2006 Hawkeye subaru impreza STI 500 BHP + Breaking
Old 26 June 2013, 05:02 PM
Pole Position
Automotive Specialist
Pole Position's Avatar
Default 2006 Hawkeye subaru impreza STI 500 BHP + Breaking
We are currently breaking a very high spec hawkeye STI in 48w (crystal grey)
all parts are priced for collection only from wv133tg, postage can be arranged at extra cost.
Click image for larger version
Engine - SOLD
2.5 pinned ej257 semi closed deck casings . 100mm wiseco forged pistons. "H" beam forged conrods. 79mm nitrided crankshaft. Cosworth baffle plate with twin scroll sump. ACL big end bearings. ACL main bearings. 11mm ARP head studs. Engine covered 3500 miles. (if supplied with heads will come with VR MLS motorsport 0.9 mm head gaskets engine built by Pole Position.
Pulleys - SOLD
Leightweight crank,power steering, and alternator in silver.
Engine Loom - £50
32bit hawkeye 3 pin AVCS engine harness
3 Pin alternator - SOLD
3 pin alternator. Perfect working condition
PAS Pump - £100
power steering pump including pipe and remote res. Perfect working order.
Master Cylinder - £20
brake master cylinder. Perfect working order.
Clutch master - £20
Clutch master cylinder. Perfect working order and ideal for classic / newage sti top mount conversion.
Oil cooler - £200
21 row custom oil cooler set up with stainless braided lines and thermostatic controlled sandwich plate.
MAP - £70
4 BAR map sensor
Throttle Body - £80
DBW throttle body in perfect working condition
Induction Kit - SOLD
Custom 4" into 6" k&n aluminium pipe and filter.
Manifold - £60
DBW red STI manifold.
ECU - £900
Simtek PRO. Multi map function with anti lag and x2 launch maps features enabled. Full details can be found on steve simpsons site.
Intercooler - £500
Custom large FMIC that fits inside front panel. Custom aluminium radiator setup with x2 motorsport fans. Pipework to suit rotated manifold. Seriously efficient setup for minimal lag. Can be fitted with no cutting to front bumper.
Injectors - £250
Denso/Deatchworks 1000cc. Only covered 1500 miles. Cost new over £400
Fuel system - SOLD
Perrin fuel rails with stainless steel braided lines. 3 port unbranded fuel pressure regulator. These are the rails needed to miss avcs pumps. They have feed and return on one side. Enabling easier setup on twisted setups. "Y" divider included.
Clutch - £750
HKS twin plate clutch. Lightweight flywheel. Covered 3500 miles with 1000 being running in miles. Capable of 600bhp
Front strut brace - £30
Aluminium strut brace with pink ends. Good condition.
Starter motor - £45
6 speed starter motor
Gearbox - £2250
2006 STI 6 speed DCCD box. All gears select flawlessly. No noises. DCCD works presicely and locks properly. Gearbox has covered 39000 miles. This is the "long legged hawkeye" box. Ratio 3.54 R180 but please check. Excellent working order. Includes dif temp sensor.
Front shafts - £150
Sold as a pair large shafts. Good condition.
Front wishbones - £100
Aluminium STI wishbones. Good condition. Pair
Rear shafts - £180
Sold as a pair. Good condition.
Front brakes - SOLD
Brembo calipers with performance friction carbon pads. The pads are only 1500 miles old and are simply brilliant. They cost £228 retail. The calipers were powder coated fluorecent yellow some time ago so have discoloured somewhat now. Calipers work perfect. Include braided flexi hoses. Grooved discs in good condition.
Rear brakes - SOLD
Brembo calipers with good condition standard pad. The calipers were powder coated fluorecent some time ago and are still quite bright. Calipers work perfect. Include braided flexi hoses. Standard brembo discs in good condition.
Exhaust - £200
3" slip jointed high flow system. Middle and back boxes, so no worries with track regulation or long runs. Stainless steel. Standard position exit. Currently set up to suit the down pipe for twisted turbo set up. This can be modified.
Rear ARB - £200
22mm uprated anti roll bar with different settings. Includes "D" bushes.
Suspension - £400
HSD Height adjustable coilovers. All in perfect working condition. They come with camber adjustable top hats and have tha ability to stiffen or soften the ride from the bottom of the shocker. They will only fit 2006/7 sti in current form but it would be possible to configure them for other models with little cost. A brilliant all round solution with out sacrificing all comfort.
Wheels - £500
Fully refurbished Rota Torque drifts. Matt black 9.5 inch wide, if not better. No tyres.
Interior - SOLD
2006/7 STI front and rear blue and black alcantara seats. Never been smoked in or had smelly pets in. Very good condition.
