Some Parts From My Spec C
Old 24 December 2012, 08:21 PM
Cannon Fodder
Cannon Fodder's Avatar
Default Some Parts From My Spec C
Below are some parts which have either been removed or are due to be removed very shortly from my Spec C.
My car is currently with Prodriverules (Ryan) who will be removing the parts for me, I dare say that if I ask him nicely he might be able to take some pics for me if required.
APS Dual Dump Valve
I bought this from TimH (JT Innovations) with the intention of using it but never got around to fitting it, if you look at the pic that I have 'borrowed' from the APS website I am missing the bracket, screws, lockwashers plus hose clip. It does have the connecting hose which would fit to your FMIC pipework, I have also got the recirculating hose connector which I removed from my standard BOV now fitted to this.
http://www.airpowersystems.com/wrx/blow.htm
Sold
APS Cold Air Intake 70mm
This is currently still fitted to my car but will be removed very soon, it is the larger of the two intakes (the smaller size is 65mm) and had no problem at all running at 400+bhp.
Once it has been removed I will get the filter cleaned and the intake pipe repainted as there are a few scratches on it where it mounts through the inner wing.
http://www.airpowersystems.com/wrx/my01/hfa.htm
No Longer For Sale
Samco Turbo Air Inlet Hose For Newage Vehicles (58mm)
This Samco turbo inlet hose is in black, it is the 58mm size and is in good condition - there are a couple of marks on the outside of it but nothing that you wouldn't get when fitting it.
The metal inserts into the breather ports have been removed as I was running an oil catch can setup, these ports were blanked off but I have removed the blanking plugs.
Sold
Standard Newage DV with Harvey's FMIC Adaptor Plate
This is the standard Newage DV as fitted to my Spec C which I have fitted onto an adaptor plate made by the late Harvey, it is still currently fitted to my car.
This allows you to use your factory DV when running a FMIC, a really good piece of engineering which works brilliantly.
Sold
Defi Power Cable 4 Pin
I bought this and thought I had lost it and then ended up buying a second one, it is still sealed in the packet and is literally brand new.
The Defi part number is PDF01302H.
Sold
Newage 650cc Flow Matched Injectors
I purchased these from another member on here after they had just had the flow rate increased and tested.
I believe I have the original flow test printouts in work and I will get them professionally cleaned and tested prior to posting.
These injectors have behaved faultlessly whilst fitted to my car and are capable of a lot more than the 400+bhp that they currently are used at.
These are still currently fitted to my car, before fitment I had a complete new set of genuine Subaru seals fitted to the injectors and they should be fine to be re-used.
Sold
Agency Power Hard Pipe 3" Coupling Hose
After a change of spec to my forthcoming turbo I find that I now have a 3" coupling hose for my Agency Power Hard Pipe.
It is literally brand new, I ordered it from the USA and got stung for import duty and handling fees as I couldn't source one in the UK.
http://www.agency-power.com/catalog/...1bfp6pkrd5hih0
Sold
I can accept payment by PayPal which I prefer for the protection given to buyer and seller (no fees will be passed onto the buyer or gift payments taken), bank transfer, cash on collection or a cheque (but funds must be cleared before I will post the goods out).
Obviously the parts still fitted to my car will now be removed in the new year and posted out after that.
Old 24 December 2012, 08:49 PM
stevie1982
stevie1982's Avatar
hi mate, would the APS induction kit possibly fit my 2010 sti hatch? no harm if you are not sure but thought I would ask.
Old 24 December 2012, 08:57 PM
Cannon Fodder
I wouldn't think so to be honest, I am not saying it couldn't be done with some modification to your inner wing but I am sure you wouldn't want that.
On the hatch or saloon I personally would go for the Forge CAIK which they make for Litchfield, I have seen it and it's a quality piece of kit and very well made.
Old 24 December 2012, 10:25 PM
Cannon Fodder
Injectors sold.
Old 25 December 2012, 11:20 AM
stevie1982
stevie1982's Avatar
Cheers pal I appreciate the honest and open advice I will take a look
Old 26 December 2012, 02:59 PM
Cannon Fodder
Bump
Old 27 December 2012, 03:16 PM
Cannon Fodder
Bump
Old 27 December 2012, 04:56 PM
Cannon Fodder
Agency Power coupling hose sold.
Old 28 December 2012, 05:15 PM
Cannon Fodder
Samco turbo inlet hose sold.
Offers welcome.
Old 29 December 2012, 12:07 PM
fasteddie84
fasteddie84's Avatar
Can't wait for the hose :-)
Thanks Ty for all your help and replying to all my PM's so quickly. Good to do business with you and good luck with the rest of the bits.
Old 29 December 2012, 05:59 PM
Cannon Fodder
No problem, your hose went out via Royal Mail before 1pm Special Delivery, I'll PM you the tracking details later.
Old 29 December 2012, 06:07 PM
Silver Scooby Sport
Moderator
Silver Scooby Sport's Avatar
Some quality items there Ty
Old 29 December 2012, 08:10 PM
Cannon Fodder
Thanks Simon.
Old 29 December 2012, 08:13 PM
Cannon Fodder
Remaining items prices revised, grab a bargain.
Old 30 December 2012, 05:03 PM
Cannon Fodder
Bump
Old 31 December 2012, 08:50 PM
Cannon Fodder
Offers welcome on the remaining parts, the worst I can say is no.
Old 01 January 2013, 11:05 AM
k_duraman
k_duraman's Avatar
Location: where there are no gatsos and no speed limits
I'll have the defi power cable pls. Just pm the PayPal address , I am in Norwich.
Thanx
Old 01 January 2013, 11:22 AM
Cannon Fodder
PM sent.
Old 02 January 2013, 05:36 PM
Cannon Fodder
Bump
Old 02 January 2013, 06:02 PM
IainMilford
IainMilford's Avatar
would you split the fmic dv adapter plate? Don't need the dv. Any pics of it fitted? Assuming it would work with any fmic (will be fitting a perrin) cheers iain
Old 02 January 2013, 06:13 PM
Cannon Fodder
Yes it would work with any FMIC setup which has an external DV setup.
I would be willing to split the adaptor from the DV but I'm waiting back on another member who wanted some pics so it's only fair that I wait to hear back from him.
Old 02 January 2013, 06:24 PM
IainMilford
ok let me know as i'll take it straight away if the other seller doesn't come through
Old 02 January 2013, 08:00 PM
Cannon Fodder
No problem.
Old 02 January 2013, 08:01 PM
Cannon Fodder
I nearly forgot about this item, it is a heater control/radio panel from a MY05 Blobeye/Hawkeye.
I bought this and had it sprayed matt black by Prodriverules (Ryan) but I couldn't use it due to my Spec C having manual AC controls and it couldn't be converted without a lot of modifications.
I would like £45 which will included insured and trackable delivery to the mainland UK.
Old 02 January 2013, 09:37 PM
Cannon Fodder
Sorry but payment now received for the adaptor plate.
Old 02 January 2013, 09:57 PM
IainMilford
no worries cheers for the update
Old 03 January 2013, 08:50 AM
fasteddie84
Just to say that I received the Samco hose yesterday. It was as good as Tyron described and came quicker than I thought. Thanks a lot for that :-)
Old 03 January 2013, 09:53 AM
Cannon Fodder
No problem, glad to be of help.
Old 03 January 2013, 08:34 PM
Cannon Fodder
Bump
Old 04 January 2013, 06:59 PM
Cannon Fodder
Offers welcome on the APS CAIK and the heater control panel.
Quick Reply: Some Parts From My Spec C
