Downpipes (Sports cat & de-cat) + Harvey smith up-pipe
Hello all!
I have 2 newage downpipes (might fit classic, you will have to check) and Harvey Smith up-pipe for sale. I can post everything, but would prefer pick up from Edmonton/Tottenham, London.
Check where your lambda sensor is before buying, i made the mistake of not doing this and ended up with sensor hole at the wrong end! LOL but, after a remap it wasnt need anyway, so blocked it off.
Cobra Sport 3" Bell mouthed downpipe (2.5" at flange and lambda sensor whole at the bottom) bought in Dec, for £250 (i have the receipt) Which has had about 4k miles use. I'm after £125+£15 for next day delivery.
3" bell mouthed de-cat downpipe (was told it is 2.5" at the flange, but when i measured, it looked like 2.25", that could be my measuring though!) came off a blobeye, comes with lambda sensor, which is at the top. I'm looking for £60+£15 for next day delivery.
Wrapped Harvey up-pipe, dont need to say much about this, we all know how good these are! I'm after £65+£5 next day delivery.
Last edited by Reshard1977; 27 April 2012 at 11:42 AM. Reason: took a photo out, which was wrong.
Single scroll. The sports cat downpipe was fitted with my VF34 and the full decaat was bought to replace the sports cat downpipe and has the same fittings bar the lambda sensor.
Hi, yes will fir your 04 WRX, but its best to check which end your lambda sensor is (if your mappers hasn't mapped it out). If its near the turbo side, its a straight fit. If your mapper has mapped out the lambda sensor like mine did, all you need to do is just blank off the hole. I used a sump plug to blank it off! Perfect fit! LOL
Hi, its at the mechanics, I'll check the bore tomorrow. I bought the harvey up-pipe (known to increase spool) from a trusted member on here, it was already wrapped, I think its a slip joint, but not sure. I'll have a closer look tomorrow and let you know.
fatboy_coach
15
18 June 2016 03:48 PM