Door cards - SOLD
dashboard centre clock - £20
STI Chrome door handle pair - £20
Aluminium pedal set - £25
Centre console with later heater controls. Currently wrapped in carbon effect. - SOLD
centre console with arm rest - SOLD
Intercooler spray button, bottle and jet - £40
STI gearknob red stitch - £30
STI handbrake lever red stitch - SOLD
STI embossed gear surround. Includes gator. Great wrx upgrade - SOLD
Blue STI carpet. Good condition - £40
Version 9 black STI steering wheel - £100
Dash board complete - £50
Doors 48W crystal grey. EACH - £25 (N/S rear SOLD)
Full wiring loom less engine harness - £100
Fuel flap 48w crystal grey - £15
Front wings 48w crystal grey. EACH - SOLD
Mirrors 48w crystal grey. Pair - SOLD
Carbon "B" pillar trim. Pair - SOLD
2006 STI hawkeye front bumper comlete and uncut in 02c world rally blue. Good condition - SOLD
2006 STI hawkeye front bumper in 48W crystal grey. Very cut up for test work but very aggressive - £120
Siebon genuine carbon fibre hawkeye bonnet. Includes aero catch lock down fasteners. Slight laquer damage at ns corner closest to the windscreen. Hardly noticable but needs mentioning - SOLD
Siebon genuine carbon fibre hawkeye bootlid / trunk. Has been drilled for high level spoiler but will not show with genuine style new age spoiler - SOLD
Rear bumper in 48w crystal grey. Has at some point in its life had a little repair to os corner. Hardly noticable but needs mentioning - SOLD
Rear carbon fibre number plate surround. Very rare and very nice touch - SOLD
3D high level carbon fibre drift style spoiler with 10" brackets. Spoiler is adjustable. Good condition - SOLD
Carbon fibre mudflaps x4. Includes brackets - SOLD
Hella motorsport horns x2 - £40
HID hawkeye headlights Pair - £400
Rear lights - £120
Shell. Cat d recorded as stolen recovered 6 months after registration. Quite a lot of useage damage and developement damage but alright for projects - SOLD
Rear under diffuser - SOLD
For any further information please feel free to contact us during normal working hours via phone or PM on here.
Attached Thumbnails Click image for larger version
ID:	74598   Click image for larger version
ID:	74604   Click image for larger version
Old 26 June 2013, 06:23 PM
MichaelW
MichaelW's Avatar
How much for all the bits I would need to do a centre dash conversion from a bug please?
Old 26 June 2013, 07:04 PM
Billet
Billet's Avatar
Pm'd Re: wings and handbrake lever with cable
Old 26 June 2013, 07:55 PM
nyscooby
nyscooby's Avatar
PM fuel rails....
Old 26 June 2013, 08:59 PM
scoobyboy1
scoobyboy1's Avatar
Shark have you got a front splitter that you used to have on this???
If so would be interested if you have one for sale, could pick up also????
Old 26 June 2013, 09:36 PM
ethanrob
ethanrob's Avatar
Hi mate
I need the top centre air vent panel and steering wheel surround if available please
Cash waiting
Regards marcus
Old 26 June 2013, 09:49 PM
WarrenSTI
WarrenSTI's Avatar
Do you have both front foglight covers? If so how much?
Old 27 June 2013, 09:06 AM
Pole Position
Replied to everyone via PM and thanks for the interest.
Regards,
PPUK
Old 27 June 2013, 05:16 PM
jazzyjembreaze
jazzyjembreaze's Avatar
What breather system was it running
& what price if available
Old 27 June 2013, 09:43 PM
ethanrob
ethanrob's Avatar
Hi mate
Payment sent for steering surround,don't forget if the top centre vent comes free give me first dibs plz
Many thanks
Old 27 June 2013, 10:11 PM
MichaelW
MichaelW's Avatar
Payment sent
Old 01 July 2013, 10:59 PM
WarrenSTI
WarrenSTI's Avatar
Just sent payment for Fog Light Covers
Old 02 July 2013, 04:58 PM
Pole Position
Various items sold, original post updated. Thanks for all the interest!
Old 04 July 2013, 09:42 AM
Pole Position
Post updated, all packages posted.
Old 05 July 2013, 12:12 PM
Rice Rocket
Rice Rocket's Avatar
How much for the drivers wing inset panel?
Old 05 July 2013, 02:54 PM
seaking22b
seaking22b's Avatar
Do you still have the speedo cluster, if so how much posted to Bury St Edmunds in Suffolk ?
Old 05 July 2013, 05:43 PM
MelTypeR
MelTypeR's Avatar
Do you have all the boot carpet set? inc the side parts?
Old 05 July 2013, 07:44 PM
Cpt Jack Sparrow
Cpt Jack Sparrow's Avatar
Hi I don't suppose you will sell the door cards separately to the seats?
Need all 4
Old 06 July 2013, 02:46 AM
BikerDarren24
BikerDarren24's Avatar
Hi mate, Interested in the HID headlights, only after one to be fair. How much for postage to Glasgow mate?
Old 07 July 2013, 08:19 PM
B0DSKI
B0DSKI's Avatar
Cheeky offer of £60 for the mudflaps
Old 08 July 2013, 12:08 PM
Pole Position
All Pm's sent and replied too.
Regards,
PPUK
Old 08 July 2013, 12:27 PM
B0DSKI
B0DSKI's Avatar
Back at ya
Old 14 July 2013, 03:14 PM
Niemitek
Niemitek's Avatar
How much for the front grills if you have them?
Old 14 July 2013, 08:04 PM
Ferry
Ferry's Avatar
Is the steeri g wheel still available?
Old 15 July 2013, 01:56 PM
B0DSKI
B0DSKI's Avatar
Mudflaps arrived safe and sound
Old 15 July 2013, 02:57 PM
Pole Position
All PM's responded.
Old 18 July 2013, 01:40 PM
WRX_Craig
WRX_Craig's Avatar
Are the door cards and seats still available ?
Old 18 July 2013, 03:17 PM
Pole Position
All items posted and PM's responded.
Old 22 July 2013, 08:09 AM
super_ted
super_ted's Avatar
Hi, are you still breaking this? I'm after the front wheel aprons from the shell if you still have it?
Old 22 July 2013, 08:49 AM
Pole Position
All PM's and questions replied.
Quick Reply: 2006 Hawkeye subaru impreza STI 500 BHP + Breaking
