BLOBEYE WIDE TRACK STI BREAKING (SYVECS/WHITELINE/SAMCOS/REBUILT ENGINE/DCCD/BREMBOS+
Old 27 August 2013, 08:34 PM
Default BLOBEYE WIDE TRACK STI BREAKING (SYVECS/WHITELINE/SAMCOS/REBUILT ENGINE/DCCD/BREMBOS+
ok we have another nice 66k 05 plate blobeye wide track sti in 02c for breaking all in excellent working order very well looked after and maintained example from its mature owner..all parts will be removed later on this week so please check delivery before buying please
all parts are based on collection delivery can be aranged at extra cost please ask
MB developments
Unit 3
Addenbrook street
Darlaston
Ws10 8hj
freshly rebuilt sti semi closed deck avcs heads long engine all in excellent working order great runner very nice sound engine and very well looked after by mature owners less than 1000miles since built with brand new oem crankshaft rods and pistons and acl race bearings and uprated oil pump all new seals and steel head gaskets fitted over 4k to built with invoices ..no knocks rattles or oil or water use pulls very nice and runs faultless great replacement engine or wrx etc upgrade.sold as a long engine minus inlet/manifold/turbo etc £2000
wide track dccd 6 speed gearbox in excellent working order very very nice box very smooth in all gears no whines or crunches at all all dccd works perfectly also as it should complete with matching r180 rear diff shorter propshaft and matching gear selector mech also great conversion package £2000
[IMG][/IMG]
male ended later style front drive shafts excellent con £180pair
r180 larger rear drive shafts excellent working order £180pair
6 speed starter motor £45
sti larger tmic in v good con complete with genuine sti pipe work mounting brackets great for classics and newage wrx models £150
inner wing induction kit with pipe work and filter for mafless running cars £40
550cc pink injectors excellent working order £100set
full wide track dccd sti car wiring loom uncut or modded minus small engine loom £150
de catted performance down pipe £sold
sti spec headers with non catted uppipe great con and excellent wrx upgrade £60
coil packs excellent working order £80set
2 port boost solenoid £20
maf sensor excellent working order genuin part £45
plastic later style header tank good con no leaks £25
3 pin alternator excellent working order £35
alloy battery claim with sercuring bars £20
air con pump excellent working order £15
air con rad good con no leaks or damage £20
washer bottle with pumps £15
intake snorkel £10
WHEELS/BRAKES/SUSPENTION
cusco front strut brace good con £40
[IMG][/IMG]
114pcd wide track hubs excellent con all good bearings etc great upgrade for older models £300set will not split
wide track later style front subframe good con £60
wide track later style rear subframe good con £60
wide track alloy front arms excellent con complete with bushes ect £80pair
wide track alloy rear trailing arms good con with uprated poly bushes recently fitted excellent upgrade £100set
wide track later style steering rack steering rack £60
pas steering pump in perfect working order £70
pas pipe with with remote bottle and cooler £30
EXTERIOR BODY WORK
wide track rear bumper with arch extenstions all in grear con etc great upgrade for older models £200 will not split
sti front grill with badges excellent con £60
blobeye alloy bonnet with genuine sti large scoop good con no damage etc the old stone chip if anything...no under tray inc £280 will not split
blobeye sti headlights nice clean lights standard untouched or messed with complete with bulbs and wiring £250pair
blobeye tail lights good con great hawkeye and bugeye upgrade £100pair
05 plate onwards sti boot lid good con with badges £60
wing mirrors good con £45pair
fuel filler door £15
front window good con £45
side mouldings trims £20pair
roof gutter trims £20pair
blue sti mud flaps good con with brackets £25set
INTERIOR
all black sti steering wheel in good con some minor marks if any complete with air bag and clock spring for easy fitment £150
sti blue carpet good con no rips etc great wrx upgrade £70
sti blue matt set good con £25set
sti 6 speed red stitch gearknob £25
dccd buttons £15 each
newage dash top good con £30
boot carpet good con £20
revised material type sun visors £20pair
Old 27 August 2013, 11:32 PM
mctwistuk
mctwistuk's Avatar
How much for the samco coolant hoses delivered to Glasgow and does it include top and bottom radiator hoses?
