Provisionally sold...But a photo in case the sale falls through.
There is a very light mark on one of the gauges(cant be seen when on) and there is a bit of outer insualtion missing from one of the sensor( only the insulation not the internal wire, happened whilst removing from the car) I could of used a small bit of insulation tape around it but dont want to hide nothing so it can be seen.
Gaz\Jay sorry to thread hijack, the defi's do they come in white or amber? Im after red (to match the speedo) will amber have to do?
H,
The BF(black face) series of Defi`s were available in White, Blue and Amber(Which is a perfect match for the JDM cluster) and you can adjust the brightness on the control unit too, Very simaler to the dimming on the car. You cant get these ones new anymore as they have been discontinued, They have been replaced with a range called Defi Advance if your buying new, If your looking for a used set try over on NASOIC as they are getting really hard to get hold of over here now in amber
These are mine and if you wand a Wideband AFR this is the best match for the rest of it, It`s an Innovate LC-1.
