Spark Plugs (HEAT 6)
"These are the OEM spark plugs as supplied and fitted to the car from Subaru."?
Hi, which plugs to replace a set of NGK PFR7Bs on a 2002 STI with ~350bhp?
http://www.jp4mance.co.uk/products/1/Subaru/_/427/
Thanks, Mark
Thanks, Mark
Thanks, Mark
Thanks, Mark
Yes, those NGK iridium IX plugs in the link replace PFR7B's (NGK Platinum, heat 7)
Light brown / Grey
This is a good indication that your engine is fueling well so stick to heat grade 7 if that is what you're running
White deposits / blistered surface
This could be an indication that your spark plugs are too warm, so go for a grade 8 (one stage cooler). Other things to rule out in this case would be:
• Over advanced ignition timing
• Too lean fuel mixture
• Blocked injectors
• Insufficient cooling
• Excessive deposits in combustion chamber
• Spark plug too warm
Excess black carbon deposits
This is an indication that the plugs you run are too cold. Unlikely in this case to be honest, but if you switch to heat 8 and this happens, then you know what to look out for. Other causes of carbon build up:
• Too rich fuel mixture
• Excessive use of choke
• Prolonged low speed driving or idle
• Blocked air filter
• Spark plug too cold
Hope this helps.
Prices are inclusive of vat and delivery to UK postcodes. The price is for a set of 4 plugs. As much as i'd love to sell you a set of NGK plugs for £129, i don't think i'd stay in business for very long
