PSI3 data monitor
Old 28 January 2012, 11:11 PM
L.J.F
Instructing with fear
L.J.F's Avatar
Default PSI3 data monitor
If you don't know what this is, its a Data Monitor for all Subaru's, that can communicate with the ECU, via the OBD port, to show you the below:
No display (blank area)
BP Boost pressure BAR
IN Intake air temperature DEGREES C (this is not charge temperature)
CT Coolant temperature DEGREES C
ES Engine speed RPM
BV Battery VOLTS
TH Throttle position % (some cars have limited range E.G 5 to 85 %)
RS Road speed MPH or KMH (user selectable)
IA Ignition advance DEGREES BTDC
AF Air flow meter GRAMMES PER SECOND
LA Lambda sensor 1 LAMBDA RATIO
KC or KN Knock correction DEGREES (ignition offset)
ID Injector duration MILLISECONDS
EG Exhaust gas temperature DEGREES C (Software version 7 onwards only)
TC Time of day clock (Software version 4 onwards only)
EX Exhaust gas temperature (Software version 9 onwards only)
OT Oil temperature (Available with software version 8 onwards)
Requires external addition sensors to be fitted.
OP Oil pressure (Available with software version 8 onwards)
All this data is real time and it can also be used to read Subaru fault codes, and reset the ECU.
Its an LCD screen version, the screen works fine the whole time I have used it.
The firm ceased trading a few yeards back, it was a project by a Subaru enthusiast, and he sold loads of units. Its a shame these are hard to come by now.
will add pic tomorrow
£150+ postage
This is the link from the ad i bought it from- https://www.scoobynet.com/subaru-par...-c-s-unit.html
Old 29 January 2012, 08:45 AM
LewisL
LewisL's Avatar
PM'd
Old 29 January 2012, 10:30 AM
L.J.F
L.J.F's Avatar
SOLD
Old 29 January 2012, 11:47 PM
joey_turbo
joey_turbo's Avatar
These never hang around long. Top piece of kit.
Sam Witwicky
17
13 November 2015 10:49 AM
T.K
10
02 October 2015 11:35 AM
Nick_Cat
Computer & Technology Related
26 September 2015 08:00 AM
Mister:E
24 September 2015 01:37 PM
STI5300
08 September 2015 09:19 AM
Quick Reply: PSI3 data monitor
