Car Parts For Sale This forum contains car parts offered for sale by our Authorised Advertisers ONLY.
REVERSE INLET ALTERNATOR TENSIONING BRACKETS
Old 10 April 2012, 04:16 PM
Default REVERSE INLET ALTERNATOR TENSIONING BRACKETS
ok after doing a few reverse inlets iv decided to design and have cut a few brackets to make it a more of a easy and bolt on job with these brackets you get the full alternator tension you need which is one of the bigger jobs on this conversion
the brackets are designed to fit both classic and newage cars up to hawkeye models iv not tested on the hatch onwards ufortunatly
also the kit is designed to fit both types of alternator/air con mounting brackets that you will use with the conversion this braket it self needs slightly modding to flip the alternator over jsut simply cutting the air con mounting top lugs off and then 5 mm of the meat off the 2 mounting point holes aswell to allow clearence of the brackets to the belt this will take around 10 mins with a trusty grinder and file
after this mod to the alternator bracket this brackets then simply bolt to that some washers will be required for spacing
this brackets not only give you a very good tension system as there is a 2 way adjustment on both the alternator and the middle adjustment bar also this in turn gives great tension adjustment and loweres the belt in the center to allow plenty room where your intercooler pipe will sit so giving plenty room to do so
brackets are in raw finish now but will be powder coated gloss black before sent out we can do 3 other colours also red/white/blue at a small cost extra
only other items you will need it a idle wheel we tend to use a std item off a impreza timing belt which works a treat and of cause a longer alternator belt aswell
2x brackets in black/blue/red/white £40pair
pm me if needed
here a set up we have recent finished brackets are in red so you can see them cleary
Old 10 April 2012, 06:41 PM
trails
trails's Avatar
Matty could you use one of these to mount a smaller alternator?
Old 10 April 2012, 07:02 PM
No mate I think there is only a Carl davey breaker out ther for the smaller alternators mate these are only the tension brackets mate not the actual mount mate
Old 25 April 2012, 11:40 AM
pm's replied
Old 08 May 2012, 10:02 AM
pm's replied
Old 16 May 2012, 11:18 AM
pm's replied
Old 17 May 2012, 09:46 AM
Gotheridge2007
Gotheridge2007's Avatar
Hi did you have to put a wedge behind the TB to point it down incase if fouling the bonnet
thanks
Old 17 May 2012, 09:53 AM
what version you running??pm me if needed
Old 17 May 2012, 10:10 AM
Gotheridge2007
You have PM
Old 28 May 2012, 04:54 PM
pm replied get some pics up when there fitted
all pm's repleid
Old 05 June 2012, 07:48 PM
pm's replied
Old 22 June 2012, 11:54 PM
Pm's replied
Old 01 July 2012, 08:25 PM
pm's replied
Old 16 July 2012, 09:52 AM
pm's replied
Old 29 July 2012, 08:58 PM
pm's replied
Old 09 August 2012, 09:39 AM
pm's replied
Old 10 August 2012, 10:04 PM
spackyscooby
spackyscooby's Avatar
Thanks for the quick responce! I sure am excited to get my set:-)
Old 10 August 2012, 10:50 PM
Yes thank you there already on route you have to post pics when fitted
Old 18 August 2012, 09:31 PM
banzai2009
banzai2009's Avatar
Tried ringing and textin with no reply Matty??
Please send me a text on 07926971608 thanks
Old 19 August 2012, 02:41 PM
Sorry fella we been attending rally day all week end were bak to normal now il send a tx now as just on route to get another breaker cheer
All pm's replied and new batch of brackets just done
Old 20 August 2012, 05:01 PM
spackyscooby
I recieved my set the other day and I must say they do look nice! I will post a pict once they are on
Old 20 August 2012, 05:34 PM
Excellent they got there quick first set in the USA post pics when you can cheers
Old 23 August 2012, 10:57 AM
pm's replied..more bracekts back in stock
Old 23 August 2012, 02:20 PM
banzai2009
banzai2009's Avatar
Hi mate have u got any of these left? And can you do it any cheaper if so I'll take a set cheers
Old 23 August 2012, 02:41 PM
we have new stock but sorry the price is the price on these lazer cutting and coating isnt cheap im afraid sorry
Old 31 August 2012, 03:17 PM
Ol die to the popularity of these we have had a new large batch made up now to keep up
With demand due to the large quantity we have had its means the price forte lazer cutting and materials have come down so we can pass that on to you guys and now to the brackets at £40 the pair coated in a colour to suit you we can also offer pre modded and coated alternator brackets for that full bolt on package also we can supply a new puly wheel the same as pictured for £19 new of needed
All pm's replied
Old 21 September 2012, 11:11 AM
pm's replied
Old 10 October 2012, 01:02 PM
tweaks
tweaks's Avatar
Mine turned up today Matt
Tim
Old 26 October 2012, 09:29 PM
pm's replied
Old 25 November 2012, 11:42 AM
all pm's replied
Quick Reply: REVERSE INLET ALTERNATOR TENSIONING BRACKETS
