Lots of wheels and tyres, new and old, RE070, Pirelli, Michelin, Dmack, cheap
Hi all,
I have loads of wheels and tyres available, but please be quick if you’re interested as I'm guessing they won’t hang around long.
sold1 set of OEM White 114.3 pcd 17" alloys in fitted with 235/45/17 Bridgestone Potenza RE070 tyres. Wheels are as new. With 1 set of tyres which have delivery miles (maybe a few more), £450 ovno
sold1 set of OEM White 114.3 pcd 17" alloys in fitted with 235/45/17 Bridgestone Potenza RE070 tyres, wheels as new. With 1 set of tyres with delivery mileage but slightly more worn on the odd tyre on the outer edge, still pretty much mint, I’m just being very critical. £400 ovno
1 x Set of 17" Speedline corse 2113 group n wheels in Gold fitted with 235/45/17 Part worn Bridgestone Potenza RE070 tyres £475
The wheels are almost £1000 new without tyres, grab a bargain!
3 x Speedline wheels in Gold with no tyres, ideal as spares for the above £70 per rim
6 x 17” Pirelli Tarmac Tyres RS5 225/625 part worn with plenty meat remaining (I would need to confirm width and profile for sure), but a bargain at £55 per tyre, or £200 a set.
Lots of OEM 100 pcd and 114.3 pcd space savers, all brand new and never used with brand new tyres.
£30 each.
9 x 18” Pirelli Tarmac Tyres RE7 225/625 part worn with plenty meat remaining (I would need to confirm width and profile for sure), but a bargain at £60 per tyre, or £200 a set.
http://www.ascania-racing.com/Shop/P...port2011_5.pdf
http://www.pirelli.com/tyre/ww/en/ca...rsport/rx.html
16 x 18" Part worn Pirelli DS tyres (Soft compound) £50 per tyre.
12 x 18" Part worn Pirelli DH tyres. (Hard compound) £50 per tyre
Info here on both DS and DH.
http://www.ascania-racing.com/Pirelli%20circuit.pdf
13 x 18” Part worn Dmack Soft tyres £50 per
More info here if you don’t know of them: http://www.dmacktyres.com/dmack-trackday-car-tyre
sold4 x 18” Part worn Dmack Ice tyres (studded) £200 for the set
5 x 18” Part worn Pirelli Wet tyres £150 for all 5.
3 x 18” Part worn Michelin Hard tyres & 3 x Part worn Michelin TA01 tyres £150 for all 6, no a bad combo for 2 + 2, and 1 of each spare..
All loose RE070’s have now sold, the only ones left are on the rims at the top of this page. However if you want track tyres there are some amazing tyres above, which normal retail at several hundred pound when new.
Some random pictures, sorry for the storage dust, no time to spend on cleaning it all, the bottom pic is about the most worn tyre I could find.
*********When I'm stating "almost new" or "delivery miles +", this is literally a case of the car coming from Japan on a transporter or container, and the car driven minimal miles to the unit, in worst case its Newcastle to base which is around 150 miles at which the car is stripped for WRC preparation. The used tyres vary, but the worst case tyre from what I have seen has a fair amount of tread past the wear marker.*********
Rob
ps - mods if this is too many to sell as a private sale, then drop me a PM and I will sign up AA status and reflect this in the prices of the products I have for sale.
Added 19-01-13 with pictures taken today:
Ok so there has been a lot of questions about the condition of the wheels, the size of the tyres, price for the lot etc.....
So here goes, the RE070 are the Jap spec 235/45/18, not 225 as some keep thinking I have typo'd.
They are 114 pcd, so they will fit the Late Blobeye, Hawkeye, Hatch and possible the new Saloon, and any other car that has had the 114 hub conversion.
The tyres are all in great condition, one set of the white's are almost as new, the other set have seen a little more testing, but in essence both sets were removed from the cars when they entered the UK from importation new.
More pics, and yes they are "dusty" and require a clean, but work commitments this week have played havoc with free time
These are the 18" Wet Pirelli as requested, quite happy to take offers new ask price on them.
£30 each.
Rob
Hiya mate, the practically new ones £275, the part worn £175 a set.
Regards
Rob
Hope that helps pal.
Rob
ps, RE070's will be fine on your rims on a newage car, a classic from memory would need the arches rolling.
When I'm stating "almost new" or "delivery miles +", this is literally a case of the car coming from Japan on a transporter or container, and the car driven minimal miles to the unit, in worst case its Newcastle to base which is around 150miles at which the car is stripped for WRC preperation.
Rob
Other than the RE070's, there all pretty much all WRC tyres. The Dmack tyres are proper tarmac competition tyres, not ideal for just winter use although they are renowned for good water Dissipation.
Rob
Rob
Martin
Hiya Marc, Two almost new £140, or part worn £90 plus P&P at around a tenner.
Rob[/QUOTE]
Mine is a wrx with 215 on the rear so couldn't run 225 on fronts could I?
Rob[/QUOTE]
Paypal or Bacs bud, I’ll send you a PM now.
They ought to be 225/40/18 but I would need to confirm.
Yes got part worns, but I need to confirm tread depth bud, which will be Monday at the earliest.
I would say this would be ok if you have the same profile tyre, and that they have similar tread depth, otherwise you run risk of buggering up the diff. You may be better get some professional advice.
Pm now sorted, I turned it off for some reason (doh)
Which wheels did you want, the white ones?
A set of white wheels with almost new tyres £500.
A set of white wheels with part worn tyres £400
A set of Gold wheels with part worn tyres £400 (need to confirm though, may be sold)
As above buddy. I need to confirm the Gold ones are still here as a mate was showing interest.
I doubt I will have any road tyres in 18’s, 18’s were used for tarmac or asphalt rallying so that is what the Dmacks are.
So many people are after these tyres I need to collate a list so I don’t promise someone tyres and have non left. Bare with me.
As per PM pal, I need to sort out a lsit as its getting out of hand, I only have what is listed in the first post, once there gone there gone.
Rob
Rob
