Bc Racing Br series needs rebuilding - Anyone recommend somewhere
One of my bc racing br series struts is leaking oil and giving hardly any shock absorption so can anyone recommend a garage that rebuilds them via posting them off? also its just the one that needs rebuilding.
I think apex can do them for you, but not sure. Best get both rears done together though.
Either that or buy a replacement damper body-that will keep you on the road as it would be a straight swap over.
I might contact Apex for guidance regarding my BC coilover issue. Spring tension me thinks.
Is this Apex in Bradford?
fpan - unsure of mileage as they were fitted already to car when i bought it, but reckon around 2-2.5 years. then there was also the 'top 17mm nut' thread was damaged, 'Upper Spring Platform with Bearing' seals had gone.
I have to say though Apex are the best car parts company I have ever dealt with been very helpful with advice/info, superfast in posting part out and even didnt charge me for some extra parts just so I had eveything I needed to do the job.
http://www.apexperformance.co.uk/catalog/default.php
Kakumei - mine was leaking, there was oil all over the shock - see pic below, it was scoobyvince with spring tension prob.
Brzoza
02 October 2015 05:26 PM
