HAWKEYE STI UK BREAKING 17000MILES ONLY
ok we have a stunning sti hawkeye uk spec for breaking sadly it has a bottom end rattle and the owner can no longer afford to fix it
car is in amazing condition its only covered 17tho miles only mechinics and body work all look almost new sorry about the poor pics of the body as it was raining i couldnt polish him up just a quick wipe over im afraid
parts are all plus postage if needed please ask for prices
collection from
pole position uk
south street
willenhall
wv13 3tg
call or tx for quick reply 07785942237
ALL PANEL ARE COLOUR 32J
sti non catted headers excellent con £60
standard catted down pipe excellent con £50
standard cat back sti system with sti back box all very good con £70
standard air box £30
sti large turbo inlet pipe £30
sti recirc valve excellent working order £20
full sti dccd car wiring loom uncut or modded minus small engine loom £120
ecu with transponder sensor and unit and full lock set and transponder key ecu is std and un modded £150complete
front lamba sensor genuin part excellent working order £60
rear lamba sensor excellent working order genuin part £50
map sensor excellent working order £25
2 port boost solinoid excellent working order £25
top rad hose good con £10
bottom rad hose £5
plastic header tank good con no leaks £15
air con pump excellent working order £15
inner wing washer bottle and filler neck with pumps £40
WHEELS/BRAKES/SUSPENTION
wide track power sterring rack excellent con £50
power steering pump with relocation pump and bracker with cooler built in £30
brake master cylinder excelletn con £25
clutch master cylinder with remote resvoir excellent con £25
sti front roll bar £25
sti rear roll bar £25
BODY AND EXTERIOR
sti twisted side skirts excellent con £80pair
wing mirrors excellent con £70pair
filler door excellent con £15
front window excellent con £60
heated rear window excellent con £70
under wheel arch liners excellent con £80pair
under body side trays both sides genuin part £40pair
engine under tray and gearbox under tray excellent con £30pair
INTERIOR TRIM
wide track facelifted stye heater control and center consold ect with genuin sti red stich hand brake for complete kit for bloeye or bug eye conversion all in excellent con great upgrade for earlier newage models £150
blue sti carper again excellent con no wear at all and no marks just needs a good hover £70
dash top excellent con £50
dash under glove box excellent con £30
drives side under steering wheel plastics excellent con £20
A/B/C piller trims all excellent con £30set
roof lining like new still £30
dash clock excellent working order £25
boot lining and capter like new £50set
ANYTHING IV MISSED PLEASE ASK WE MOST LIKELY HAVE IT ALSO CHEERS
collection from
pole position uk
south street
willenhall
wv13 3tg
bottom rad hose £5
BODY AND EXTERIOR
INTERIOR TRIM
Cj it's a 2.5 mate this happens our 15k is the least we come across 4k is the least iv herd of
Martin the mats are in excellent con no wear showing mate
Richie sorry spoiler has sold already sorry
Vain spoiler and coil packs sold already
Murray sorry its vein broke only its worth to much in parts for us sorry
Martin sorry Martin 850 has taken payment details for the mats if he doesn't take them il let you know fella cheers
All pm's replied
All pm's replied
Martin yes sorry he had message first il keep you posted as for the boot badge sorry pal it's staying on the boot fella sorry
Jules all the prices are listed fella postage would be £45 on a pallet for all parts collection is welcomed but te prices are the prices fella there not many interiors out there like this anymore fella
Cheers Martin
Hi, i'm after a fuel filler cap with the tether etc. could you give me a price on that posted to Surrey? The plastic tether on mine has snapped so i have to take it off and leave it on the boot while i fill up and it annoys me .
Hi mate could you tell me how much for the flasher unit under the steering column and the upper most rubber coolant pipe from he header tank to the turbo please posted to Darlington co Durham , thanks.
Blackbugeye thoses 2 parts £20 posted fella pm me if needed
Guardian sorry were not splitting the rear lights I'm afraid postage would be £22 an that would be complete with wiring and deals yes fella pm me if needed
All pm's replied
All pm's replied
Ian its still fitted but it all looks brand new its only run standard power and has done very little miles so the chances of cracks or play are minimums but it will be checked before final sale also postage would be £9 on this pm me if needed
