Garage Clearout - lots of bits!
Old 04 August 2013, 01:26 AM
Ginola
Ginola's Avatar
Default Garage Clearout - lots of bits!
Moved:- https://www.scoobynet.com/subaru-par...clear-out.html
Old 04 August 2013, 02:29 PM
Philturbo1
Philturbo1's Avatar
Hi how much for the oil cooler delivered to Barnsley Yorkshire and have you got the pipe work and sandwich plate. Phil
Old 04 August 2013, 02:37 PM
*matthewturb2000*
*matthewturb2000*'s Avatar
hi mate are the pads a;ll the same thickness, i have a sticky pot on mine thease will do till i get the refurbed cheers
Old 04 August 2013, 03:55 PM
Ginola
Ginola's Avatar
PM Sent
PM Sent
Old 04 August 2013, 10:17 PM
joey_turbo
joey_turbo's Avatar
That PPP ecu has gotta be worth more than that. Should still make at least 150 on ebay.
Old 04 August 2013, 10:29 PM
winston69
winston69's Avatar
99/00 Standard recirc valve and gasket brand new in bag £25 + del
Both brand new? I'll give you £25 delivered via PayPal gift if so
Old 04 August 2013, 11:41 PM
Ginola
Ginola's Avatar
Dono, It has been up on here before at 100 and not gone..
PM Sent.
Old 09 August 2013, 11:54 AM
Ginola
Ginola's Avatar
bump
Old 09 August 2013, 11:57 AM
Swedge
Swedge's Avatar
Does the ppp board need soldered on?
Old 13 August 2013, 09:35 PM
Ginola
Ginola's Avatar
top
Old 13 August 2013, 09:40 PM
Oggy249
Oggy249's Avatar
is that ecu a mapable one and will it fit a 99 uk turbo cheers
Old 13 August 2013, 10:28 PM
Swedge
Swedge's Avatar
No it won't fit and it's sold to me
Old 13 August 2013, 10:48 PM
joey_turbo
joey_turbo's Avatar
He's talking about the ECU, not the PPP board.
If it is a Forester specific one, it won't work on an Impreza without a re-map.
Old 13 August 2013, 10:52 PM
Swedge
Swedge's Avatar
Aright sorry
Old 13 August 2013, 11:38 PM
Ginola
Ginola's Avatar
It is designed for a Forester, I don't know if it will fit a 99 UK turbo sorry.
Old 14 August 2013, 07:20 AM
Oggy249
Oggy249's Avatar
Oki doki cheers bud
Old 18 August 2013, 12:35 PM
Peanuts
Peanuts's Avatar
is the arb single size or is it adjustable 3 hole and just dirty?
Old 18 August 2013, 05:55 PM
Ginola
Ginola's Avatar
It is adjustable 3x Holes my bad
Old 18 August 2013, 07:35 PM
Noobz941
Noobz941's Avatar
whats the miles on the clocks ?
Old 18 August 2013, 07:41 PM
Ginola
Ginola's Avatar
You asked me before a while back didn't I PM you?
Old 20 August 2013, 10:05 PM
Ginola
Ginola's Avatar
bump
Old 26 August 2013, 11:25 PM
Ginola
Ginola's Avatar
top
Old 27 August 2013, 11:58 PM
Ginola
Ginola's Avatar
top
Old 01 September 2013, 12:46 PM
Ginola
Ginola's Avatar
bump
Old 12 September 2013, 10:05 PM
Ginola
Ginola's Avatar
bump
Old 13 September 2013, 08:37 PM
BHPvstorque
BHPvstorque's Avatar
Going to ask a stupid question sorry not very mechanically minded would the dccd controller work on a ver 5 box ie give more adjustment or were they different gearboxes. Sorry if stupid question.
Old 14 September 2013, 12:04 AM
Ginola
Ginola's Avatar
Which Version 5 do you have? The Type R box and center diff I'm pretty sure are different to the normal STI box but I could be wrong.
Dave.
Old 14 September 2013, 06:58 AM
scoobynshag
scoobynshag's Avatar
How much for just the diff posted please mate and will it fit a 97 uk turbo without having to change anything like driveshafts or prop
Old 14 September 2013, 10:20 PM
Ginola
Ginola's Avatar
I'm not sure if it fits a 97 uk turbo, you need to check if the ratio's are the same, Where about's are you? I Will get a quote for shipping for you.
Dave.
Old 15 September 2013, 01:25 PM
Ginola
Ginola's Avatar
Quick update, this will fit a 97/98 uk turbo, the ratios are the same but you will need the shafts too, where abouts are you as shipping will be expensive (half pallet at aproximetly 40kg
Quick Reply: Garage Clearout - lots of bits!
