Hayward & Scott Slip Jointed Up Pipe
Old 11 September 2012, 08:30 PM
MrNoisy
Supporting Member
MrNoisy's Avatar
Default Hayward & Scott Slip Jointed Up Pipe
Hayward & Scott stainless steel slip jointed up pipe, great upgrade for WRX cost £120 new, will do it for £60 posted.
Same as this http://www.haywardandscott.com/subar...e-up-pipe.html
Old 13 September 2012, 10:21 AM
MrNoisy
Supporting Member
MrNoisy's Avatar
Bump
Old 13 September 2012, 01:00 PM
pot1175
pot1175's Avatar
I presume it will also fit classic headers as well ?.
Old 13 September 2012, 01:39 PM
Rammi shaa
Rammi shaa's Avatar
does the uppipe make the car sound any different and what sort of bhp gains does it give ??
Old 13 September 2012, 02:16 PM
MrNoisy
Supporting Member
MrNoisy's Avatar
@pot1175 - From what I can find, they're the same, other than the newage has an EGT boss and the classic doesn't; you can easily put a bolt in the EGT boss though (as I did with mine).
@Rammi_shaa - On a newage WRX, the up pipe has a cat in it.
I changed mine out for this and made an additional 8bhp and 12ft/lbs after mapping, and the car pulls far better with the reduced restriction.
One thing that sometimes happens is that the up pipe cat breaks down, goes through the turbo and BANG. Swapping it out means you eliminate that possibility.
Noise-wise you probably won't notice a huge difference; maybe a little more turbo noise.
If you remove the Catted uppipe or the EGT sensor that goes in, you need to install a 2200 ohm resistor across the terminals where the EGT sensor normally plugs in so as to fool the ECU and prevent it from throwing a CEL. It's a 2 minute job that I did on my old WRX.
Or...your mapper can map the code out
Old 13 September 2012, 02:58 PM
duds64
duds64's Avatar
that pic looks like it has a chunk missing from the bottom end
Old 13 September 2012, 03:48 PM
MrNoisy
Supporting Member
MrNoisy's Avatar
Look closer duds64 - I think you're seeing a shadow....suggest you revise that statement.
Old 13 September 2012, 03:52 PM
M2RTXhawkeye
M2RTXhawkeye's Avatar
Defo a shadow mate 😉 got one of these on mine good but of kit and well worth the price above. Glwts buddy
Martin
Old 13 September 2012, 05:47 PM
pot1175
pot1175's Avatar
Cheers for the reply I have a blank for the egt, YHPM.
Old 13 September 2012, 06:56 PM
duds64
duds64's Avatar
i take it back mate it was the way i was looking at it
Old 13 September 2012, 09:01 PM
pot1175
pot1175's Avatar
Deal done, just waiting on payment details
Old 14 September 2012, 07:30 AM
MrNoisy
Supporting Member
MrNoisy's Avatar
Provisionally sold to Mark
Old 16 September 2012, 09:06 AM
pot1175
pot1175's Avatar
Cheers bud,
Mark.
Old 17 September 2012, 06:58 PM
pot1175
pot1175's Avatar
received today, cheers
Abx
22
09 January 2016 05:42 PM
Scooby_Lee101
3
26 September 2015 12:04 AM
Quick Reply: Hayward & Scott Slip Jointed Up Pipe
