Mint v5 type R breaking
98/99 ver5 type R impreza
I bought this type R less than a year ago with every intention of putting it back on the road.. Now the car is running and almost compleat I just don't have the funds to compleat her.
I'm not working currently so by the time I get gauges new ecu geo set up and mapped I'm gonna be another grand or 2 down and that's without thinking about getting insured.
Here is the thread to when I bought the car last year:
https://www.scoobynet.com/full-cars-...plete-car.html
Some photos will add more soon.
Really need the engine and shell to be sold before I start stripping for parts
Parts ....
V5 long engine less turbo & injectors.....
Bought from scoobyspares approx six months ago, milage at 74000k / 46000 miles
With new short motor fitted 20000. The engine has had a overhaul of cylinder
Heads inc clean, pressure test, reseat valves, reface, remove and check piston rings, check
Clearances, new gaskets.
Since then I have put new gates aux belts on and also put new inlet manifold gaskets in place
As well as spraying the inlet manifold..
All work and milage can be confirmed with scott@scoobyspares and I also have the paperwork to prove this totalling £ 1600 approx for work carried out this is not including the parts I've added.
Can be seen running.
Looking for £sold
Shell ... £sold
V3/4 short ratio dccd gearbox + r180 rear diff .. £500
Vf28 no play no smoke no cracks ... £sold
440 phase2 injectors ... £sold
STI carbon strut brace ... £sold
Blitz nur spec r ( back box & centre section ) ... £sold
Subaru 4 pot fronts painted black £sold
Subaru 2 pot rears painted black £sold
Type r carpet £45
Open mouth decat down pipe 3" to 2.5 at bottom .. £65
Crystle front and side lights ... £90
V5 type r dccd cluster / clocks .. £sold
J2 ecu ... £100
V5 lambda sensor .... £sold
Exedy organic clutch ( covered 2k ) ..... £65
Braided brake line .... £25
Demon Motorsport red rad hoses ... £30
Ic spray set up including switches ..... £sold
Parts ....
Looking for £sold
Shell ... £sold
Type r carpet £45
J2 ecu ... £100
Last edited by crazyspeedfreakz; 18 May 2012 at 07:03 AM. Reason: add to description
I could do a price for the a full shell and full interior.
price for front and rears,and price for fronts only please mate.
