BREAKING 99 UK 95H (P1 ALLOYS/HDI GT2 FMIC/STI 8 REBUILT ENGINE/K SPORT 8 POTS+MORE)
Old 11 August 2012, 04:45 PM
Default BREAKING 99 UK 95H (P1 ALLOYS/HDI GT2 FMIC/STI 8 REBUILT ENGINE/K SPORT 8 POTS+MORE)
ok we have a very nice 99 UKturbo for breaking in 95h deep blue nice car sadly worth more in parts last owner owned and care for the car for some time sensibly modding it on the way to a very nice spec
all parts are based on collection we can post at extra cost please ask
collection from
pole position uk
south street
willenhall
wv13 3tg
call or tx for quick reply 07785942237
genuin sti 8 semi closed deck rebuilt bottom end with new crankshaft and bearing and rebuilt phase 2 heads so so a complete phase 2 long engine excellent working order very nice running engine pulls like a train running close to 340ish safely will happily runn 400+ safely all work done by chy @ pennine subaru sept 2010 which since has covered 3000 miles max
heads, valves & stems re-done also @ time of re-build excellent motor no oil water used and no leaks a sweet engine idea upgrade for any phase 2 wrx/uk sti classic £1200
sti short ration ty754vbaaa gearbox and rear diff all perfect working order perfect gear changes no whines or crunches at all good positive gear change with matching rear diff and shafts for easy fit excellent accelratin and decent top speed also very strong perfect upgrade for any classic £480
hybrid vf34 roller bearing turbo built by turbo dynamics using a vf22 larger rear p20 housing for more top end power in excellent condition a perfect condition all conplete with uprated actuator and water pipes ready to fit pulls like a train removed from avery rare turbo one of the best for a fast road car with very min lag £470
uk ecu with full ecotek remaped so no licence fee excellent working con remapped by cha at pennine subaru roughtly 340ish bhp with mods £100
genuin harvey smith hdi gt spec 2 hybrid front mounted intercooler kit with all genuin hoses ect complete bolt on kit best kit on the market great flow and cooling and great fit all in good con also inc converter plate for genuin recirc or aftermarket dv for this year £180
forge vta dump valve for v5/6 tmic excellent con sounds awesome £40
uprated welbro 255l'ph genuin fuel pump excellent con £40
3inch de catted down pipe good con good quality aswell all heat wrapped 3inch narrowing to 2.5inch at the join £90
hayward and scott cat back exhaust sounds awesome excellent fit quality is awesome as always with these exhausts one of the best makes around and the noise is stunning exhaust is in excellent con under 95db for track days also £180
zero sports induction hard pipe £30
k&n con induction kit and fitting kit for this year good con £35
black phase inlet manifold looks very good no paint missing ect complete with fuel rails £40
ported headers with std up pipe great spool up with these all heat wrapped poss could do with re wrapping tho £70
exedy pink clutch with skimmed fly wheel less than 5000miles £80
japspeed catch tank no fixing £10
subaru 3 port boost solinoid good con £30
2 port boost solinoid £25
late spec map sensor £25
cam sensor £15
crank sensor £15
lamba sensor excellent working order £25
phase 2 throttle body with tps and idle control perfect working order £40
phase 2 coilpack excellent working con £25
phase 2 440cc injectors £50set
phase 2 knock sensor £30
phase 2 maf sensors perfect working order £45
3 pin alternator excfellent working order £30
phase 2 turbo inlet pipe no rips ect £20
starter motor £20
single fan rad £25
EXTERIOR
facelift front bumper good con but has been cut for fmic tho decent con inc washer jets no wedges inc £60
facelift wedges for above bumper good con £20pair
facelift bonnet complete with scoops ect good con minor stone chips all complete £50
3d v6 grill good con £50
genuin facelift crystal headlights in very good con no chips ect £60pair
uk rear lights very good con no damage £30pair
front wings good con £40pair
4x doors good con £20each
colour coded door handles good con £15each
boot lid good con £30
version 6 sti hi level spoiler replica good con and quality and fit £100
black mudflaps with brackets ect £25set
un colour coded side skirts good con £30pair
facelift rear bumper with hockey sticks good con £45
side repeaters £10pair
front window v good con £40
rear window no wiper hole £45
colour coded mirrors good con £40pair
BRAKES/WHEELS/SUSPENTION
genuin o.z p1 prodrive alloy wheels 17inch alloy wheels genuin items not copies failry rare and expensive item wheels are all straight and true no damage or curbing at all all very clean in dark grey no marks ect and all tyres plenty legal around 4mm tread tryres are all prada spec 2 215/40/17 alswell so excellent grip with these £400
k sport 8 front brake set up with 330mm 2 piece disks in excellent con std pads have been replaced with far better ds2500 pads for excellent serious braking power all very good con pads and disks have loads of life left in them will fit under a 17inch wheel also £500
1 pot rear brake set up good cailper with brand new in box vented disks and pads that have never been fitted £50
