intercooler fitting?
Old 03 February 2012, 09:54 PM
kemzo
kemzo's Avatar
Default intercooler fitting?
hi I've just bought a p1 inter-cooler as an upgrade to my standard terzo my98 one, as i went to fit it everything fitted ok direct bolt on except for were the dump valve bolts on to inter-cooler it wouldn't fid due to a what ;looks like water pipe?
here's a pic with original inter-cooler back on Ive highlighted were the pipe is and were the new dump valve would of went:
http://i1097.photobucket.com/albums/...o/IMG_0566.jpg
is there anything i can do or am i stuck thanks will
Old 03 February 2012, 10:42 PM
Dutch Scooby lover
Dutch Scooby lover's Avatar
It won't fit mate without a different Dumpvalve.
The P1 (99/2000) models use a DV bolted directly to the Intercooler, the 98 uses a hose mounted DV.
Also, on a 98 the idle valve (circled white-ish plastic bit) is right in front of the mounting holes for the DV, as the P1/99/2000 models have the valve on the other side (left from throttle body when seen from the front).
You could fab up a blanking plate, to blank of the hole in the Intercooler that the DV mounts to, and keep your My98 hose/DV valve. (this would be the most simple option)
Old 03 February 2012, 10:52 PM
winston69
winston69's Avatar
If you have no luck I might buy the intercooler from you as I have a MY99 and I only live up the road...
Old 22 March 2012, 03:26 PM
kemzo
kemzo's Avatar
any 1 know of an intercooler that will fit and act as an upgrade also still have this p1 intercooler gathering dust lol
Old 22 March 2012, 06:17 PM
midnight
midnight's Avatar
You have a couple of options open to you :1. you can sell it and buy a sti intercooler of a 97/98 car which will fit straight on. 2. you can buy an adaptor plate that just bolts over the holes and has a angled exit to the right which will allow you to use your existing hoses.Whichever option you decide try and get the Y pipe set up with the intercooler,as this allows a smoother flow of air over the restrictive oe unit.
Old 22 March 2012, 06:35 PM
alcazar
alcazar's Avatar
I did this upgrade, I bought a right-angled adaptor that allowed me to use my 98 dumpvalve with the new i/c.
Paid nearly as much for the adaptor as I did for the V6 intercooler, LOL
Old 22 March 2012, 07:54 PM
kemzo
kemzo's Avatar
cheers well the p1 intercooler came with an oe dump valve which i was hoping to use as ive got a bailys on atm so need rid off that if i get an adapter id need a new dump valve(original one)?? also where are adapters availible from ? confusing lol cheers in advance
Old 23 March 2012, 11:55 AM
alcazar
alcazar's Avatar
Bottom of this page, I THINK, http://www.scoobyclinic.com/products_dumpvalves.htm
But give them a call and ask.
BTW: Google is your friend
Old 23 March 2012, 01:51 PM
midnight
midnight's Avatar
Grahame Goode is the place your looking for try them on 01162452321,they do it as a kit .You wont find it on there website as it has changed but they definetley use to sell them.
Old 23 March 2012, 07:51 PM
kemzo
kemzo's Avatar
thanks guys might just buy another intercooler and sell this p1 one, seen a version 3/4 sti one for sale for £40 is that any good? sorry for all the questions btw all help much appreiciated
Old 23 March 2012, 09:07 PM
midnight
midnight's Avatar
Its no different to the P1 intercooler bar there is a elbow that comes out on the right which connects to your recirc/dump valve
Old 23 March 2012, 09:25 PM
Ginge !
Ginge !'s Avatar
I got a v3 sti inter cooler doing nothing if your local
Old 23 March 2012, 11:26 PM
alcazar
alcazar's Avatar
Hang on, I thought the V5/6 intercoolers were better? The P1 is like those.
Old 24 March 2012, 12:06 AM
midnight
midnight's Avatar
V5/6 intercoolers are the same as a P1 no different,version 3/4 intercooler is the same bar no recirc valve bolted on.
version 3/4 intercooler :
http://www.ebay.co.uk/itm/subaru-sti...item3f1544c256
Version 5/6 intercooler :
http://www.ebay.co.uk/itm/Subaru-Imp...item3373724034
61
11 January 2021 03:08 PM
7
14 December 2015 08:16 AM
Reshard1977
9
22 September 2015 11:48 PM
TypeR99
13 September 2015 01:25 PM
blackv5
13 September 2015 12:37 PM
Quick Reply: intercooler fitting?
