PRODRIVE STI 7 BREAKING(ppp sports cat/exhaust system/prodrive styling/brembos/forge)
Old 12 May 2013, 08:27 PM
Default PRODRIVE STI 7 BREAKING(ppp sports cat/exhaust system/prodrive styling/brembos/forge)
ok we have another nice wr blue 02c sti version 7 uk prodrive spec with slight loss of compression due to exhaust valve seat apart from this 100% mechanical all parts are based on collection delivery can be arranged at extra cost please ask
pole position uk
south street
willenhall
wv13 3tg
6 speed larger front drive shafts for above set up excellent con £40each
6 speed fly wheel excellent con no juddering ect £60
sti large tmic in good con complete with genuin cast pipe and silicone turbo joiner also fixings brackets and larger under tray for complete bolt on kitgreat bolt on wrx or classic upgrade £180
sti water spray kit bottle/motor/jets/manual button great kit for wrx £70
sti 550cc pink injectors excellent working order £100set
sti newage coil packs all excellent working order great upgrade for classic models £80set
full sti car wiring loom uncut or modded minus small engine loom £120
eco tekked sti ecu approx 330bhp full licence payed so no fee to pay £100
genuine sti non catted headers in excellent working order with genuine sti non
catted uppipe £60
front lamba sensor genuin part excellent working order £70
rear lamba sensor excellent working order genuin part £50
turbo inlet pipe excellent con unripped ect £30
std air box £20
maf sensor excellent working order genuin part £45
idle control valve excellent working order £35
throttle body with tps fitted no idle control tho great working order £25
2 port boost solinoid excellent working order £25
crank sensor excellent working order genuin part £25
front cam sensor excellent working order genuin part £25
boost solinoid cover with clips £10
twin fan rad good con no leaks £30
rad hose good con £10
std bottom rad hose £5
metal header tank good con no leaks £15
air con pump excellent working order £15
washer bottle with pumps £15
SUSPENSION/WHEELS/BRAKES
alloy front bottom arms good con complete with cones for easy fitting £80pair
100pcd sti front hubs with good brearings £50each
r180 larger rear hubs in excellent con with excellent bearings £160pair
sti steering rack good con £40
pas steering pump in excellent working order no leaks or whines ect £60
pas remote resovoir bottle with pipe work and cooler £30
clutch master cylinder with remote res £20
brake master cylinder £20
EXTERNAL BODY WORK
bugeye sti wings in good straight con does have stone chips tho so could do with painting £80pair
sti alloy bonnet with genuine large scoop all in good straight con vent does have some paint flaking tho very common on these larger scoops easy fix no under tray tho £150
rear bumper good con paint has some marks on no actual damage to the bumper tho £50
bugeye sti rear lights excellent con £60pair
wing mirrors excellent con with switch some stone chips £40pair
door handles colour coded £25set
side moldings with door rubbers all in great con £30set
boot seal good con £10
fuel filler cover £10
front window good con no chips etc £50
rear window good con £40
INTERIOR PARTS
sti door cards in very good con all in great con £60set
sti chrome door handles good con £20set
sti momo steering red stitched wheel in good con £70
red stiched handbrake lever good cxon £20
sti clock spring good con £25
6 speed gearknob good con £30
sti clocks excellent working order £70
stereo surround in good con £20
center heater vents with surround and cup holder good con £15
sti gear stick surround with good gaitor £30
6 speed gearknob very good con £30
sti blue carpet excellent con £60
pedal set great upgrade for classics £25set
dash top good con £40
boot carpet good con £20
center dash section £15
all plastics available pm me if not listed
Old 12 May 2013, 08:55 PM
ken-sti
ken-sti's Avatar
V4 sti type r I have the r180 diff. . Would that gearbox match up? What's delivery to Ireland?
Old 12 May 2013, 09:08 PM
mo with your diff no you would have to use the diff that is supplied with the gearbox but you could use your driveshafts and rear hubs and brakes so that saves you some money postage is no problem but id need a address for a price fella pm me if needed
Old 12 May 2013, 09:21 PM
Cpt Jack Sparrow
Cpt Jack Sparrow's Avatar
PM'd buddy
Paul
Old 13 May 2013, 12:22 AM
HUN337
HUN337's Avatar
PM'd
Old 13 May 2013, 08:11 AM
Both replied cheers
All pm's replied
Old 13 May 2013, 10:11 PM
Pics now added
Old 15 May 2013, 12:32 AM
95_s14
95_s14's Avatar
Payment sent for grill
Old 15 May 2013, 09:35 AM
It's all yours thank you
All pm's replied
Old 15 May 2013, 12:22 PM
Lagamorph
Lagamorph's Avatar
Backbox looks like a TSL one bud, I had one on mine a while back.
Old 15 May 2013, 06:01 PM
That's a possibility we need to get it removed and checked but certainly sounds and looks the part
All pm's replied
Old 18 May 2013, 03:58 AM
95_s14
95_s14's Avatar
Matt do the prodrive headlight have leveling motors in them ? If so how much to the light shipped with switch and wiring for leveler to 92377 cheers
Old 18 May 2013, 07:20 AM
Yes they do fella your looking £55 shipping for them all fella pm me if needed
All pm's replied
Old 19 May 2013, 11:31 AM
pm's replied and list updated all sold items removed
Old 19 May 2013, 08:02 PM
95_s14
95_s14's Avatar
Are they the hid or non hid ones
Old 20 May 2013, 08:39 AM
They aren't hid as standard no but they do have a aftermarket hid kit fitted that's inc also
All pm's replied
Old 20 May 2013, 06:31 PM
kwan88
kwan88's Avatar
Do you have the turbo heat shield and bolts? And would that fit a standard v8 sti one?
Old 21 May 2013, 11:24 AM
heat shield we do bolts im afraid not they rarely come out without breaking pm me if needed
all pm's replied
Old 21 May 2013, 09:10 PM
Silver Scooby Sport
Moderator
Silver Scooby Sport's Avatar
Hi Matty, the wheels arrived first thing this morning, spot on with the packaging as well many thanks matey
Simon
Old 21 May 2013, 09:25 PM
excellent simon thank you again mate
all pm's replied
Old 23 May 2013, 08:35 AM
simonsss
simonsss's Avatar
Hi did the lights go? If not how much for postage to NP19 7NY?
Simon
Old 23 May 2013, 08:50 AM
We still have the lights as listed postage is £9 pm me if needed
All pm's replied
Old 24 May 2013, 11:36 PM
95_s14
95_s14's Avatar
Please leave feedback when you can thank you
Old 25 May 2013, 04:27 PM
Will do cheers again
All pm's replied
Old 30 May 2013, 08:23 AM
List updated all sold items removed and some prices lowered to clear
Old 30 May 2013, 07:07 PM
scooblet
scooblet's Avatar
Best price on a pair of wings delivered?
Old 30 May 2013, 07:10 PM
there £89 delivered for the pair fella pm me if needed
all pm's replied
Old 31 May 2013, 01:12 PM
bluenose172
bluenose172's Avatar
I take it the scoop and under tray are away?
Old 31 May 2013, 06:34 PM
Scoop goes with the bonnet only under tray with the tmic sorry fella
Old 01 June 2013, 04:31 AM
95_s14
95_s14's Avatar
Tmic shipped to 92377
Quick Reply: PRODRIVE STI 7 BREAKING(ppp sports cat/exhaust system/prodrive styling/brembos/forge)
