Rallytech battery clamps, tow hooks etc. etc.
Hey everyone, we thought it was about time that we opened a vendor account on Scoobynet - previously I was posting as 'Ironbridge'
Now we will be running monthly GB's. Many of you are probably already using our bolt kits or other products.
If you have any questions please email rallytechsubaru@gmail.com
You'll get a much faster response via email. Please remember to mention that this is the SNET GB as we have several GB's running at the same time worldwide.
So here we have a GB for all of out lower priced items.
Price includes the items shipped with DHL Global Mail (normally around 10 days for delivery) DHL express is also available and is an extra 10GBP, you only pay the 10GBP once - you can order as many items as you like and it's still 10GBP extra
You can all mix and match the items to get the GB discount. As long as there is 10+ or 20+ people the discounts apply to all of the items!
On previous GB's some people were stung with import tax To avoid this we will post items as 'gifts' you must also specify what value you want marking on the customs declaration.
1. Stainless steel battery rods
Small item but makes quite a nice difference to the battery area and is a lot better than the OEM ones which go very dirty/rusty quickly. Item has been revised, website has not been updated - now comes with a fully polished top Looks great in combination with the battery tie downs below!
http://www.rally-tech.com/battery_rods.html
Normal price around 15GBP 10+ 12.50GBP, 20+ 11GBP
2. Billet aluminum battery tie downs
CNC'd from a 15mm thick billet of aluminum, anodized in a variety of colors and available in 3 different styles. Very nice item. Quite discreet especially if you go for a black colored one.
Important to check the distance between the rods as shown here: http://www.rally-tech.com/battery_tie_downs.html
Normal price around 23GBP 10+ 19.70GBP, 20+ 17.40GBP
3. PTFE header tank spacer kit
Excellent little kit, one of our all time best sellers. 2 x 8mm thick PTFE spacers move the header tank full of hot coolant away from the inlet manifold. The third spacer is only used on some models and is not essential but is supplied anyway. Supplied with stainless steel bolts, washers and nuts.
http://www.rally-tech.com/header_spacer.html
Normal price around 16.50GBP 10+ 15GBP, 20+ 13.50GBP
4. Fuse box covers
Made from 1.2mm thick stainless steel, fully welded and then powdercoated in three different finishes. Simply sits on top of the OEM plastic fuse cover, can be supplied with foam double sided adhesive tape if needed.
3 finishes and lots of logo options to choose from, more info go here:
http://www.rally-tech.com/fusecover.html
Normal price around 30GBP 10+26GBP, 20+ 22GBP
5. Billet racing tow hooks
Probably the best tow hook out there that's Subaru specific. These are super populate stateside and are used on a large number of competition vehicles from circuit to rally.
15mm thick billet, CNC cut and anodized. Bracket is 8mm thick and uses M10 stainless mounting hardware. We have plenty of red ones but black, blue, gold and purple are in limited numbers.
More info go here: http://www.rally-tech.com/towhook.html
Normal price around 41GBP 10+ 36GBP, 20+ 32GBP
***EDIT*** BLACK HOOKS NOW COME POWDERCOATED IN CRINKLE BLACK!
4. Fuse box covers
1. Major_Sarcasm - 1x Stainless Steel Rods (Silver) & Battery Clamp (Red, Square) - (10+ price)
2. V9 STi - 1x billet tow hook in black
3. stuntmonkey46 - 1x billet tow hook in red, fuse box cover
4. kartingsteve 1x billet tow hook in red for a newage.
5. markfey - fuse box cover classic V4 - crinkle black
6. LouisB - 1x billet tow hook in red - stainless steel rods (red washers)
7. zenith - 1x Stainless Steel Rods (Silver/Red washers) & Battery Clamp (Red, Circle)
8. Huzzy1- 1 stainless steel rods black washers, crackle black fuse cover,circular black battery clamp.
8. Huzzy1- 1 stainless steel rods silver washers, crackle black fuse cover, black battery clamp.
9. PaulPPP - 1x stainless steel rods (Blue washers), 1x battery clamp (Blue,square)
10. Beastra - 1x Stainless steel battery rods (Red Washers), 1x Red Tow Hook, 1x Blue Tow Hook.
Can I order other parts from your website at the same time as this group buy?
11. Fleetwood - (All Newage) 1x Fuse box cover crackle black, 1x stainless steel rods (black washers), 1x battery clamp black circular
7. zenith - 1x Stainless Steel Rods (Silver/Red washers) & Battery Clamp (Black, Circle)