front drive shafts v good con £25each
4x abs hubs all good con with good bearings £25each
full jdm sti red 50mm insert shocks and hks 40mm lowering springs springs all good con excellent road holding no body roll at all no leaks knocks or bangs £200full set
pink end strut brace good con £20
4x abs sensors good con £15each
pas pump excellent working order £45
pas steering rack £30
pas pipes with cooler £15
INTERIOR
3x gauges with A piller pod and single pod for boost oil temp and pressure and boost oil temp and pressure have brand new sensors also inc remote vbraided hoses for easy fitment £80
uk dark blue interior seats decent for year no rips or tears facelift type so adjustable base on drivers seat £60front and rear
door cards to martch above facelift fitting all good con very minor marks if any at all £20set
carpet good con £15
facelift momo leather steering wheel good con £40
momo aftermarket gear **** good con £15
hand head fire extinguisher with proper fixing bracket to fit to origiinal seat fixing bolts £20
uk2000 genuin floor mats good con no holes ect just need a good hover £20set
facelift speedo's good con with carbon faced cover and blue led back lit all good con £50
single facelift stero surround good con £10
facelift dash with air bag £30
Old 11 August 2012, 10:49 PM
frankyurry
frankyurry's Avatar
Top advert couldn't of put it better myself ;-)
Old 11 August 2012, 11:01 PM
classicgc8
classicgc8's Avatar
Default downpipe please
hi Matt,any chance of couple of pics of the downpipe please mate ,thanks, Dave
Old 12 August 2012, 10:01 AM
5cooby1
5cooby1's Avatar
Interested in nearside wing if mint and also Hayward and Scott centre pipe if decat both posted also that turbo return hose rubber one
Old 12 August 2012, 10:16 AM
5cooby1
5cooby1's Avatar
And zero sports hard pipe pics
Old 12 August 2012, 02:55 PM
Frankyurry cheers mate sorry we breaking your old car
Classic gc8 picks of the down pipe will be like Tuesday before we get it
Removed fella
Scooby 1 we add pics body work looks very good on this so il comfirm the con of the wing when it stops raining also the Hayward and scot there no cats in I think there is a small resonator box in the middle but defo no cats zero sports pipe il add pics this evening fella
Old 12 August 2012, 03:22 PM
5cooby1
5cooby1's Avatar
Yeah pal I'm very interested in all I said pm me when pics on
Old 12 August 2012, 08:03 PM
gibbyisking
gibbyisking's Avatar
you would happen to have a fuel pressure regulator for a v2?
Old 12 August 2012, 08:29 PM
few pics added check them put fella pm me if needed
all pm's replied an d pics added
Old 12 August 2012, 09:17 PM
Bealescooby
Bealescooby's Avatar
oooo i like them gauges , will need to come view them
Old 12 August 2012, 09:51 PM
classicgc8
classicgc8's Avatar
hi matt,pm sent ref that downpipe as above
Old 13 August 2012, 12:15 AM
no probs beale i cvan put them with the rest of your bill
pm replied dave cheers
Old 13 August 2012, 02:02 PM
scooby.steve555
scooby.steve555's Avatar
Have the gauges sold then?Steve
Old 13 August 2012, 09:04 PM
no there still for sale pm me if needed
all pm.s replied
Old 14 August 2012, 05:38 PM
Themexican
BANNED
Themexican's Avatar
il have a look / hopefully take the spoiler matty, in 95h?
Old 14 August 2012, 06:22 PM
the hamster
BANNED
the hamster's Avatar
Matty, would you sell the gauge pod on its own, or do you have any triple centre pods for facelifts? I'm seeing Dave the Chef on thursday so if you've got owt I can get him to pick it up.
Oh, and have you got a flare? and any p1 rear 1/4 glass?
Old 14 August 2012, 06:58 PM
Dave tx replied cheers
Hamster gauges are sold I'm afraid fella sorry
All pm's replied
Old 15 August 2012, 09:54 PM
topdogkelvin
topdogkelvin's Avatar
Hi Matty is The STI Spoiler still for sale if so how much including postage
Old 15 August 2012, 10:34 PM
sorry its sold im afraid
all pm's replied
Old 16 August 2012, 05:36 AM
Turbo-Rush
Turbo-Rush's Avatar
clutch and flywheel price delivered please if still available
Old 17 August 2012, 10:09 AM
sorry fella clutch has now sold flywheel is still for sale if needed
all pm's replied
Old 17 August 2012, 06:10 PM
ScoobyForLife27
ScoobyForLife27's Avatar
Hi Matt. Is catback 2.5 or 3 inches ?
Old 17 August 2012, 10:04 PM
It's 2.5inch fella
All pm's replied
Old 21 August 2012, 12:35 PM
davoid
davoid's Avatar
still got mats? Price delivered?
thanks
Old 21 August 2012, 01:20 PM
Yes we have postage is 7quid the set pm me if needed
Old 29 August 2012, 07:37 AM
ovadrive
ovadrive's Avatar
Hi there are the wheels still for sale if so how much posted uk
Old 29 August 2012, 03:15 PM
Pm sent all pm's replied
Old 01 September 2012, 06:57 PM
Guest
Guest's Avatar
After a high level STI spoiler in 95H or maybe 52D might work, if this one's sold don't suppose you've got any others?
Old 01 September 2012, 07:05 PM
Sorry we don't have any in at the moment I'm afraid sorry
Old 01 September 2012, 07:09 PM
Guest
Guest's Avatar
No probs, just a bit too slow again as usual!
Quick Reply: BREAKING 99 UK 95H (P1 ALLOYS/HDI GT2 FMIC/STI 8 REBUILT ENGINE/K SPORT 8 POTS+MORE)
