garage clear out mainly classic
Old 22 July 2012, 01:25 PM
dbay
dbay's Avatar
Default garage clear out mainly classic
as you can see i have loads of junk cluttering up my garage (mainly classic). to make room it ALL HAS TO GO so if there any thing you want just ask.
Version 8 SCDB sold
TY754VN1AA 5sp 3rd & 4th broken (ideal for ppg build) £50
Classic engine cradle £10
Classic front under brace anodised blue £20
Anti roll bar front std £5
Front bottom arms pair (steel) £10
Front near side ABS hub £10
Front offside ABS hub £10
Rear nearside ABS hub £10
Version 5 power steering rack sold
Version 5 inlet manifold sold
Version 2 inlet manifold £5
Version 2 cylinder heads t2000 (pair complete) £30
Pair of Version 3/4 cylinder heads (bare) £30
Aftermarket top mount (slight damage on one side) sold
Nearside rear door – black £10
Nearside front door – black £10
Nearside front door –white £10
Nearside rear door – white £10
Offside front door –white £10
Pre face lift alloy bonnet £10
Pre face lift rear bumper £5
Pre face lift front bumper – modified £20
2 sets of side skirts – black £10 a set
pair of rubber spats/mud guard hangers – rear £10
2 sets of timing belt covers £10 a set
2 sets of cam wheels £10 a set
2 sets of STD engine mounts £5 a pair
Pair of headers – without lambda £10
Power steering cooler sold
Face lift steering column with key and stalks £5
2 AC RAD fans £2.50 each
T05 Turbo in parts £10
Set of camber adjustment bolts £5
Alternator £10
Purple maff Sensor – 3 pin £5 condition unknown
Orange maff Sensor - 3 pin soldcondition unknown
Green maff Sensor - 5 pin £5 condition unknown
Version 4 throttle body with sensor £5
Version 5 throttle body sensors £5
3 Cam Sensors £5 each
3 crank sensors - 1 black £5 each
2 water temp sensors £3 each
3 knock sensors – 1 pin/1pin with a double plug and 1 short plug type with adapter £10 each
Version 2 ICV £3
Various stalks and switches £2 each
IC water spray tank approximately 2 litres (no pump) £5
Version 3 recirc valve sold
Version 5 recirc valve £5
Set of 4 prodrive centre caps (60ml) sold
Dog bone engine mount £3
Rear nearside brake calliper £5
2 sets of electric door mirrors – 1 pair black/1 pair white (pre facelift) £10 a set
Nearside mica blue electric door mirror (facelift)£5
Heater and AC matrix blowers – facelift £5
Version 5 water crossover pipe (could be newage) £5
Early classic water crossover pipe £5 each
Version 2 plastic header tank sold
Version 3 > alloy header tank £10
2 Brake master cylinder and servo - 1 with servo £10 each
Clutch master cylinder £10
Version 5 ABS ECU £5
Version 5 Y7 ECU £20
6S 3 plug ECU £20
2B 3 plug ECU £10
Facelift dashboard and centre console (full dash with all switches(not clocks)) sold
Version 5 Momo steering wheel with air bag sold
Stainless Subaru fuse box slip over cover £10
Pre face lift fog lights £5
Grey carpet £5
K & N air filter – 195MN wide at maff – suits early classic £5
Various engine looms version 2 to 5 £5 each
Timing belt tensioner brackets – early type £5
6.5 hp Honda GX200 plant Generator. P rated 2.24kw – 9.73AMP 110/230 volt, 2.8kw, 12.1 AMP max sold
Approx 15+ metres of 8ml ID internal braided black pipe – anti static £20 for the roll
Approx 15+ metres of 6ml ID Nitros Oxide pipe blue £20 for the roll
Pair of JL 12 inch sub woofers twin box £50
Pair of Kenwood 12 inch sub woofers single box £40
JL 4x 300w amplifier £50
1200w 2 channel pro plus sub amp (this thing is a beast) £75
640w 4ch kenwood amp £50
1 fared digital power cap £15
16ml amp wiring kit with 150amp mega fuse (mans grade) with earths, remote, distribution blocks,2 sets of pure AV phono leads gold plated, 1 set unknown – 5 meter £60
Phoenix gold 15 ch graphic equaliser 2 ch and 1 through £40
BC coilover parcel shelf adjusters, rear – 25cm brand new still in packet £10
Old 22 July 2012, 01:30 PM
Themexican
BANNED
Themexican's Avatar
Price/details for the intercooler please mate and do you have any facelift mirrors? thanks
Also, where in the UK are you? update your profile with your location so people can come and collect bits
Old 22 July 2012, 01:32 PM
Themexican
BANNED
Themexican's Avatar
oh, price for the subs/amp too please
Old 22 July 2012, 02:07 PM
JDM_Stig
JDM_Stig's Avatar
hi, what's the blue brace ?