Chris
Old 28 August 2013, 08:29 AM
Hi chris it doesn indeed inc top and bottom hoses aswell as the other water hoses fella postage £9 fella pm me if needed
All pm's replied
Old 28 August 2013, 09:04 AM
mctwistuk
mctwistuk's Avatar
I will take them in that case will send pm
Chris
Old 28 August 2013, 10:03 AM
pm replied cheers
all pm's replied
Old 28 August 2013, 01:52 PM
328isport
328isport's Avatar
Hi guys, will the rear ARB and stout mounts fit a classic? (97' UK car)
Old 28 August 2013, 02:54 PM
yes they will pm me if needed
all pm's replied
Old 28 August 2013, 06:40 PM
PICTURES NOW ADDED
all pm's replied
Old 28 August 2013, 08:09 PM
Hammer man
Hammer man's Avatar
Matt. Do you know if the "whiteline stout mount uprated rear anti roll bar mounts" will fit my UK04 blob sti?. Mine aint a widetrack and I don't know if there is any difference. If they do, I`ll take them please and can you post to Coventry please..
Old 28 August 2013, 08:36 PM
Stout mounts will roll bar won't but I do have one for your version tho also fella postage £9 on the pair if needed cheers
Old 28 August 2013, 09:04 PM
Hammer man
Hammer man's Avatar
Ive got the bar Matt. Drop me a pm with payment details and I will have the mounts....cheers
Old 29 August 2013, 08:16 AM
Cheers for payment cliff
All pm's replied
Old 29 August 2013, 07:17 PM
LIST UPDATED SOLD ITEMS LISTED MORE PICTURES ADDED
Old 30 August 2013, 02:38 PM
List updated
All pm's replied
Old 31 August 2013, 10:59 PM
phila78
phila78's Avatar
Hi any of the blue hoses left?
Old 01 September 2013, 03:19 AM
Sorry all sold in afraid sorry
All pm's replied
Old 01 September 2013, 07:33 AM
white noise
white noise's Avatar
Hi Matty
Is the plate for sale ,if so,how much?
cheers
Neil
Old 01 September 2013, 08:55 AM
Sorry it's not no ex owner retained the plate sorry
All pm's replied
Old 09 September 2013, 12:02 PM
list updated all sold items removed and pm's replied
Old 09 September 2013, 09:09 PM
t79boy
t79boy's Avatar
Matt, interested in the turbo timer . PM me
Old 10 September 2013, 07:10 AM
Pm sent fella cheers
All pm's replied
Old 10 September 2013, 09:28 AM
pergie
pergie's Avatar
how much for the front lamba sensor posted to ireland ?
Old 10 September 2013, 01:19 PM
Hi there your looking £67 posted for the front one pm me if needed
All pm's replied
Old 10 September 2013, 09:00 PM
samben
samben's Avatar
I'm guessing the syvecs has sold mat?
Old 11 September 2013, 07:24 AM
Yes sorry it's long sold sorry
All pm's replied
Old 14 September 2013, 09:23 AM
list updated some prices lowered to clear some space and pm's replied
Old 22 September 2013, 05:46 PM
List updated sold items removed and pm's replied
Old 29 September 2013, 12:40 AM
chappaz
chappaz's Avatar
sti spec headers still for sale mate? if so pm me price posted to highlands..cheers
Old 29 September 2013, 08:40 AM
ATWRX
ATWRX's Avatar
Forget it.
Old 29 September 2013, 10:44 AM
chappaz
chappaz's Avatar
no worries, i mite as well be in the north pole with delivery costs.... cheers anyway mate
Quick Reply: BLOBEYE WIDE TRACK STI BREAKING (SYVECS/WHITELINE/SAMCOS/REBUILT ENGINE/DCCD/BREMBOS+