Old 22 July 2012, 02:34 PM
Ian
Ian's Avatar
size and price of the blue and black hose
thanks
Old 22 July 2012, 02:40 PM
need4speeduk
need4speeduk's Avatar
Price of generator (if it works and has 240v) and garden water hose please. Via PM would be great.
Old 22 July 2012, 03:07 PM
banzai2009
banzai2009's Avatar
Price on the heater surround plastic 07926971608 thanks plus postage
Old 22 July 2012, 05:56 PM
dbay
dbay's Avatar
list updated mate, just got the n/s mica mirror for a facelift. cooler is £40. subs and amps are various prices but are all priced on the list.
located in stoke on trent
Old 22 July 2012, 05:57 PM
dbay
dbay's Avatar
that is a under brace for a classic, it links the bottom ams and is fixed to the rear of the cradle
Old 22 July 2012, 06:04 PM
dbay
dbay's Avatar
the generator does work but hasnt been used for a while, i will give it some fresh oil and a new plug to confirm it does work as it should before if sold on. the nitrous oxide pipe is 6mm id (blue) and 8mm id (black), both £20 a roll each.
Old 22 July 2012, 06:05 PM
dbay
dbay's Avatar
which ones are you after mate
Old 22 July 2012, 09:52 PM
banzai2009
banzai2009's Avatar
The ones with the 3 holes for gauges instead of vents mate cheers
Old 22 July 2012, 10:22 PM
dbay
dbay's Avatar
send us a sae and you can have them mate
Old 23 July 2012, 10:40 AM
banzai2009
banzai2009's Avatar
Are you sure mate?
Can you pm or text me prefrebly your details and I'll send it down thanks very much
I take the orange maf aswell please I'll post money and an envelope inside for you as soon as I get ure details thankyou
And also the rear spats Re they the actual spat or just to hang the spats?? Any pics if there the spats I'll take those aswell mate
Old 23 July 2012, 11:59 AM
fourspoons
fourspoons's Avatar
Hello mate, quite a collection you've got there!
I'm interested in the steering wheel+airbag please. How much posted? Or whereabouts are you for collection?
I'm also after a plastic stereo surround from a v5 STI import if you've got one?
Chris
Old 23 July 2012, 04:23 PM
andyyam750
andyyam750's Avatar
Whats the deal with the TD05 mate, is it goosed or just in bits???
Old 23 July 2012, 05:54 PM
dbay
dbay's Avatar
Chris
sorry mate the wheel has dibs on it already im afraid
Old 23 July 2012, 05:56 PM
dbay
dbay's Avatar
it is dry but i would personally put a seal and bearing kit on it to make sure its pukka
Old 23 July 2012, 06:59 PM
fourspoons
fourspoons's Avatar
Ok mate, come back to me if it doesn't sell, cash waiting
Old 23 July 2012, 08:34 PM
Yellow R
Yellow R's Avatar
Hi mate is the classic centre vent available the one with gauge holes in it?? thanks
Old 23 July 2012, 08:56 PM
Finbin
Finbin's Avatar
Hi
What version are the cam belt covers?
Are they the covers that goes between engine and belt, and the front covers?
Can you please tell me the part numbers?
Old 23 July 2012, 09:30 PM
banzai2009
banzai2009's Avatar
Sorry mate it's mine still waiting for address details to send envelope and money for afm orange to
Old 24 July 2012, 01:11 PM
potter.adam20
potter.adam20's Avatar
What cond are white skirts il have them
Old 24 July 2012, 02:00 PM
Yellow R
Yellow R's Avatar
ok mate no worries.
Old 24 July 2012, 09:17 PM
dbay
dbay's Avatar
Originally Posted by Finbin
Hi
they are classic fitment so v1-v6, the back is included in the set. no part numbers sorry but can take pictures if you are unsure.
pm sent at 5.14am this morning with details
they are in pretty good condition for 14 years old, a little gravel rash on the bottom and the sides are clean.
Old 27 July 2012, 06:37 PM
dbay
dbay's Avatar
evening
Old 27 July 2012, 07:24 PM
seaside matt
seaside matt's Avatar
Do you have a rear bumper drivers side bit of trim? Think its called a spat
Old 28 July 2012, 09:58 AM
EJ22 LAD
EJ22 LAD's Avatar
white nearside front door, what condition m8 and location?
cheers
gav
Old 28 July 2012, 04:20 PM
dbay
dbay's Avatar
sorry mate ive got no spats
cheers
gav
the n/s/f door has a crease on the top half of the door, possible ding dent removal. located in stoke on trent.
Old 28 July 2012, 04:37 PM
hence555
hence555's Avatar
Hi,
Do you still have the single bolt x4 coil packs for sale..? + price
And also air filter please.
cheers
Quick Reply: garage clear out mainly classic
